RTEMS 6.1
grpci2dma.h
2
3/*
4 * GRPCI2 DMA Driver
5 *
6 * COPYRIGHT (c) 2017
7 * Cobham Gaisler AB
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 *
18 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28 * POSSIBILITY OF SUCH DAMAGE.
29 *
30 * OVERVIEW
31 * ========
32 * This driver controls the DMA on the GRPCI2 device, located
33 * at an on-chip AMBA.
34 */
35
36#ifndef __GRPCI2DMA_H__
37#define __GRPCI2DMA_H__
38
39#include <stdint.h>
40#include <stdio.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
46/* Error return codes */
47#define GRPCI2DMA_ERR_OK 0
48#define GRPCI2DMA_ERR_WRONGPTR -1
49#define GRPCI2DMA_ERR_NOINIT -2
50#define GRPCI2DMA_ERR_TOOMANY -3
51#define GRPCI2DMA_ERR_ERROR -4
52#define GRPCI2DMA_ERR_STOPDMA -5
53#define GRPCI2DMA_ERR_NOTFOUND -6
54
55/* Size of a dma descriptors */
56#define GRPCI2DMA_BD_CHAN_SIZE 0x10
57#define GRPCI2DMA_BD_DATA_SIZE 0x10
58
59/* Alignment of dma descriptors */
60#define GRPCI2DMA_BD_CHAN_ALIGN 0x10
61#define GRPCI2DMA_BD_DATA_ALIGN 0x10
62
63/* User-helper functions to allocate/deallocate
64 * channel and data descriptors
65 */
66extern void * grpci2dma_channel_new(int number);
67extern void grpci2dma_channel_delete(void * chanbd);
68extern void * grpci2dma_data_new(int number);
69extern void grpci2dma_data_delete(void * databd);
70
71/* Function:
72 * -grpci2dma_prepare
73 * Description:
74 * -Prepare a transfer, initializing the required data descriptors
75 * Parameters:
76 * -pci_start: Where in PCI/remote starts the transfer
77 * -ahb_start: Where in AHB/local starts the transfer
78 * -dir: Direction of the transfer (AHBTOPCI or PCITOAHB)
79 * -endianness: Endianness of the transfer (LITTLEENDIAN or BIGENDIAN)
80 * -size: Size in bytes of the transfer (the function will calculate if there
81 * are enough descriptors)
82 * -databd: Pointer to the data descriptor buffer
83 * -bdindex: Where in the buffer to start the transfer
84 * -bdmax: Maximum index for the data descriptor buffer
85 * -block_size: Size in bytes for each PCI transaction (or block). Guaranteed
86 * to be at least smaller that this value. Put 0 to use default.
87 * Default is maximum, which is 0x10000*4 bytes.
88 * Returns:
89 * -WRONGPTR: Wrong input parameters
90 * -TOOMANY: Not enough data descriptors in the buffer
91 * -value > 0: A positive return value means the number of data descriptors
92 * prepared/used in the buffer, starting from index.
93 */
94#define GRPCI2DMA_AHBTOPCI 1
95#define GRPCI2DMA_PCITOAHB 0
96#define GRPCI2DMA_LITTLEENDIAN 1
97#define GRPCI2DMA_BIGENDIAN 0
98extern int grpci2dma_prepare(
99 uint32_t pci_start, uint32_t ahb_start, int dir, int endianness,
100 int size, void * databd, int bdindex, int bdmax, int block_size);
101
102/* Function:
103 * -grpci2dma_status
104 * Description:
105 * -Status of an transfer:
106 * Parameters:
107 * -databd: Pointer to the data descriptor buffer
108 * -bdindex: Where in the buffer starts the transfer
109 * -bdsize: Number of descriptors used by the transfer
110 * Returns:
111 * -WRONGPTR: Wrong input parameters
112 * -GRPCI2DMA_BD_DATA_STATUS_ERR: If at least one of the descriptors has an
113 * error
114 * -GRPCI2DMA_BD_DATA_STATUS_ENABLED: If at least one of the descriptors is
115 * enabled, which means that the transfer is still not finished.
116 * -GRPCI2DMA_BD_DATA_STATUS_DISABLED: If all the descriptors are disabled,
117 * which means that either the transfer finished or it was never prepared.
118 */
119#define GRPCI2DMA_BD_STATUS_DISABLED 0
120#define GRPCI2DMA_BD_STATUS_ENABLED 1
121#define GRPCI2DMA_BD_STATUS_ERR 2
122extern int grpci2dma_status(void *databd, int bdindex, int bdsize);
123
124/* Function Interrupt-Code ISR callback prototype.
