RTEMS 6.1
SAI Exported Constants
 SAI Audio Frequency
 SAI Block Clock Strobing
 SAI Block Companding Mode
 SAI Block Data Size
 SAI Block FS Definition
 SAI Block FS Offset
 SAI Block FS Polarity
 SAI Block Fifo Status Level
 SAI Block Fifo Threshold
 SAI Block Flags Definition
 SAI Block Interrupts Definition
 SAI Block MSB LSB transmission
 SAI Block Master Clock Output
 SAI Block Master Clock OverSampling
 SAI Block Mode
 SAI Block Mute Value
 SAI Block NoDivider
 SAI Block Output Drive
 SAI Block Protocol
 SAI Block Slot Active
 SAI Block Slot Size
 SAI Block Synchronization
 SAI Error Code
 SAI External synchronisation
 SAI Mono Stereo Mode
 SAI PDM Clock Enable
 SAI Supported protocol
 SAI TRIState Management
 SAI protocol data size
