RTEMS 6.1
Modules | Files | Data Structures | Typedefs
This group contains the L4STAT interfaces. More...
 Counter 0-15 control register (CCTRL)
 This group contains register bit definitions.
 Counter 0-15 max/latch register (CSVAL)
 Counter 0-15 value register (CVAL)
 Timestamp register (TSTAMP)
file  l4stat-regs.h
 This header file defines the L4STAT register block interface.
struct  l4stat
 This structure defines the L4STAT register block memory map. More...
typedef struct l4stat l4stat
