RTEMS 6.1
Modules | Files | Macros | Variables
spec:/testsuites/validation-timecounter-smp-0
This validation test suite is intended test cases related to the use of timecouters. The Clock Driver is disabled. More...
 spec:/score/timecounter/val/get-smp
 Tests directives to get a time value.
file  ts-validation-timecounter-smp-0.c
#define CONFIGURE_MAXIMUM_PROCESSORS   4
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesValidationTimecounterSmp0"
 Each test must define a test name string.
