RTEMS 6.1
Modules | Files | Data Structures | Typedefs
This group contains the GPTIMER interfaces. More...
 Configuration register (CONFIG)
 This group contains register bit definitions.
 GPTIMER TIMER
 This group contains the GPTIMER TIMER interfaces.
 Scaler reload value register (SRELOAD)
 Scaler value register (SCALER)
 Timer latch configuration register (LATCHCFG)
file  gptimer-regs.h
 This header file defines the GPTIMER register block interface.
struct  gptimer
 This structure defines the GPTIMER register block memory map. More...
typedef struct gptimer gptimer
