RTEMS 6.1
Modules | Files | Data Structures | Typedefs
GRCLKGATE
This group contains the GRCLKGATE interfaces. More...
 CPU/FPU override register (OVERRIDE)
 This group contains register bit definitions.
 Clock enable register (CLKEN)
 Reset register (RESET)
 Unlock register (UNLOCK)
file  grclkgate-regs.h
 This header file defines the GRCLKGATE register block interface.
struct  grclkgate
 This structure defines the GRCLKGATE register block memory map. More...
typedef struct grclkgate grclkgate
