Tests some Directive Status Codes interfaces.
More...
| T_TEST_CASE (RtemsStatusValStatus) |
This test case performs the following actions:
- Validate the status code constants.
- Assert that RTEMS_STATUS_CODES_FIRST has the expected value and is a constant expression.
- Check that RTEMS_STATUS_CODES_FIRST has the expected value.
- Assert that RTEMS_STATUS_CODES_LAST has the expected value and is a constant expression.
- Check that RTEMS_STATUS_CODES_LAST has the expected value.
