RTEMS 6.1
Files | Data Structures | Enumerations | Functions
file  tc-task-set-affinity.c
struct  RtemsTaskReqSetAffinity_Entry
struct  RtemsTaskReqSetAffinity_Context
 Test context for spec:/rtems/task/req/set-affinity test case. More...
enum  RtemsTaskReqSetAffinity_Pre_Id { RtemsTaskReqSetAffinity_Pre_Id_Invalid , RtemsTaskReqSetAffinity_Pre_Id_Task , RtemsTaskReqSetAffinity_Pre_Id_NA }
enum  RtemsTaskReqSetAffinity_Pre_CPUSetSize { RtemsTaskReqSetAffinity_Pre_CPUSetSize_Askew , RtemsTaskReqSetAffinity_Pre_CPUSetSize_Normal , RtemsTaskReqSetAffinity_Pre_CPUSetSize_Huge , RtemsTaskReqSetAffinity_Pre_CPUSetSize_NA }
enum  RtemsTaskReqSetAffinity_Pre_CPUSetOnline { RtemsTaskReqSetAffinity_Pre_CPUSetOnline_Supported , RtemsTaskReqSetAffinity_Pre_CPUSetOnline_Unsupported , RtemsTaskReqSetAffinity_Pre_CPUSetOnline_NA }
enum  RtemsTaskReqSetAffinity_Pre_CPUSetHuge { RtemsTaskReqSetAffinity_Pre_CPUSetHuge_NotZero , RtemsTaskReqSetAffinity_Pre_CPUSetHuge_Zero , RtemsTaskReqSetAffinity_Pre_CPUSetHuge_NA }
enum  RtemsTaskReqSetAffinity_Pre_CPUSet { RtemsTaskReqSetAffinity_Pre_CPUSet_Valid , RtemsTaskReqSetAffinity_Pre_CPUSet_Null , RtemsTaskReqSetAffinity_Pre_CPUSet_NA }
enum  RtemsTaskReqSetAffinity_Post_Status {
  RtemsTaskReqSetAffinity_Post_Status_Ok , RtemsTaskReqSetAffinity_Post_Status_InvAddr , RtemsTaskReqSetAffinity_Post_Status_InvId , RtemsTaskReqSetAffinity_Post_Status_InvNum ,
  RtemsTaskReqSetAffinity_Post_Status_NA
enum  RtemsTaskReqSetAffinity_Post_SetAffinity { RtemsTaskReqSetAffinity_Post_SetAffinity_Set , RtemsTaskReqSetAffinity_Post_SetAffinity_Nop , RtemsTaskReqSetAffinity_Post_SetAffinity_NA }
 T_TEST_CASE_FIXTURE (RtemsTaskReqSetAffinity, &RtemsTaskReqSetAffinity_Fixture)
