#define | __ADC_ENABLE __HAL_ADC_ENABLE |
#define | __ADC_DISABLE __HAL_ADC_DISABLE |
#define | __HAL_ADC_ENABLING_CONDITIONS ADC_ENABLING_CONDITIONS |
#define | __HAL_ADC_DISABLING_CONDITIONS ADC_DISABLING_CONDITIONS |
#define | __HAL_ADC_IS_ENABLED ADC_IS_ENABLE |
#define | __ADC_IS_ENABLED ADC_IS_ENABLE |
#define | __HAL_ADC_IS_SOFTWARE_START_REGULAR ADC_IS_SOFTWARE_START_REGULAR |
#define | __HAL_ADC_IS_SOFTWARE_START_INJECTED ADC_IS_SOFTWARE_START_INJECTED |
#define | __HAL_ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED ADC_IS_CONVERSION_ONGOING_REGULAR_INJECTED |
#define | __HAL_ADC_IS_CONVERSION_ONGOING_REGULAR ADC_IS_CONVERSION_ONGOING_REGULAR |
#define | __HAL_ADC_IS_CONVERSION_ONGOING_INJECTED ADC_IS_CONVERSION_ONGOING_INJECTED |
#define | __HAL_ADC_IS_CONVERSION_ONGOING ADC_IS_CONVERSION_ONGOING |
#define | __HAL_ADC_CLEAR_ERRORCODE ADC_CLEAR_ERRORCODE |
#define | __HAL_ADC_GET_RESOLUTION ADC_GET_RESOLUTION |
#define | __HAL_ADC_JSQR_RK ADC_JSQR_RK |
#define | __HAL_ADC_CFGR_AWD1CH ADC_CFGR_AWD1CH_SHIFT |
#define | __HAL_ADC_CFGR_AWD23CR ADC_CFGR_AWD23CR |
#define | __HAL_ADC_CFGR_INJECT_AUTO_CONVERSION ADC_CFGR_INJECT_AUTO_CONVERSION |
#define | __HAL_ADC_CFGR_INJECT_CONTEXT_QUEUE ADC_CFGR_INJECT_CONTEXT_QUEUE |
#define | __HAL_ADC_CFGR_INJECT_DISCCONTINUOUS ADC_CFGR_INJECT_DISCCONTINUOUS |
#define | __HAL_ADC_CFGR_REG_DISCCONTINUOUS ADC_CFGR_REG_DISCCONTINUOUS |
#define | __HAL_ADC_CFGR_DISCONTINUOUS_NUM ADC_CFGR_DISCONTINUOUS_NUM |
#define | __HAL_ADC_CFGR_AUTOWAIT ADC_CFGR_AUTOWAIT |
#define | __HAL_ADC_CFGR_CONTINUOUS ADC_CFGR_CONTINUOUS |
#define | __HAL_ADC_CFGR_OVERRUN ADC_CFGR_OVERRUN |
#define | __HAL_ADC_CFGR_DMACONTREQ ADC_CFGR_DMACONTREQ |
#define | __HAL_ADC_CFGR_EXTSEL ADC_CFGR_EXTSEL_SET |
#define | __HAL_ADC_JSQR_JEXTSEL ADC_JSQR_JEXTSEL_SET |
#define | __HAL_ADC_OFR_CHANNEL ADC_OFR_CHANNEL |
#define | __HAL_ADC_DIFSEL_CHANNEL ADC_DIFSEL_CHANNEL |
#define | __HAL_ADC_CALFACT_DIFF_SET ADC_CALFACT_DIFF_SET |
#define | __HAL_ADC_CALFACT_DIFF_GET ADC_CALFACT_DIFF_GET |
#define | __HAL_ADC_TRX_HIGHTHRESHOLD ADC_TRX_HIGHTHRESHOLD |
#define | __HAL_ADC_OFFSET_SHIFT_RESOLUTION ADC_OFFSET_SHIFT_RESOLUTION |
