RTEMS 6.1
hsu.h
2
11/*
12 * Copyright (C) 2010, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC32XX_HSU_H
37#define LIBBSP_ARM_LPC32XX_HSU_H
38
39#include <rtems/termiostypes.h>
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
55typedef struct {
56 uint32_t fifo;
57 uint32_t level;
58 uint32_t iir;
59 uint32_t ctrl;
60 uint32_t rate;
62
63typedef struct {
65 volatile lpc32xx_hsu *hsu;
66 size_t chars_in_transmission;
68 uint32_t initial_baud;
70
71extern const rtems_termios_device_handler lpc32xx_hsu_fns;
72
73bool lpc32xx_hsu_probe(rtems_termios_device_context *base);
74
77#ifdef __cplusplus
78}
79#endif /* __cplusplus */
80
81#endif /* LIBBSP_ARM_LPC32XX_HSU_H */
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: hsu.h:63
Definition: hsu.h:55
Termios device context.
Definition: termiosdevice.h:68
Termios device handler.
Definition: termiosdevice.h:100
