This test case collection provides validation test cases for requirements of the Partition Manager.
More...
| T_TEST_CASE (RtemsPartValPart) |
This test case performs the following actions:
- Create a partition with a buffer area length which is greater than three times the buffer size and less than four times the buffer size.
- Check that exactly three buffers can be obtained from the partition for use in parallel.
- Return the three buffers in use to the partition and check that they can be obtained from the partition for use in parallel in FIFO order.
- Assert that RTEMS_PARTITION_ALIGNMENT is a constant expression which evaluates to the expected value.
