Tests the basedefs macros of the Classic API.
More...
#define | WHITE_SPACE_STRING_MAX_LENGTH 80 |
#define | abccat concat |
#define | abc ABC |
#define | CON con |
#define | CAT cat |
#define | defcat concat |
#define | GLOBAL_SYMBOL_VALULE(_hex) 0x ## _hex |
#define | EXPAND expand |
#define | PREDICT_FALSE 1 - |
#define | SECTION_NAME ".rtemsroset.test" |
#define | STATIC_ASSERT_COND 0 + |
#define | STRING_PREFIX str |
#define | SYMBOL_NAME global_object |
#define | _TO_STR2(_text) #_text |
#define | _TO_STR(_text) _TO_STR2( _text ) |
| __asm__ ("\n\t.set " RTEMS_XSTRING(RTEMS_SYMBOL_NAME(address_of_global_object)) ", " RTEMS_XSTRING(RTEMS_SYMBOL_NAME(SYMBOL_NAME)) "\n") |
| RTEMS_DEFINE_GLOBAL_SYMBOL (GLOBAL_SYMBOL, RTEMS_SYMBOL_NAME(global_symbol_base)+GLOBAL_SYMBOL_VALULE(abc)) |
| RTEMS_DECLARE_GLOBAL_SYMBOL (global_symbol_2) |
| RTEMS_DEFINE_GLOBAL_SYMBOL (global_symbol_2, 0x123) |
RTEMS_INLINE_ROUTINE int | inline_routine_func (int arg) |
| RTEMS_PRINTFLIKE (2, 3) |
| RTEMS_SECTION (".rtemsrwset.test") |
int | basedefs_weak_alias_0_func (int i) RTEMS_WEAK_ALIAS(ori_func) |
int | basedefs_weak_alias_1_func (int i) RTEMS_WEAK_ALIAS(ori_func) |
RTEMS_WEAK int | basedefs_weak_0_func (void) |
RTEMS_WEAK int | basedefs_weak_1_func (void) |
| T_TEST_CASE (RtemsBasedefsValBasedefs) |
int | global_object |
int | address_of_global_object |
RTEMS_WEAK const volatile int | basedefs_weak_0_var = 60 |
RTEMS_WEAK const volatile int | basedefs_weak_1_var = 61 |
This test case performs the following actions:
- Use the RTEMS_ALIAS() macro.
- Check that ori_func() and alias_func() are the same function.
- Use the RTEMS_ALIGN_DOWN() macro in various examples.
- Use the RTEMS_ALIGN_UP() macro in various examples.
- Check that RTEMS_ALIGN_UP() calculates the expected result and is side-effect free.
- Use the RTEMS_ALIGNED() macro.
- Check that RTEMS_ALIGNED() correctly aligns a variable on the stack and a structure member.
- Use the RTEMS_ALIGNOF() macro.
- Check that the RTEMS_ALIGNOF() macro results in the alignment of the type.
- If the RTEMS_ALIGNOF() macro would evaluate its argument, it could not figure out how much menory to reserve for it.
- If the RTEMS_ALIGNOF() macro would evaluate the size expression, the division by zero would cause an error.
- Ensure the constant value of the RTEMS_ALIGNOF() macro is of type size_t.
- Use a function declared with the RTEMS_ALLOC_ALIGN() macro.
- It cannot be checked that the RTEMS_ALLOC_ALIGN() macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a memory function and that the argument counting starts at 1.
- Use a function declared with the RTEMS_ALLOC_SIZE() macro.
- It cannot be checked that the RTEMS_ALLOC_SIZE() macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a memory function and that the argument counting starts at 1.
- Use a function declared with the RTEMS_ALLOC_SIZE_2() macro.
- It cannot be checked that the RTEMS_ALLOC_SIZE_2() macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a memory function and that the argument counting starts at 1.
- Use the RTEMS_ARRAY_SIZE() macro.
- Check that the calculated size of the arrays fit their definition.
- Use the RTEMS_COMPILER_DEPRECATED_ATTRIBUTE macro.
- It cannot automatically be checked that the RTEMS_COMPILER_DEPRECATED_ATTRIBUTE macro has the desired effect. The gcc compiler should issue a warning about the use of a deprecated variable on the above line where the
compiler_deprecated_attribute is used.
- Use the RTEMS_COMPILER_MEMORY_BARRIER() macro.
- Use of the RTEMS_COMPILER_NO_RETURN_ATTRIBUTE macro at the beginning of this file.
- It cannot be checked that the RTEMS_COMPILER_NO_RETURN_ATTRIBUTE macro has the desired effect. It is only checked that such a macro exists.
- Use the RTEMS_COMPILER_PACKED_ATTRIBUTE macro.
- Check that RTEMS_COMPILER_PACKED_ATTRIBUTE correctly aligns a structure member.
- Use the RTEMS_COMPILER_PURE_ATTRIBUTE macro at the beginning of this file.
