RTEMS 6.1
gr_leon4_n2x.h
2
12/*
13 * COPYRIGHT (c) 2013.
14 * Cobham Gaisler AB.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 *
37 * Configures the GR-CPIC-LEON4-N2X interface PCI board in peripheral
38 * mode. This driver provides a AMBA PnP bus by using the general part
39 * of the AMBA PnP bus driver (ambapp_bus.c).
40 *
41 *
42 * Driver resource options:
43 * NAME DEFAULT VALUE
44 * ahbmst2pci _RAM_START AMBA->PCI translation PCI base address
45 * ambaFreq 200000000 (200MHz) AMBA system frequency of LEON4-N2X
46 * cgEnMask 0x1f (all) Clock gating enable mask
47 *
48 * TODO/UNTESTED
49 * Interrupt testing
50 * bar0 RESOURCE 0x00000000 L2-Cache SDRAM memory
51 * bar1 RESOURCE 0xf0000000 L2-Cache registers
52 */
53
54#ifndef __GR_CPCI_LEON4_N2X_H__
55#define __GR_CPCI_LEON4_N2X_H__
56
57#include <drvmgr/drvmgr.h>
58
59#ifdef __cplusplus
60extern "C" {
61#endif
62
63/* An array of pointers to GR-CPCI-LEON4-N2X resources. The resources will be
64 * used by the drivers controlling the cores on the GR-CPCI-LEON4-N2X target
65 * AMBA bus.
66 *
67 * The gr_leon4_n2x_resources is declared weak so that the user can override the
68 * default configuration. The array must be terminated with a NULL resource.
69 */
70extern struct drvmgr_bus_res *gr_leon4_n2x_resources[];
71
72/* Options to gr_cpci_leon4_n2x_print function */
73#define GR_LEON4_N2X_OPTIONS_AMBA 0x01 /* Print AMBA bus devices */
74
75/* Print information about all GR-CPCI-LEON4-N2X PCI boards */
76void gr_leon4_n2x_print(int options);
77
78/* Print information about one GR-CPCI-LEON4-N2X PCI board */
79void gr_cpci_leon4_n2x_print_dev(struct drvmgr_dev *dev, int options);
80
81/* Register GR-CPCI-LEON4-N2X driver */
82void gr_cpci_leon4_n2x_register_drv(void);
83
84#ifdef __cplusplus
85}
86#endif
87
88#endif
Driver Manager Interface.
Definition: drvmgr.h:238
Definition: drvmgr.h:297
