RTEMS 6.1
ftpd.h
2
9/*
10 * Copyright (C) 1999 Jake Janovetz <jvanovetz@uiuc.edu>
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef _RTEMS_FTPD_H
35#define _RTEMS_FTPD_H
36
37#include <rtems.h>
38
39#ifdef __cplusplus
40extern "C" {
41#endif
42
43#define FTPD_CONTROL_PORT 21
44
45/* Various buffer sizes */
46enum {
47 FTPD_BUFSIZE = 256, /* Size for temporary buffers */
48 FTPD_DATASIZE = 4 * 1024, /* Size for file transfer buffers */
49 FTPD_STACKSIZE = RTEMS_MINIMUM_STACK_SIZE + FTPD_DATASIZE /* Tasks stack size */
50};
51
52/* FTPD access control flags */
53enum
54{
55 FTPD_NO_WRITE = 0x1,
56 FTPD_NO_READ = 0x2,
57 FTPD_NO_RW = FTPD_NO_WRITE | FTPD_NO_READ
58};
59
60typedef int (*rtems_ftpd_hookfunction)(char *, size_t);
61
62#include <rtems/shell.h>
63
65{
66 char *filename;
67 rtems_ftpd_hookfunction hook_function;
68};
69
71{
72 rtems_task_priority priority; /* FTPD task priority */
73 unsigned long max_hook_filesize; /* Maximum buffersize */
74 /* for hooks */
75 int port; /* Well-known port */
76 struct rtems_ftpd_hook *hooks; /* List of hooks */
77 char const *root; /* Root for FTPD or 0 for / */
78 int tasks_count; /* Max. connections */
79 int idle; /* Idle timeout in seoconds
80 or 0 for no (inf) timeout */
81 int access; /* 0 - r/w, 1 - read-only,
82 2 - write-only,
83 3 - browse-only */
84 rtems_shell_login_check_t login; /* Login check or 0 to ignore
85 user/passwd. */
86 bool verbose; /* Say hello! */
87};
88
89rtems_status_code rtems_ftpd_start(
91);
92
94
95rtems_status_code rtems_initialize_ftpd(void);
96
97#ifdef __cplusplus
98}
99#endif
100
101#endif /* _RTEMS_FTPD_H */
rtems_status_code
Definition: status.h:85
#define RTEMS_MINIMUM_STACK_SIZE
This compile time constant provides the minimum task stack size recommended for the target architectu...
Definition: tasks.h:331
uint32_t rtems_task_priority
This integer type represents task priorities of the Classic API.
Definition: types.h:257
Instantatiate a New Terminal Shell.
Definition: deflate.c:114
Definition: ftpd.h:71
Definition: ftpd.h:65
