RTEMS 6.1
The SSC driver provides the interface to configure and use the SSC peripheral.
!Usage
  1. Enable the SSC interface pins.
  2. Configure the SSC to operate at a specific frequency by calling SSC_Configure(). This function enables the peripheral clock of the SSC, but not its PIOs.
  3. Configure the transmitter and/or the receiver using the SSC_ConfigureTransmitter() and SSC_ConfigureEmitter() functions.
  4. Enable the PIOs or the transmitter and/or the received.
  5. Enable the transmitter and/or the receiver using SSC_EnableTransmitter() and SSC_EnableReceiver()
  6. Send data through the transmitter using SSC_Write()
  7. Receive data from the receiver using SSC_Read()
  8. Disable the transmitter and/or the receiver using SSC_DisableTransmitter() and SSC_DisableReceiver()
For more accurate information, please look at the SSC section of the Datasheet.
Related files :
ssc.c
ssc.h.
