| | APB address area (APBAREA) |
| | This group contains register bit definitions.
| | Capability (CAP) |
| | Configuration port write enable (CFGWE) |
| | Credit counter, SpaceWire ports (CREDCNT) |
| | General purpose in, bits 0-31, 32-63, 64-95, and 96-127 (GPI) |
| | General purpose out, bits 0-31, 32-63, 64-95, and 96-127 (GPO) |
| | Initialization divisor (IDIV) |
| | Interrupt code distribution ACK-to-INT timer reload (AITIMER) |
| | Interrupt code distribution ISR change timer reload (ISRCTIMER) |
| | Interrupt code distribution ISR register, interrupt 0-31 (ISR0) |
| | Interrupt code distribution ISR register, interrupt 32-63 (ISR1) |
| | Interrupt code distribution ISR timer reload (ISRTIMER) |
| | Interrupt code generation (ICODEGEN) |
| | Interrupt mask (IMASK) |
| | Interrupt port mask (IPMASK) |
| | Link running status (LRUNSTAT) |
| | Maximum packet length, ports > 0 (MAXPLEN) |
| | Port control 2, port 0 (configuration port) (PCTRL2CFG) |
| | Port control 2, ports > 0 (PCTRL2) |
| | Port control, port 0 (configuration port) (PCTRLCFG) |
| | Port control, ports > 0 (PCTRL) |
| | Port interrupt pending (PIP) |
| | Port status, port 0 (configuration port) (PSTSCFG) |
| | Port status, ports > 0 (PSTS) |
| | Port timer reload (PTIMER) |
| | Router configuration / status (RTRCFG) |
| | Routing table address control, addresses 1-31 and 32-255 (RTACTRL) |
| | Routing table port mapping, addresses 1-31 and 32-255 (RTPMAP) |
| | Routing table, combined port mapping and address control, addresses 1-255 (RTCOMB) |
| | SpaceWire Plug-and-Play - Device Vendor and Product ID (PNPVEND) |
| | SpaceWire Plug-and-Play - Port network discovery enable (PNPNETDISC) |
| | SpaceWire Plug-and-Play - Unit Serial Number (PNPUSN) |
| | SpaceWire Plug-and-Play - Unit Vendor and Product ID (PNPUVEND) |
| | SpaceWire Router Port Statistics |
| | This group contains the SpaceWire Router Port Statistics interfaces.
| | Time-code (TC) |
| | Timer prescaler reload (PRESCALER) |
| | Version / instance ID (VER) |
This group contains the SpaceWire Router interfaces.
