RTEMS 6.1
Tests the .preinit_array constructor handling of the C runtime support.
More...
Files | |
| file | tc-preinit-array.c |
| T_TEST_CASE (ScoreThreadValPreinitArray) | |
This test case performs the following actions:
.preinit_array constructor invocation. Mark that the test case executed..preinit_array constructor was called exactly once..preeinit_array construction was done by the Classic API user initialization task..preinit_array constructor was called before the global constructor invocations.
