RTEMS 6.1
fsl_flexio.h
1/*
2 * Copyright (c) 2015, Freescale Semiconductor, Inc.
3 * Copyright 2016-2020, 2022 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_FLEXIO_H_
9#define _FSL_FLEXIO_H_
10
11#include "fsl_common.h"
12
18/*******************************************************************************
19 * Definitions
20 ******************************************************************************/
21
25#define FSL_FLEXIO_DRIVER_VERSION (MAKE_VERSION(2, 1, 0))
29#define FLEXIO_TIMER_TRIGGER_SEL_PININPUT(x) ((uint32_t)(x) << 1U)
30#define FLEXIO_TIMER_TRIGGER_SEL_SHIFTnSTAT(x) (((uint32_t)(x) << 2U) | 0x1U)
31#define FLEXIO_TIMER_TRIGGER_SEL_TIMn(x) (((uint32_t)(x) << 2U) | 0x3U)
32
35{
39
42{
46
49{
55
58{
62
65{
71
74{
82
85{
94#if (defined(FSL_FEATURE_FLEXIO_TIMCFG_TIMDCE_FIELD_WIDTH) && (FSL_FEATURE_FLEXIO_TIMCFG_TIMDCE_FIELD_WIDTH == 3))
95 ,
96 kFLEXIO_TimerDecSrcDiv16OnFlexIOClockShiftTimerOutput,
98 kFLEXIO_TimerDecSrcDiv256OnFlexIOClockShiftTimerOutput,
100 kFLEXIO_TimerRisSrcOnPinInputShiftPinInput,
102 kFLEXIO_TimerRisSrcOnTriggerInputShiftTriggerInput
104#endif /* FSL_FEATURE_FLEXIO_TIMCFG_TIMDCE_FIELD_WIDTH */
106
109{
118
121{
131
134{
144
147{
154
157{
161
164{
168
171{
175
178{
184#if FSL_FEATURE_FLEXIO_HAS_STATE_MODE
185 kFLEXIO_ShifterModeState = 0x6U,
187#endif /* FSL_FEATURE_FLEXIO_HAS_STATE_MODE */
188#if FSL_FEATURE_FLEXIO_HAS_LOGIC_MODE
189 kFLEXIO_ShifterModeLogic = 0x7U,
191#endif /* FSL_FEATURE_FLEXIO_HAS_LOGIC_MODE */
193
196{
200
203{
208
211{
219
222{
227#if defined(FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_NIBBLE_BYTE_SWAP) && FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_NIBBLE_BYTE_SWAP
228 kFLEXIO_ShifterBufferNibbleByteSwapped = 0x4U,
229#endif /*FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_NIBBLE_BYTE_SWAP*/
230#if defined(FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_HALF_WORD_SWAP) && FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_HALF_WORD_SWAP
231 kFLEXIO_ShifterBufferHalfWordSwapped = 0x5U,
232#endif
233#if defined(FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_NIBBLE_SWAP) && FSL_FEATURE_FLEXIO_HAS_SHFT_BUFFER_NIBBLE_SWAP
234 kFLEXIO_ShifterBufferNibbleSwapped = 0x6U,
235#endif
237
239typedef struct _flexio_config_
240{
247
250{
251 /* Trigger. */
252 uint32_t triggerSelect;
255 /* Pin. */
257 uint32_t pinSelect;
259 /* Timer. */
273 uint32_t timerCompare;
275
278{
279 /* Timer. */
280 uint32_t timerSelect;
283 /* Pin. */
285 uint32_t pinSelect;
287 /* Shifter. */
289#if FSL_FEATURE_FLEXIO_HAS_PARALLEL_WIDTH
290 uint32_t parallelWidth;
291#endif /* FSL_FEATURE_FLEXIO_HAS_PARALLEL_WIDTH */
296
298typedef void (*flexio_isr_t)(void *base, void *handle);
299
300/*******************************************************************************
301 * Variables
302 ******************************************************************************/
304extern FLEXIO_Type *const s_flexioBases[];
305
306#if !(defined(FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL) && FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL)
308extern const clock_ip_name_t s_flexioClocks[];
309#endif /* FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL */
310/*******************************************************************************
311 * API
312 ******************************************************************************/
313
314#if defined(__cplusplus)
315extern "C" {
316#endif /*_cplusplus*/
317
336
355void FLEXIO_Init(FLEXIO_Type *base, const flexio_config_t *userConfig);
356
364void FLEXIO_Deinit(FLEXIO_Type *base);
365
