RTEMS 6.1
fsl_flexio_uart_dma.h
1/*
2 * Copyright (c) 2015, Freescale Semiconductor, Inc.
3 * Copyright 2016-2020 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_FLEXIO_UART_DMA_H_
9#define _FSL_FLEXIO_UART_DMA_H_
10
11#include "fsl_flexio_uart.h"
12#include "fsl_dma.h"
13
19/*******************************************************************************
20 * Definitions
21 ******************************************************************************/
22
26#define FSL_FLEXIO_UART_DMA_DRIVER_VERSION (MAKE_VERSION(2, 4, 0))
29/* Forward declaration of the handle typedef. */
31
35 status_t status,
36 void *userData);
37
42{
44 void *userData;
49 dma_handle_t *txDmaHandle;
50 dma_handle_t *rxDmaHandle;
52 volatile uint8_t txState;
53 volatile uint8_t rxState;
54};
55
56/*******************************************************************************
57 * API
58 ******************************************************************************/
59
60#if defined(__cplusplus)
61extern "C" {
62#endif
63
84 void *userData,
85 dma_handle_t *txDmaHandle,
86 dma_handle_t *rxDmaHandle);
87
103
119
129
139
152
166 size_t *count);
167
170#if defined(__cplusplus)
171}
172#endif
173
176#endif /* _FSL_UART_DMA_H_ */
Definition: fsl_flexio_uart_dma.h:52
void FLEXIO_UART_TransferAbortSendDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle)
Aborts the sent data which using DMA.
dma_handle_t * rxDmaHandle
Definition: fsl_flexio_uart_dma.h:50
status_t FLEXIO_UART_TransferReceiveDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_transfer_t *xfer)
Receives data using DMA.
size_t rxDataSizeAll
Definition: fsl_flexio_uart_dma.h:47
dma_handle_t * txDmaHandle
Definition: fsl_flexio_uart_dma.h:49
void * userData
Definition: fsl_flexio_uart_dma.h:44
status_t FLEXIO_UART_TransferSendDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_transfer_t *xfer)
Sends data using DMA.
status_t FLEXIO_UART_TransferGetSendCountDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, size_t *count)
Gets the number of bytes sent out.
void FLEXIO_UART_TransferAbortReceiveDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle)
Aborts the receive data which using DMA.
Definition: fsl_flexio_uart_dma.h:53
status_t FLEXIO_UART_TransferGetReceiveCountDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, size_t *count)
Gets the number of bytes received.
flexio_uart_dma_transfer_callback_t callback
Definition: fsl_flexio_uart_dma.h:43
void(* flexio_uart_dma_transfer_callback_t)(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, status_t status, void *userData)
UART transfer callback function.
Definition: fsl_flexio_uart_dma.h:33
status_t FLEXIO_UART_TransferCreateHandleDMA(FLEXIO_UART_Type *base, flexio_uart_dma_handle_t *handle, flexio_uart_dma_transfer_callback_t callback, void *userData, dma_handle_t *txDmaHandle, dma_handle_t *rxDmaHandle)
Initializes the FLEXIO_UART handle which is used in transactional functions.
size_t txDataSizeAll
Definition: fsl_flexio_uart_dma.h:46
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
UART DMA handle.
Definition: fsl_flexio_uart_dma.h:42
Define FlexIO UART transfer structure.
Definition: fsl_flexio_uart.h:99
Define FlexIO UART access structure typedef.
Definition: fsl_flexio_uart.h:76
