RTEMS 6.1
 UART Address-matching LSB Position In CR2 Register
 UART Advanced Feature Auto BaudRate Enable
 UART Advanced Feature AutoBaud Rate Mode
 UART Advanced Feature Binary Data Inversion
 UART Advanced Feature DMA Disable On Rx Error
 UART Advanced Feature Initialization Type
 UART Advanced Feature MSB First
 UART Advanced Feature Mute Mode Enable
 UART Advanced Feature Overrun Disable
 UART Advanced Feature RX Pin Active Level Inversion
 UART Advanced Feature RX TX Pins Swap
 UART Advanced Feature Stop Mode Enable
 UART Advanced Feature TX Pin Active Level Inversion
 UART Clock Prescaler
 UART DMA Rx
 UART DMA Tx
 UART Driver Enable Assertion Time LSB Position In CR1 Register
 UART Driver Enable DeAssertion Time LSB Position In CR1 Register
 UART DriverEnable Polarity
 UART Error Definition
 UART Half Duplex Selection
 UART Hardware Flow Control
 UART Interruption Clear Flags
 UART Interruptions Flag Mask
 UART Interrupts Definition
 UART LIN Break Detection
 UART Local Interconnection Network mode
 UART Number of Stop Bits
 UART One Bit Sampling Method
 UART Over Sampling
 UART Parity
 UART Receiver Timeout
 UART Reception type values
 UART Request Parameters
 UART RxEvent type values
 UART State
 UART State Code Definition
 UART Status Flags
 UART Transfer Mode
 UART WakeUp From Stop Selection
 UART WakeUp Methods
 UART polling-based communications time-out value