#define | __HAL_ADC_AWD1THRESHOLD_SHIFT_RESOLUTION ADC_AWD1THRESHOLD_SHIFT_RESOLUTION |
#define | __HAL_ADC_AWD23THRESHOLD_SHIFT_RESOLUTION ADC_AWD23THRESHOLD_SHIFT_RESOLUTION |
#define | __HAL_ADC_COMMON_REGISTER ADC_COMMON_REGISTER |
#define | __HAL_ADC_COMMON_CCR_MULTI ADC_COMMON_CCR_MULTI |
#define | __HAL_ADC_MULTIMODE_IS_ENABLED ADC_MULTIMODE_IS_ENABLE |
#define | __ADC_MULTIMODE_IS_ENABLED ADC_MULTIMODE_IS_ENABLE |
#define | __HAL_ADC_NONMULTIMODE_OR_MULTIMODEMASTER ADC_NONMULTIMODE_OR_MULTIMODEMASTER |
#define | __HAL_ADC_COMMON_ADC_OTHER ADC_COMMON_ADC_OTHER |
#define | __HAL_ADC_MULTI_SLAVE ADC_MULTI_SLAVE |
#define | __HAL_ADC_SQR1_L ADC_SQR1_L_SHIFT |
#define | __HAL_ADC_JSQR_JL ADC_JSQR_JL_SHIFT |
#define | __HAL_ADC_JSQR_RK_JL ADC_JSQR_RK_JL |
#define | __HAL_ADC_CR1_DISCONTINUOUS_NUM ADC_CR1_DISCONTINUOUS_NUM |
#define | __HAL_ADC_CR1_SCAN ADC_CR1_SCAN_SET |
#define | __HAL_ADC_CONVCYCLES_MAX_RANGE ADC_CONVCYCLES_MAX_RANGE |
#define | __HAL_ADC_CLOCK_PRESCALER_RANGE ADC_CLOCK_PRESCALER_RANGE |
#define | __HAL_ADC_GET_CLOCK_PRESCALER ADC_GET_CLOCK_PRESCALER |
#define | __HAL_ADC_SQR1 ADC_SQR1 |
#define | __HAL_ADC_SMPR1 ADC_SMPR1 |
#define | __HAL_ADC_SMPR2 ADC_SMPR2 |
#define | __HAL_ADC_SQR3_RK ADC_SQR3_RK |
#define | __HAL_ADC_SQR2_RK ADC_SQR2_RK |
#define | __HAL_ADC_SQR1_RK ADC_SQR1_RK |
#define | __HAL_ADC_CR2_CONTINUOUS ADC_CR2_CONTINUOUS |
#define | __HAL_ADC_CR1_DISCONTINUOUS ADC_CR1_DISCONTINUOUS |
#define | __HAL_ADC_CR1_SCANCONV ADC_CR1_SCANCONV |
#define | __HAL_ADC_CR2_EOCSelection ADC_CR2_EOCSelection |
#define | __HAL_ADC_CR2_DMAContReq ADC_CR2_DMAContReq |
#define | __HAL_ADC_JSQR ADC_JSQR |
#define | __HAL_ADC_CHSELR_CHANNEL ADC_CHSELR_CHANNEL |
#define | __HAL_ADC_CFGR1_REG_DISCCONTINUOUS ADC_CFGR1_REG_DISCCONTINUOUS |
#define | __HAL_ADC_CFGR1_AUTOOFF ADC_CFGR1_AUTOOFF |
#define | __HAL_ADC_CFGR1_AUTOWAIT ADC_CFGR1_AUTOWAIT |
#define | __HAL_ADC_CFGR1_CONTINUOUS ADC_CFGR1_CONTINUOUS |
#define | __HAL_ADC_CFGR1_OVERRUN ADC_CFGR1_OVERRUN |
#define | __HAL_ADC_CFGR1_SCANDIR ADC_CFGR1_SCANDIR |
#define | __HAL_ADC_CFGR1_DMACONTREQ ADC_CFGR1_DMACONTREQ |
