RTEMS 6.1
gr_rasta_spw_router.h
2
3/* GR-RASTA-SPW-ROUTER PCI Peripheral driver
4 *
5 * COPYRIGHT (c) 2015.
6 * Cobham Gaisler.
7 *
8 * Redistribution and use in source and binary forms, with or without
9 * modification, are permitted provided that the following conditions
10 * are met:
11 * 1. Redistributions of source code must retain the above copyright
12 * notice, this list of conditions and the following disclaimer.
13 * 2. Redistributions in binary form must reproduce the above copyright
14 * notice, this list of conditions and the following disclaimer in the
15 * documentation and/or other materials provided with the distribution.
16 *
17 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
18 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
19 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
20 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
21 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
22 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
23 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
24 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
25 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
26 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
27 * POSSIBILITY OF SUCH DAMAGE.
28 *
29 */
30
31#ifndef __GR_RASTA_SPW_ROUTER_H__
32#define __GR_RASTA_SPW_ROUTER_H__
33
34#include <drvmgr/drvmgr.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif
39
40/* An array of pointers to GR-RASTA-SPW-ROUTER resources. The resources will be
41 * used by the drivers controlling the cores on the GR-RASTA-SPW-ROUTER target
42 * AMBA bus.
43 *
44 * The gr_rasta_spw_router_resources is declared weak so that the user can
45 * override the default configuration. The array must be terminated with a
46 * NULL resource.
47 */
48extern struct drvmgr_bus_res *gr_rasta_spw_router_resources[];
49
50/* Options to gr_rasta_spw_router_print function */
51#define RASTA_SPW_ROUTER_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
52#define RASTA_SPW_ROUTER_OPTIONS_IRQ 0x02 /* Print current IRQ setup */
53
54/* Print information about all GR-CPCI-LEON4-N2X PCI boards */
55void gr_rasta_spw_router_print(int options);
56
57/* Print information about one GR-CPCI-LEON4-N2X PCI board */
58void gr_rasta_spw_router_print_dev(struct drvmgr_dev *dev, int options);
59
60/* Register GR-RASTA-SPW-ROUTER driver to Driver Manager */
61void gr_rasta_spw_router_register_drv(void);
62
63#ifdef __cplusplus
64}
65#endif
66
67#endif
Driver Manager Interface.
Definition: drvmgr.h:238
Definition: drvmgr.h:297
