RTEMS 6.1
Files | Data Structures | Typedefs | Enumerations | Functions
spec:/rtems/intr/req/handler-iterate
file  tc-intr-handler-iterate.c
struct  RtemsIntrReqHandlerIterate_Entry
struct  RtemsIntrReqHandlerIterate_Context
 Test context for spec:/rtems/intr/req/handler-iterate test case. More...
typedef RtemsIntrReqHandlerIterate_Context Context
enum  RtemsIntrReqHandlerIterate_Pre_Vector { RtemsIntrReqHandlerIterate_Pre_Vector_Valid , RtemsIntrReqHandlerIterate_Pre_Vector_Invalid , RtemsIntrReqHandlerIterate_Pre_Vector_NA }
enum  RtemsIntrReqHandlerIterate_Pre_Routine { RtemsIntrReqHandlerIterate_Pre_Routine_Valid , RtemsIntrReqHandlerIterate_Pre_Routine_Null , RtemsIntrReqHandlerIterate_Pre_Routine_NA }
enum  RtemsIntrReqHandlerIterate_Pre_Init { RtemsIntrReqHandlerIterate_Pre_Init_Yes , RtemsIntrReqHandlerIterate_Pre_Init_No , RtemsIntrReqHandlerIterate_Pre_Init_NA }
enum  RtemsIntrReqHandlerIterate_Pre_ISR { RtemsIntrReqHandlerIterate_Pre_ISR_Yes , RtemsIntrReqHandlerIterate_Pre_ISR_No , RtemsIntrReqHandlerIterate_Pre_ISR_NA }
enum  RtemsIntrReqHandlerIterate_Post_Status {
  RtemsIntrReqHandlerIterate_Post_Status_Ok , RtemsIntrReqHandlerIterate_Post_Status_InvAddr , RtemsIntrReqHandlerIterate_Post_Status_IncStat , RtemsIntrReqHandlerIterate_Post_Status_InvId ,
  RtemsIntrReqHandlerIterate_Post_Status_CalledFromISR , RtemsIntrReqHandlerIterate_Post_Status_NA
enum  RtemsIntrReqHandlerIterate_Post_Visit { RtemsIntrReqHandlerIterate_Post_Visit_Yes , RtemsIntrReqHandlerIterate_Post_Visit_Nop , RtemsIntrReqHandlerIterate_Post_Visit_NA }
 T_TEST_CASE_FIXTURE (RtemsIntrReqHandlerIterate, &RtemsIntrReqHandlerIterate_Fixture)
