RTEMS 6.1
This header file defines the GR740 Boostrap Signals register block interface. More...
#include <stdint.h>Go to the source code of this file.
| struct | gr740_bootstrap |
| This structure defines the GR740 Bootstrap Signals register block memory map. More... | |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B10 0x2000000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B9 0x1000000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B8 0x800000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B7 0x400000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B6 0x200000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B5 0x100000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B4 0x80000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B3 0x40000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B2 0x20000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_B1 0x10000U |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_GPIO_SHIFT 0 |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_GPIO_MASK 0xffffU |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_GPIO_GET(_reg) |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_GPIO_SET(_reg, _val) |
| #define | GR740_BOOTSTRAP_BOOTSTRAP_GPIO(_val) |
Typedefs | |
| typedef struct gr740_bootstrap | gr740_bootstrap |
| This structure defines the GR740 Bootstrap Signals register block memory map. | |
