#define | QSPI_INSTANCES_NUMBER 1U |
#define | BSP_QSPI_SPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_MODE /* 1 Cmd Line, 1 Address Line and 1 Data Line */ |
#define | BSP_QSPI_SPI_1I2O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I2O_MODE /* 1 Cmd Line, 1 Address Line and 2 Data Lines */ |
#define | BSP_QSPI_SPI_2IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_2IO_MODE /* 1 Cmd Line, 2 Address Lines and 2 Data Lines */ |
#define | BSP_QSPI_SPI_1I4O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I4O_MODE /* 1 Cmd Line, 1 Address Line and 4 Data Lines */ |
#define | BSP_QSPI_SPI_4IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_4IO_MODE /* 1 Cmd Line, 4 Address Lines and 4 Data Lines */ |
#define | BSP_QSPI_DPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_DPI_MODE /* 2 Cmd Lines, 2 Address Lines and 2 Data Lines */ |
#define | BSP_QSPI_QPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_QPI_MODE /* 4 Cmd Lines, 4 Address Lines and 4 Data Lines */ |
#define | BSP_QSPI_STR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_STR_TRANSFER /* Single Transfer Rate */ |
#define | BSP_QSPI_DTR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_DTR_TRANSFER /* Double Transfer Rate */ |
#define | BSP_QSPI_DUALFLASH_DISABLE (BSP_QSPI_DualFlash_t)MT25TL01G_DUALFLASH_DISABLE /* Dual flash mode enabled */ |
#define | BSP_QSPI_FLASH_ID QSPI_FLASH_ID_1 |
#define | BSP_QSPI_BLOCK_8K MT25TL01G_SECTOR_4K |
#define | BSP_QSPI_BLOCK_64K MT25TL01G_BLOCK_32K |
#define | BSP_QSPI_BLOCK_128K MT25TL01G_BLOCK_64K |
#define | QSPI_CLK_ENABLE() __HAL_RCC_QSPI_CLK_ENABLE() |
#define | QSPI_CLK_DISABLE() __HAL_RCC_QSPI_CLK_DISABLE() |
#define | QSPI_CLK_GPIO_CLK_ENABLE() __HAL_RCC_GPIOB_CLK_ENABLE() |
#define | QSPI_BK1_CS_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE() |
#define | QSPI_BK1_D0_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE() |
#define | QSPI_BK1_D1_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE() |
#define | QSPI_BK1_D2_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE() |
#define | QSPI_BK1_D3_GPIO_CLK_ENABLE() __HAL_RCC_GPIOF_CLK_ENABLE() |
#define | QSPI_BK2_CS_GPIO_CLK_ENABLE() __HAL_RCC_GPIOC_CLK_ENABLE() |
#define | QSPI_BK2_D0_GPIO_CLK_ENABLE() __HAL_RCC_GPIOH_CLK_ENABLE() |
#define | QSPI_BK2_D1_GPIO_CLK_ENABLE() __HAL_RCC_GPIOH_CLK_ENABLE() |
#define | QSPI_BK2_D2_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE() |
#define | QSPI_BK2_D3_GPIO_CLK_ENABLE() __HAL_RCC_GPIOG_CLK_ENABLE() |
#define | QSPI_FORCE_RESET() __HAL_RCC_QSPI_FORCE_RESET() |
#define | QSPI_RELEASE_RESET() __HAL_RCC_QSPI_RELEASE_RESET() |
#define | QSPI_CLK_PIN GPIO_PIN_2 |
#define | QSPI_CLK_GPIO_PORT GPIOB |
#define | QSPI_BK1_CS_PIN GPIO_PIN_6 |
#define | QSPI_BK1_CS_GPIO_PORT GPIOG |
#define | QSPI_BK1_D0_PIN GPIO_PIN_8 |
#define | QSPI_BK1_D0_GPIO_PORT GPIOF |
#define | QSPI_BK1_D1_PIN GPIO_PIN_9 |
#define | QSPI_BK1_D1_GPIO_PORT GPIOF |
#define | QSPI_BK1_D2_PIN GPIO_PIN_7 |
#define | QSPI_BK1_D2_GPIO_PORT GPIOF |
#define | QSPI_BK1_D3_PIN GPIO_PIN_6 |
#define | QSPI_BK1_D3_GPIO_PORT GPIOF |
#define | QSPI_BK2_CS_PIN GPIO_PIN_11 |
#define | QSPI_BK2_CS_GPIO_PORT GPIOC |
#define | QSPI_BK2_D0_PIN GPIO_PIN_2 |
#define | QSPI_BK2_D0_GPIO_PORT GPIOH |
#define | QSPI_BK2_D1_PIN GPIO_PIN_3 |
#define | QSPI_BK2_D1_GPIO_PORT GPIOH |
#define | QSPI_BK2_D2_PIN GPIO_PIN_9 |
#define | QSPI_BK2_D2_GPIO_PORT GPIOG |
#define | QSPI_BK2_D3_PIN GPIO_PIN_14 |
#define | QSPI_BK2_D3_GPIO_PORT GPIOG |
#define | QSPI_FLASH_SIZE 26 /* Address bus width to access whole memory space */ |
#define | QSPI_PAGE_SIZE 256 |
#define | QSPI_BASE_ADDRESS 0x90000000 |