125 * arg - Custom arg provided by user
126 * cid - Channel ID that got the interrupt
127 * status - Error status of the DMA core
128 */
129typedef void (*grpci2dma_isr_t)(void *arg, int cid, unsigned int status);
130
131/* Function:
132 * -grpci2dma_isr_register
133 * Description:
134 * -Register an ISR for a channel (and enable interrupts if disabled)
135 * Parameters:
136 * -chan_no: ID of the channel
137 * -dmaisr: ISR
138 * -arg: Argument to pass to the ISR when called
139 * Returns:
140 * -NOINIT: GRPCI2 DMA not initialized
141 * -WRONGPTR: Wrong input parameters
142 * -OK (=0): Done
143 */
144extern int grpci2dma_isr_register(
145 int chan_no, grpci2dma_isr_t dmaisr, void *arg);
146
147/* Function:
148 * -grpci2dma_isr_unregister
149 * Description:
150 * -Unregister an ISR for a channel (and enable interrupts if disabled)
151 * Parameters:
152 * -chan_no: ID of the channel
153 * Returns:
154 * -NOINIT: GRPCI2 DMA not initialized
155 * -WRONGPTR: Wrong input parameters
156 * -OK (=0): Done
157 */
158extern int grpci2dma_isr_unregister(int chan_no);
159
160/* Function:
161 * -grpci2dma_open
162 * Description:
163 * -Open a channel (and allocate the descriptor if the user does not provide
164 * one).
165 * Parameters:
166 * -chan: Descriptor for the channel (must be aligned to 0x10)
167 * Returns:
168 * -NOINIT: GRPCI2 DMA not initialized
169 * -TOOMANY: Maximum number of channels already opened.
170 * -WRONGPTR: Wrong input parameters
171 * -ERROR: Inconsistent state found in driver
172 * -value > 0: A positive return value means the id for the channel.
173 */
174extern int grpci2dma_open(void * chan);
175
176/* Function:
177 * -grpci2dma_close
178 * Description:
179 * -Stop and close a channel (and deallocate it if the user did not provide a
180 * pointer when opening it)
181 * Parameters:
182 * -chan_no: Id of the channel
183 * Returns:
184 * -NOINIT: GRPCI2 DMA not initialized
185 * -NOTFOUND: Channel not opened.
186 * -STOPDMA: Cannot stop channel.
187 * -WRONGPTR: Wrong input parameters
188 * -OK (=0): Done.
189 */
190extern int grpci2dma_close(int chan_no);
191
192/* Function:
193 * -grpci2dma_start
194 * Description:
195 * -Start a channel
196 * Parameters:
197 * -chan_no: Id of the channel
198 * -options: Maximum number of data descriptors to be executed before moving
199 * to next channel (up to 0x10000)
200 * Returns:
201 * -NOINIT: GRPCI2 DMA not initialized
202 * -WRONGPTR: Wrong input parameters
203 * -ERROR: Inconsistent state found in driver
204 * -OK (=0): Done.
205 */
206extern int grpci2dma_start(int chan_no, int options);
207
208/* Function:
209 * -grpci2dma_stop
210 * Description:
211 * -Start a channel
212 * Parameters:
213 * -chan_no: Id of the channel
214 * Returns:
215 * -NOINIT: GRPCI2 DMA not initialized
216 * -WRONGPTR: Wrong input parameters
217 * -ERROR: Inconsistent state found in driver
218 * -OK (=0): Done.
219 */
220extern int grpci2dma_stop(int chan_no);
221
222/* Function:
223 * -grpci2dma_push
224 * Description:
225 * -Push a transfer into a channel (already started or not)
226 * Parameters:
227 * -chan_no: Id of the channel
228 * -databd: Pointer to the data descriptor buffer
229 * -bdindex: Where in the buffer starts the transfer
230 * -bdsize: Number of descriptors used by the transfer
231 * Returns:
232 * -NOINIT: GRPCI2 DMA not initialized
233 * -WRONGPTR: Wrong input parameters
234 * -NOTFOUND: Channel not opened.
235 * -OK (=0): Done.
236 */
237extern int grpci2dma_push(int chan_no, void *databd, int bdindex, int bdsize);
238
239/* Function:
240 * -grpci2dma_active
241 * Description:
242 * -Check if dma is active
243 * Parameters:
244 * Returns:
245 * -(!=0): Active.
246 * -(=0): Not active.
247 */
248extern int grpci2dma_active(void);
249
250/* Function:
251 * -grpci2dma_interrupt_enable
252 * Description:
253 * -Enable interrupt for a transfer
254 * Parameters:
255 * -databd: Pointer to the data descriptor buffer
256 * -bdindex: Where in the buffer starts the transfer
257 * -bdmax: Upper limit for index. index < bdmax
258 * -options:
259 * (=GRPCI2DMA_OPTIONS_ALL)=Enable interrupt on all transfer descriptors.
260 * (=GRPCI2DMA_OPTIONS_ONE)=Enable interrupt on transfer descriptor
261 * indicated by bdindex.
262 * Returns:
263 * -NOINIT: GRPCI2 DMA not initialized
264 * -WRONGPTR: Wrong input parameters
265 * -ERROR: Inconsistent state found in driver
266 * -OK (=0): Done.
267 */
268#define GRPCI2DMA_OPTIONS_ALL 1
269#define GRPCI2DMA_OPTIONS_ONE 0
270extern int grpci2dma_interrupt_enable(
271 void *databd, int bdindex, int bdmax, int options);
272
273/* Debug function: print dma channel and associated data descriptors.
274 * Only prints if driver internal DEBUG flag is defined. */
275extern int grpci2dma_print(int chan_no);
276extern int grpci2dma_print_bd(void * data);
277
278#ifdef __cplusplus
279}
280#endif
281
282#endif /* __GRPCI2DMA_H__ */
