RTEMS 6.1
Modules | Files | Data Structures | Typedefs
This group contains the AHBTRACE interfaces. More...
 Trace buffer break address registers (TBBA)
 This group contains register bit definitions.
 Trace buffer break mask registers (TBBM)
 Trace buffer control register (CTRL)
 Trace buffer index register (INDEX)
 Trace buffer master/slave filter register (MSFILT)
 Trace buffer time tag register (TIMETAG)
file  ahbtrace-regs.h
 This header file defines the AHBTRACE register block interface.
struct  ahbtrace
 This structure defines the AHBTRACE register block memory map. More...
typedef struct ahbtrace ahbtrace