371uint32_t FLEXIO_GetInstance(FLEXIO_Type *base);
372
373/* @} */
374
385void FLEXIO_Reset(FLEXIO_Type *base);
386
393static inline void FLEXIO_Enable(FLEXIO_Type *base, bool enable)
394{
395 if (enable)
396 {
397 base->CTRL |= FLEXIO_CTRL_FLEXEN_MASK;
398 }
399 else
400 {
401 base->CTRL &= ~FLEXIO_CTRL_FLEXEN_MASK;
402 }
403}
404
405#if defined(FSL_FEATURE_FLEXIO_HAS_PIN_STATUS) && FSL_FEATURE_FLEXIO_HAS_PIN_STATUS
412static inline uint32_t FLEXIO_ReadPinInput(FLEXIO_Type *base)
413{
414 return base->PIN;
415}
416#endif /*FSL_FEATURE_FLEXIO_HAS_PIN_STATUS*/
417
418#if defined(FSL_FEATURE_FLEXIO_HAS_STATE_MODE) && FSL_FEATURE_FLEXIO_HAS_STATE_MODE
425static inline uint8_t FLEXIO_GetShifterState(FLEXIO_Type *base)
426{
427 return ((uint8_t)(base->SHIFTSTATE) & FLEXIO_SHIFTSTATE_STATE_MASK);
428}
429#endif /*FSL_FEATURE_FLEXIO_HAS_STATE_MODE*/
430
456void FLEXIO_SetShifterConfig(FLEXIO_Type *base, uint8_t index, const flexio_shifter_config_t *shifterConfig);
487void FLEXIO_SetTimerConfig(FLEXIO_Type *base, uint8_t index, const flexio_timer_config_t *timerConfig);
488
495static inline void FLEXIO_SetClockMode(FLEXIO_Type *base, uint8_t index, flexio_timer_decrement_source_t clocksource)
496{
497 uint32_t reg = base->TIMCFG[index];
498
499 reg &= ~FLEXIO_TIMCFG_TIMDEC_MASK;
500
501 reg |= FLEXIO_TIMCFG_TIMDEC(clocksource);
502
503 base->TIMCFG[index] = reg;
504}
505
506/* @} */
507
521static inline void FLEXIO_EnableShifterStatusInterrupts(FLEXIO_Type *base, uint32_t mask)
522{
523 base->SHIFTSIEN |= mask;
524}
525
534static inline void FLEXIO_DisableShifterStatusInterrupts(FLEXIO_Type *base, uint32_t mask)
535{
536 base->SHIFTSIEN &= ~mask;
537}
538
547static inline void FLEXIO_EnableShifterErrorInterrupts(FLEXIO_Type *base, uint32_t mask)
548{
549 base->SHIFTEIEN |= mask;
550}
551
560static inline void FLEXIO_DisableShifterErrorInterrupts(FLEXIO_Type *base, uint32_t mask)
561{
562 base->SHIFTEIEN &= ~mask;
563}
564
573static inline void FLEXIO_EnableTimerStatusInterrupts(FLEXIO_Type *base, uint32_t mask)
574{
575 base->TIMIEN |= mask;
576}
577
586static inline void FLEXIO_DisableTimerStatusInterrupts(FLEXIO_Type *base, uint32_t mask)
587{
588 base->TIMIEN &= ~mask;
589}
590
591/* @} */
592
604static inline uint32_t FLEXIO_GetShifterStatusFlags(FLEXIO_Type *base)
605{
606 return ((base->SHIFTSTAT) & FLEXIO_SHIFTSTAT_SSF_MASK);
607}
608
617static inline void FLEXIO_ClearShifterStatusFlags(FLEXIO_Type *base, uint32_t mask)
618{
619 base->SHIFTSTAT = mask;
620}
621
628static inline uint32_t FLEXIO_GetShifterErrorFlags(FLEXIO_Type *base)
629{
630 return ((base->SHIFTERR) & FLEXIO_SHIFTERR_SEF_MASK);
631}
632
641static inline void FLEXIO_ClearShifterErrorFlags(FLEXIO_Type *base, uint32_t mask)
642{
643 base->SHIFTERR = mask;
644}
645
652static inline uint32_t FLEXIO_GetTimerStatusFlags(FLEXIO_Type *base)
653{
654 return ((base->TIMSTAT) & FLEXIO_TIMSTAT_TSF_MASK);
655}
656
665static inline void FLEXIO_ClearTimerStatusFlags(FLEXIO_Type *base, uint32_t mask)
666{
667 base->TIMSTAT = mask;
668}
669
670/* @} */
671
687static inline void FLEXIO_EnableShifterStatusDMA(FLEXIO_Type *base, uint32_t mask, bool enable)
688{
689 if (enable)
690 {
691 base->SHIFTSDEN |= mask;
692 }
693 else
694 {
695 base->SHIFTSDEN &= ~mask;
696 }
697}
698
708
718status_t FLEXIO_RegisterHandleIRQ(void *base, void *handle, flexio_isr_t isr);
719
728/* @} */
729
730#if defined(__cplusplus)
731}
732#endif /*_cplusplus*/
735#endif /*_FSL_FLEXIO_H_*/
#define FLEXIO_TIMCFG_TIMDEC(x)
Definition: MIMXRT1052.h:21034
enum _clock_ip_name clock_ip_name_t
CCM CCGR gate control for each module independently.
