Tests properties of thread-local objects.
More...
| T_TEST_CASE (ScoreThreadValTlsMaxZero) |
This test case performs the following actions:
- The test action is carried out by the thread-local objects definition and the application configuration.
- Check that the CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE application configuration option resulted in the expected system setting. Since at least one thread-local objects is available, the referenced requirement is validated.