- It cannot be checked that the RTEMS_COMPILER_PURE_ATTRIBUTE macro has the desired effect. It is checked that such a macro exists.
- Use the RTEMS_COMPILER_UNUSED_ATTRIBUTE macro.
- It cannot automatically be checked that the RTEMS_COMPILER_UNUSED_ATTRIBUTE macro has the desired effect. It is checked that such a macro exists and one can manually check that no compiler warnings are produced for the compiler_unused_attribute_var.
- Invoke the RTEMS_CONCAT() macro on examples.
- Check that the two arguments of RTEMS_CONCAT() are concatenated to a new token.
- Check that the result of the RTEMS_CONCAT() expansion is subject to a further pre-processor substitution.
- Use the RTEMS_CONST macro at the beginning of this file.
- It cannot be checked that the RTEMS_CONST macro has the desired effect. It is checked that such a macro exists.
- Use the RTEMS_CONTAINER_OF() macro.
- Use the RTEMS_DECLARE_GLOBAL_SYMBOL() macro in the file tc-basedefs-pendant.h.
- Check that the RTEMS_DECLARE_GLOBAL_SYMBOL() macro declares a global symbol which can be accessed by function basedefs_get_global_symbol() which is defined in a file different from the file in which the gobal symbol is defined.
- Use the RTEMS_DECONST() macro.
- Check that the RTEMS_DECONST() macro returns a pointer which allows to write into an otherwise const value.
- Use the RTEMS_DEFINE_GLOBAL_SYMBOL() macro at the beginning of this file.
- Use a function declared with the RTEMS_DEPRECATED macro.
- It cannot automatically be checked that the RTEMS_DEPRECATED macro has the desired effect. The gcc compiler should issue a warning about the use of a deprecated function on the above line where the
deprecated_func is used.
- Use the RTEMS_DEQUALIFY_DEPTHX() macro.
- Check that the RTEMS_DEQUALIFY_DEPTHX() macro returns a pointer which allows to write into an otherwise const (volatile) value.
- Use the RTEMS_DEQUALIFY() macro.
- Check that the RTEMS_DEQUALIFY() macro returns a pointer which allows to write into an otherwise const volatile value.
- Use the RTEMS_DEVOLATILE() macro.
- Check that the RTEMS_DEVOLATILE() macro returns a pointer which allows to write into an otherwise volatile value.
- Invoke the RTEMS_EXPAND() macro on an example.
- Invoke the FALSE macro on an example.
- Check that of FALSE is substituted by 0.
- Invoke the RTEMS_HAVE_MEMBER_SAME_TYPE() macro on examples.
- Use the RTEMS_INLINE_ROUTINE in the definition of function inline_routine_func() at the beginning of this file. Obtain the text the macro RTEMS_INLINE_ROUTINE produces.
- Check that the RTEMS_INLINE_ROUTINE exists and that it produces the desired text.
- Use a function declared with the RTEMS_MALLOCLIKE macro.
- It cannot be checked that the RTEMS_MALLOCLIKE macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a memory function and that it produces the correct code.
- Use a function declared with the RTEMS_NO_INLINE macro.
- It cannot be checked that the RTEMS_NO_INLINE macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a function and that it produces the correct code.
- Use of the RTEMS_NO_RETURN macro at the beginning of this file.
- It cannot be checked that the RTEMS_NO_RETURN macro has the desired effect. It is only checked that such a macro exists.
- Use the RTEMS_NOINIT macro on
noinit_variable at the beginning of this file.
- It cannot be checked that the RTEMS_NOINIT macro has the desired effect. Yet, the check confirms that such a macro exists and can be used.
- Use the RTEMS_OBFUSCATE_VARIABLE() macro.
- It cannot be checked that the RTEMS_OBFUSCATE_VARIABLE() macro has the desired effect. Yet, the check confirms that such a macro exists and can be used.
- Use the RTEMS_PACKED macro.
- Check that RTEMS_PACKED correctly aligns a structure member.
- Check that RTEMS_PACKED correctly aligns all structure members.
- Check that RTEMS_PACKED correctly enforces a minimal enum type.
- Use the RTEMS_PREDICT_FALSE() macro.
- It cannot be checked that the RTEMS_PREDICT_FALSE() macro has the desired effect. Yet, the check confirms that such a macro exists and can be used.
- Use the RTEMS_PREDICT_TRUE() macro.
- It cannot be checked that the RTEMS_PREDICT_TRUE() macro has the desired effect. Yet, the check confirms that such a macro exists and can be used.
- Use a function declared with the RTEMS_PRINTFLIKE() macro.
- It cannot automatically be checked that the RTEMS_PRINTFLIKE() macro has the desired effect. Yet, the check confirms that such a macro exists and that it can be used on such a printf-like function and that the argument numbers are correct.
- Use the RTEMS_PURE macro at the beginning of this file.
