RTEMS 6.1
Files | Data Structures | Typedefs | Enumerations | Functions
file  tc-task-exit.c
struct  RtemsTaskReqExit_Entry
struct  RtemsTaskReqExit_Context
 Test context for spec:/rtems/task/req/exit test case. More...
typedef RtemsTaskReqExit_Context Context
enum  RtemsTaskReqExit_Pre_Restarting { RtemsTaskReqExit_Pre_Restarting_Yes , RtemsTaskReqExit_Pre_Restarting_No , RtemsTaskReqExit_Pre_Restarting_NA }
enum  RtemsTaskReqExit_Pre_Terminating { RtemsTaskReqExit_Pre_Terminating_Yes , RtemsTaskReqExit_Pre_Terminating_No , RtemsTaskReqExit_Pre_Terminating_NA }
enum  RtemsTaskReqExit_Pre_Protected { RtemsTaskReqExit_Pre_Protected_Yes , RtemsTaskReqExit_Pre_Protected_No , RtemsTaskReqExit_Pre_Protected_NA }
enum  RtemsTaskReqExit_Pre_ThreadDispatch { RtemsTaskReqExit_Pre_ThreadDispatch_Enabled , RtemsTaskReqExit_Pre_ThreadDispatch_Disabled , RtemsTaskReqExit_Pre_ThreadDispatch_NA }
enum  RtemsTaskReqExit_Post_FatalError { RtemsTaskReqExit_Post_FatalError_Yes , RtemsTaskReqExit_Post_FatalError_Nop , RtemsTaskReqExit_Post_FatalError_NA }
enum  RtemsTaskReqExit_Post_DeleteExtensions { RtemsTaskReqExit_Post_DeleteExtensions_Nop , RtemsTaskReqExit_Post_DeleteExtensions_NA }
enum  RtemsTaskReqExit_Post_RestartExtensions { RtemsTaskReqExit_Post_RestartExtensions_Nop , RtemsTaskReqExit_Post_RestartExtensions_NA }
enum  RtemsTaskReqExit_Post_TerminateExtensions { RtemsTaskReqExit_Post_TerminateExtensions_Yes , RtemsTaskReqExit_Post_TerminateExtensions_Nop , RtemsTaskReqExit_Post_TerminateExtensions_NA }
enum  RtemsTaskReqExit_Post_Zombie { RtemsTaskReqExit_Post_Zombie_Yes , RtemsTaskReqExit_Post_Zombie_No , RtemsTaskReqExit_Post_Zombie_NA }
enum  RtemsTaskReqExit_Post_ID { RtemsTaskReqExit_Post_ID_Valid , RtemsTaskReqExit_Post_ID_Invalid , RtemsTaskReqExit_Post_ID_NA }
enum  RtemsTaskReqExit_Post_Delete { RtemsTaskReqExit_Post_Delete_NextAllocate , RtemsTaskReqExit_Post_Delete_Nop , RtemsTaskReqExit_Post_Delete_NA }
 T_TEST_CASE_FIXTURE (RtemsTaskReqExit, &RtemsTaskReqExit_Fixture)