Configures the shifter with the shifter configuration. The configuration structure covers both the SH...
Definition: fsl_flexio.c:247
enum _flexio_pin_polarity flexio_pin_polarity_t
Definition of pin polarity.
_flexio_timer_output
Define type of timer initial output or timer reset condition.
Definition: fsl_flexio.h:74
bool enableInDebug
Definition: fsl_flexio.h:243
flexio_timer_enable_condition_t timerEnable
Definition: fsl_flexio.h:269
bool enableInDoze
Definition: fsl_flexio.h:242
enum _flexio_pin_config flexio_pin_config_t
Define type of timer/shifter pin configuration.
enum _flexio_shifter_mode flexio_shifter_mode_t
Define type of shifter working mode.
flexio_timer_trigger_source_t triggerSource
Definition: fsl_flexio.h:254
Definition: fsl_flexio.h:58
enum _flexio_shifter_start_bit flexio_shifter_start_bit_t
Define type of START bit configuration.
struct _flexio_timer_config flexio_timer_config_t
Define FlexIO timer configuration structure.
flexio_shifter_timer_polarity_t timerPolarity
Definition: fsl_flexio.h:282
void(* flexio_isr_t)(void *base, void *handle)
typedef for FlexIO simulated driver interrupt handler.
Definition: fsl_flexio.h:298
_flexio_shifter_timer_polarity
Define type of timer polarity for shifter control.
Definition: fsl_flexio.h:171
flexio_shifter_stop_bit_t shifterStop
Definition: fsl_flexio.h:293
flexio_shifter_start_bit_t shifterStart
Definition: fsl_flexio.h:294
enum _flexio_timer_output_state flexio_timer_output_state_t
FlexIO as PWM channel output state.
enum _flexio_shifter_input_source flexio_shifter_input_source_t
Define type of shifter input source.
_flexio_timer_disable_condition
Define type of timer disable condition.
Definition: fsl_flexio.h:121
enum _flexio_timer_mode flexio_timer_mode_t
Define type of timer work mode.
flexio_pin_config_t pinConfig
Definition: fsl_flexio.h:256
Gates the FlexIO clock. Call this API to stop the FlexIO clock.
Definition: fsl_flexio.c:120
flexio_pin_polarity_t pinPolarity
Definition: fsl_flexio.h:258
Definition: fsl_flexio.h:211
status_t FLEXIO_UnregisterHandleIRQ(void *base)
Unregisters the handle and the interrupt handler for the FlexIO-simulated peripheral.
Definition: fsl_flexio.c:356
Definition: fsl_flexio.h:252
Resets the FlexIO module.
Definition: fsl_flexio.c:158
_flexio_shifter_buffer_type
Define FlexIO shifter buffer type.
Definition: fsl_flexio.h:222
enum _flexio_timer_reset_condition flexio_timer_reset_condition_t
Define type of timer reset condition.
_flexio_timer_trigger_polarity
Define time of timer trigger polarity.
