RTEMS 6.1
Usage
- ISI_Init: initialize ISI with default parameters
- ISI_EnableInterrupt: enable one or more interrupts
- ISI_DisableInterrupt: disable one or more interrupts
- ISI_Enable: enable isi module
- ISI_Disable: disable isi module
- ISI_CodecPathFull: enable codec path
- ISI_SetFrame: set frame rate
- ISI_BytesForOnePixel: return number of byte for one pixel
- ISI_StatusRegister: return ISI status register
- ISI_Reset: make a software reset
