Tests the default values of application configuration options where all optional BSP provided settings are disabled.
More...
| T_TEST_CASE (AcfgValDisabledBspSettings) |
This test case performs the following actions:
- Check the effect of application configuration options with optional BSP-provided settings.
- Check the default value CONFIGURE_IDLE_TASK_BODY where the optional BSP-provided default value is disabled.
- Check the default value CONFIGURE_IDLE_TASK_STACK_SIZE where the optional BSP-provided default value is disabled.
- Check the default value CONFIGURE_INTERRUPT_STACK_SIZE where the optional BSP-provided default value is disabled.
- Check the BSP-provided initial extension is not registered.