Definition: fsl_flexio.h:35
uint32_t pinSelect
Definition: fsl_flexio.h:285
flexio_timer_trigger_polarity_t triggerPolarity
Definition: fsl_flexio.h:253
flexio_timer_stop_bit_condition_t timerStop
Definition: fsl_flexio.h:271
_flexio_timer_enable_condition
Define type of timer enable condition.
Definition: fsl_flexio.h:134
flexio_timer_start_bit_condition_t timerStart
Definition: fsl_flexio.h:272
_flexio_timer_mode
Definition: fsl_flexio.h:65
Definition: fsl_flexio.h:164
Pointers to flexio clocks for each instance.
Definition: fsl_flexio.c:31
Configures the timer with the timer configuration. The configuration structure covers both the TIMCTL...
Definition: fsl_flexio.c:292
flexio_timer_mode_t timerMode
Definition: fsl_flexio.h:260
flexio_shifter_mode_t shifterMode
Definition: fsl_flexio.h:288
enum _flexio_shifter_timer_polarity flexio_shifter_timer_polarity_t
uint32_t pinSelect
Definition: fsl_flexio.h:257
uint32_t FLEXIO_GetShifterBufferAddress(FLEXIO_Type *base, flexio_shifter_buffer_type_t type, uint8_t index)
Gets the shifter buffer address for the DMA transfer usage.
Definition: fsl_flexio.c:173
void FLEXIO_GetDefaultConfig(flexio_config_t *userConfig)
Gets the default configuration to configure the FlexIO module. The configuration can used directly to...
Definition: fsl_flexio.c:140
enum _flexio_shifter_buffer_type flexio_shifter_buffer_type_t
Definition: fsl_flexio.h:178
Get instance number for FLEXIO module.
Definition: fsl_flexio.c:55
struct _flexio_config_ flexio_config_t
Define FlexIO user configuration structure.
Pointers to flexio bases for each instance.
Definition: fsl_flexio.c:27
enum _flexio_timer_trigger_polarity flexio_timer_trigger_polarity_t
Registers the handle and the interrupt handler for the FlexIO-simulated peripheral.
Definition: fsl_flexio.c:318
flexio_shifter_input_source_t inputSource
Definition: fsl_flexio.h:292
flexio_timer_decrement_source_t timerDecrement
Definition: fsl_flexio.h:263
enum _flexio_timer_decrement_source flexio_timer_decrement_source_t
Define type of timer decrement.
Definition: fsl_flexio.h:286
_flexio_timer_start_bit_condition
Define type of timer start bit generate condition.
Definition: fsl_flexio.h:157
enum _flexio_timer_enable_condition flexio_timer_enable_condition_t
Definition: fsl_flexio.h:273
enum _flexio_timer_trigger_source flexio_timer_trigger_source_t
Define type of timer trigger source.
bool enableFlexio
Definition: fsl_flexio.h:241
flexio_timer_reset_condition_t timerReset
Definition: fsl_flexio.h:265
Definition: fsl_flexio.h:85
Definition: fsl_flexio.h:280
Definition: fsl_flexio.h:196
enum _flexio_timer_stop_bit_condition flexio_timer_stop_bit_condition_t
Define type of timer stop bit generate condition.
Definition: fsl_flexio.h:42
Definition: fsl_flexio.h:109
struct _flexio_shifter_config flexio_shifter_config_t
Define FlexIO shifter configuration structure.
enum _flexio_timer_start_bit_condition flexio_timer_start_bit_condition_t
flexio_timer_disable_condition_t timerDisable
Definition: fsl_flexio.h:267
enum _flexio_timer_disable_condition flexio_timer_disable_condition_t
Configures the FlexIO with a FlexIO configuration. The configuration structure can be filled by the u...
Definition: fsl_flexio.c:91
Definition: fsl_flexio.h:284
_flexio_pin_config
Definition: fsl_flexio.h:49
enum _flexio_timer_output flexio_timer_output_t
bool enableFastAccess
Definition: fsl_flexio.h:244
enum _flexio_shifter_stop_bit flexio_shifter_stop_bit_t
Define of STOP bit configuration.
