#define | _IO_BASE PREP_ISA_IO_BASE |
#define | _ISA_MEM_BASE PREP_ISA_MEM_BASE |
#define | PCI_DRAM_OFFSET PREP_PCI_DRAM_OFFSET |
#define | PCI_MEM_BASE PREP_ISA_MEM_BASE |
#define | PCI_MEM_WIN0 0 |
#define | BSP_HAS_PC_PCI |
#define | RTEMS_BSP_PCI_IO_REGION_BASE 0 |
#define | RTEMS_BSP_PCI_MEM_REGION_BASE PCI_DRAM_OFFSET |
#define | RTEMS_BSP_ADDR_PTR(_type) uint ## _type ## _t __volatile* |
#define | RTEMS_BSP_ADDR_CPTR(_type) const RTEMS_BSP_ADDR_PTR(_type) |
#define | RTEMS_BSP_ADDRESS_READ(_addr, _type) *((RTEMS_BSP_ADDR_CPTR(_type)) (((RTEMS_BSP_ADDR_CPTR(8)) _addr) + PCI_DRAM_OFFSET)) |
#define | RTEMS_BSP_ADDRESS_WRITE(_addr, _val, _type) *((RTEMS_BSP_ADDR_PTR(_type)) (((RTEMS_BSP_ADDR_PTR(8)) _addr) + PCI_DRAM_OFFSET)) = (_val) |
#define | RTEMS_BSP_READ_1(_addr) RTEMS_BSP_ADDRESS_READ(_addr, 8) |
#define | RTEMS_BSP_READ_2(_addr) RTEMS_BSP_ADDRESS_READ(_addr, 16) |
#define | RTEMS_BSP_READ_4(_addr) RTEMS_BSP_ADDRESS_READ(_addr, 32) |
#define | RTEMS_BSP_READ_8(_addr) RTEMS_BSP_ADDRESS_READ(_addr, 64) |
#define | RTEMS_BSP_WRITE_1(_addr, _val) RTEMS_BSP_ADDRESS_WRITE(_addr, _val, 8) |
#define | RTEMS_BSP_WRITE_2(_addr, _val) RTEMS_BSP_ADDRESS_WRITE(_addr, _val, 16) |
#define | RTEMS_BSP_WRITE_4(_addr, _val) RTEMS_BSP_ADDRESS_WRITE(_addr, _val, 32) |
#define | RTEMS_BSP_WRITE_8(_addr, _val) RTEMS_BSP_ADDRESS_WRITE(_addr, _val, 64) |
#define | BSP_UART_IOBASE_COM1 ((_IO_BASE)+0x3f8) |
#define | BSP_UART_IOBASE_COM2 ((_IO_BASE)+0x2f8) |
#define | BSP_KBD_IOBASE ((_IO_BASE)+0x60) |
#define | BSP_VGA_IOBASE ((_IO_BASE)+0x3c0) |
#define | BSP_CONSOLE_PORT BSP_UART_COM1 |
#define | BSP_UART_BAUD_BASE 115200 |
#define | BSP_PIC_DO_EOI openpic_eoi(0) |
#define | outport_byte(port, value) outb(value,port) |
#define | outport_word(port, value) outw(value,port) |
#define | outport_long(port, value) outl(value,port) |
#define | inport_byte(port, value) (value = inb(port)) |
#define | inport_word(port, value) (value = inw(port)) |
#define | inport_long(port, value) (value = inl(port)) |
#define | BSP_Convert_decrementer(_value) ((unsigned long long) ((((unsigned long long)BSP_time_base_divisor) * 1000000ULL) /((unsigned long long) BSP_bus_frequency)) * ((unsigned long long) (_value))) |
Motorola Board Support Package.
