RTEMS 6.1
Modules | Files | Macros | Variables
spec:/testsuites/validation-timecounter-0
This validation test suite is intended test cases related to the installation of timecouters. The Clock Driver is disabled. More...
 spec:/score/timecounter/val/install
 Tests timecounter installation related functions and directives of the Clock Manager.
file  ts-validation-timecounter-0.c
#define CONFIGURE_MAXIMUM_PROCESSORS   1
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
const char rtems_test_name [] = "TestsuitesValidationTimecounter0"
 Each test must define a test name string.
