RTEMS 6.1
elf_machdep.h
1/* $NetBSD: elf_machdep.h,v 1.10 2009/05/30 05:56:52 skrll Exp $ */
2
3#define ELF32_MACHDEP_ENDIANNESS ELFDATA2LSB
4#define ELF32_MACHDEP_ID_CASES \
5 case EM_386: \
6 case EM_486: \
7 break;
8
9#define ELF64_MACHDEP_ENDIANNESS XXX /* break compilation */
10#define ELF64_MACHDEP_ID_CASES \
11 /* no 64-bit ELF machine types supported */
12
13#define ELF32_MACHDEP_ID EM_386
14
15#define ARCH_ELFSIZE 32 /* MD native binary size */
16
17/* i386 relocations */
18#define R_386_NONE 0
19#define R_386_32 1
20#define R_386_PC32 2
21#define R_386_GOT32 3
22#define R_386_PLT32 4
23#define R_386_COPY 5
24#define R_386_GLOB_DAT 6
25#define R_386_JMP_SLOT 7
26#define R_386_RELATIVE 8
27#define R_386_GOTOFF 9
28#define R_386_GOTPC 10
29
30/* TLS relocations */
31#define R_386_TLS_TPOFF 14
32#define R_386_TLS_IE 15
33#define R_386_TLS_GOTIE 16
34#define R_386_TLS_LE 17
35#define R_386_TLS_GD 18
36#define R_386_TLS_LDM 19
37
38/* The following relocations are GNU extensions. */
39#define R_386_16 20
40#define R_386_PC16 21
41#define R_386_8 22
42#define R_386_PC8 23
43
44/* More TLS relocations */
45#define R_386_TLS_GD_32 24
46#define R_386_TLS_GD_PUSH 25
47#define R_386_TLS_GD_CALL 26
48#define R_386_TLS_GD_POP 27
49#define R_386_TLS_LDM_32 28
50#define R_386_TLS_LDM_PUSH 29
51#define R_386_TLS_LDM_CALL 30
52#define R_386_TLS_LDM_POP 31
53#define R_386_TLS_LDO_32 32
54#define R_386_TLS_IE_32 33
55#define R_386_TLS_LE_32 34
56#define R_386_TLS_DTPMOD32 35
57#define R_386_TLS_DTPOFF32 36
58#define R_386_TLS_TPOFF32 37
59#define R_386_TLS_GOTDESC 39
60#define R_386_TLS_DESC_CALL 40
61#define R_386_TLS_DESC 41
62
63#define R_TYPE(name) __CONCAT(R_386_,name)