- It cannot be checked that the RTEMS_PURE macro has the desired effect. It is checked that such a macro exists.
- Get the code the RTEMS_RETURN_ADDRESS() macro produces as string.
- Use the RTEMS_SECTION() macro on
section_variable and section_func at the beginning of this file.
- It cannot be checked that the RTEMS_SECTION() macro has the desired effect. Yet, the check confirms that such a macro exists and can be used.
- Evaluate if RTEMS_STATIC_ANALYSIS is defined.
- Check that RTEMS_STATIC_ANALYSIS was not defined.
- Use the RTEMS_STATIC_ASSERT() macro.
- It cannot be automatically check that the RTEMS_STATIC_ASSERT() macro has the desired effect. Yet, it can be checked that the macro exists and accepts the specified arguments.
- Use the RTEMS_STRING() macro.
- Check that the RTEMS_STRING() macro converts its arguments into a single string without applying pre-processor substitutions on its arguments.
- Use the RTEMS_SYMBOL_NAME() macro with an example object.
- Invoke the TRUE macro on an example.
- Check that of TRUE is substituted by 0.
- Use of the RTEMS_TYPEOF_REFX() macro on several examples. This use is already the test as the statements will not compile without error if the macro did not evaluate to the correct type.
- The checks here are proforma. The macro is tested by the fact that the action will not compile if the macro returns a wrong result.
- Use the RTEMS_UNUSED macro. See also unused_func() at the beginning of this file.
- It cannot automatically be checked that the RTEMS_UNUSED macro has the desired effect. It is checked that such a macro exists and one can manually check that no compiler warnings are produced for the unused_func().
- It cannot automatically be checked that the RTEMS_UNUSED macro has the desired effect. It is checked that such a macro exists and one can manually check that no compiler warnings are produced for the unused_lable.
- It cannot automatically be checked that the RTEMS_UNUSED macro has the desired effect. It is checked that such a macro exists and one can manually check that no compiler warnings are produced for the unused_struct.
- It cannot automatically be checked that the RTEMS_UNUSED macro has the desired effect. It is checked that such a macro exists and one can manually check that no compiler warnings are produced for the unused items unused_var and the unused argument and variable in unused_func().
- Use of the RTEMS_UNREACHABLE() macro in function definition of unreachable_func() at the beginning of this file.
- It cannot be checked that the RTEMS_UNREACHABLE() macro has the desired effect. It is checked that such a macro exists and the compiler warning about the missing return statement is suppressed.
- Use of the RTEMS_USED macro in function definition of used_func() at the beginning of this file and with used_var above.
- It cannot be checked that the RTEMS_USED macro has the desired effect. It is checked that such a macro exists.
- Use of the RTEMS_WARN_UNUSED_RESULT macro in function definition of warn_unused_func() at the beginning of this file.
- It cannot be checked that the RTEMS_WARN_UNUSED_RESULT macro has the desired effect. The GNU C compiler should issue a warning about the disregarded result returned by the call to the
warn_unused_func() function.
- Use of
basedefs_weak_alias_0/1_func() which are defined with the RTEMS_WEAK_ALIAS() macro at the beginning of this file.
- There exists no strong alias for basedefs_weak_alias_0_func(). Check that ori_func() and basedefs_weak_alias_0_func() are the same function.
- File
tc_basedefs_pndant.c defines a strong function for basedefs_weak_alias_1_func(). Check that ori_func() and basedefs_weak_alias_1_func() are not the same function.
- Use of
basedefs_weak_0/1_var and basedefs_weak_0/1_func() which are defined with the RTEMS_WEAK macro at the beginning of this file.
- For
basedefs_weak_0_var and basedefs_weak_0_func() there exists no other symbols with the same name. Hence, the checks test that the weak symbols are used.
basedefs_weak_1_var and basedefs_weak_1_func() are overwritten by strong symbols defined in file tc_basedefs_pendant.c. Hence, the checks test that the strong variants are used.
- Invoke the RTEMS_XCONCAT() macro on examples.
- Check that the two arguments of RTEMS_XCONCAT() are concatenated without inserting new characters.
- Check that the two arguments of RTEMS_XCONCAT() are substituted before they are concatenated.
- Check that the two arguments of RTEMS_XCONCAT() are can be the macro itself.
- Check that the result of the RTEMS_XCONCAT() expansion is subject to a further pre-processor substitution.
- Use the RTEMS_XSTRING() macro.
- Check that the RTEMS_XSTRING() macro applies pre-processor substitutions on its arguments and converts its arguments into a single string.
- Use of the RTEMS_ZERO_LENGTH_ARRAY macro in a declaration of a structure.
- Checked that the RTEMS_ZERO_LENGTH_ARRAY macro produces a structure similar to a structure with one element.
- Use the RTEMS_DEFINE_GLOBAL_SYMBOL() macro at the beginning of this file and assign the address of the symbol to an object.
