RTEMS 6.1
i2c-dev.h
2
11/*
12 * Copyright (c) 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _UAPI_LINUX_I2C_DEV_H
37#define _UAPI_LINUX_I2C_DEV_H
38
39#include <stdint.h>
40
59#define I2C_RETRIES 0x701
60
66#define I2C_TIMEOUT 0x702
67
75#define I2C_SLAVE 0x703
76
82#define I2C_SLAVE_FORCE 0x706
83
90#define I2C_TENBIT 0x704
91
97#define I2C_FUNCS 0x705
98
106#define I2C_RDWR 0x707
107
114#define I2C_PEC 0x708
115
121#define I2C_SMBUS 0x720
122
129 uint8_t read_write;
130 uint8_t command;
131 uint32_t size;
132 union i2c_smbus_data *data;
133};
134
139 struct i2c_msg *msgs;
140 uint32_t nmsgs;
141};
142
146#define I2C_RDRW_IOCTL_MAX_MSGS 42
147
150#endif /* _UAPI_LINUX_I2C_DEV_H */
I2C transfer message.
Definition: i2c.h:151
Argument type for I2C_RDWR IO control call.
Definition: i2c-dev.h:138
Argument type for I2C_SMBUS IO control call.
Definition: i2c-dev.h:128
SMBus data.
Definition: i2c.h:242