Definition: fsl_flexio.h:147
flexio_timer_output_t timerOutput
Definition: fsl_flexio.h:261
Definition: fsl_flexio.h:203
@ kFLEXIO_TimerOutputOneNotAffectedByReset
Definition: fsl_flexio.h:75
@ kFLEXIO_TimerOutputOneAffectedByReset
Definition: fsl_flexio.h:79
@ kFLEXIO_TimerOutputZeroNotAffectedByReset
Definition: fsl_flexio.h:77
@ kFLEXIO_TimerOutputZeroAffectedByReset
Definition: fsl_flexio.h:80
@ kFLEXIO_PinActiveLow
Definition: fsl_flexio.h:60
@ kFLEXIO_PinActiveHigh
Definition: fsl_flexio.h:59
@ kFLEXIO_ShifterTimerPolarityOnNegitive
Definition: fsl_flexio.h:173
@ kFLEXIO_ShifterTimerPolarityOnPositive
Definition: fsl_flexio.h:172
@ kFLEXIO_TimerDisableOnPinBothEdge
Definition: fsl_flexio.h:126
@ kFLEXIO_TimerDisableOnPreTimerDisable
Definition: fsl_flexio.h:123
@ kFLEXIO_TimerDisableOnTriggerFallingEdge
Definition: fsl_flexio.h:129
@ kFLEXIO_TimerDisableNever
Definition: fsl_flexio.h:122
@ kFLEXIO_TimerDisableOnTimerCompare
Definition: fsl_flexio.h:124
@ kFLEXIO_TimerDisableOnTimerCompareTriggerLow
Definition: fsl_flexio.h:125
@ kFLEXIO_TimerDisableOnPinBothEdgeTriggerHigh
Definition: fsl_flexio.h:127
@ kFLEXIO_ShifterStartBitHigh
Definition: fsl_flexio.h:217
@ kFLEXIO_ShifterStartBitLow
Definition: fsl_flexio.h:216
@ kFLEXIO_ShifterStartBitDisabledLoadDataOnEnable
Definition: fsl_flexio.h:212
@ kFLEXIO_ShifterStartBitDisabledLoadDataOnShift
Definition: fsl_flexio.h:214
@ kFLEXIO_ShifterBufferBitSwapped
Definition: fsl_flexio.h:224
Definition: fsl_flexio.h:223
@ kFLEXIO_ShifterBufferBitByteSwapped
Definition: fsl_flexio.h:226
@ kFLEXIO_ShifterBufferByteSwapped
Definition: fsl_flexio.h:225
@ kFLEXIO_TimerTriggerPolarityActiveLow
Definition: fsl_flexio.h:37
@ kFLEXIO_TimerTriggerPolarityActiveHigh
Definition: fsl_flexio.h:36
@ kFLEXIO_TimerEnableOnPrevTimerEnable
Definition: fsl_flexio.h:136
@ kFLEXIO_TimerEnabledAlways
Definition: fsl_flexio.h:135
@ kFLEXIO_TimerEnableOnPinRisingEdge
Definition: fsl_flexio.h:139
@ kFLEXIO_TimerEnableOnTriggerHighPinHigh
Definition: fsl_flexio.h:138
@ kFLEXIO_TimerEnableOnTriggerBothEdge
Definition: fsl_flexio.h:142
@ kFLEXIO_TimerEnableOnTriggerRisingEdge
Definition: fsl_flexio.h:141
Definition: fsl_flexio.h:137
@ kFLEXIO_TimerEnableOnPinRisingEdgeTriggerHigh
Definition: fsl_flexio.h:140
@ kFLEXIO_TimerModeDual8BitPWM
Definition: fsl_flexio.h:68
@ kFLEXIO_TimerModeDual8BitBaudBit
Definition: fsl_flexio.h:67
@ kFLEXIO_TimerModeSingle16Bit
Definition: fsl_flexio.h:69
@ kFLEXIO_TimerModeDisabled
Definition: fsl_flexio.h:66
@ kFLEXIO_PwmHigh
Definition: fsl_flexio.h:166
@ kFLEXIO_PwmLow
Definition: fsl_flexio.h:165
@ kFLEXIO_ShifterModeMatchStore
Definition: fsl_flexio.h:182
@ kFLEXIO_ShifterDisabled
Definition: fsl_flexio.h:179
@ kFLEXIO_ShifterModeReceive
Definition: fsl_flexio.h:180
@ kFLEXIO_ShifterModeMatchContinuous
Definition: fsl_flexio.h:183
@ kFLEXIO_ShifterModeTransmit
Definition: fsl_flexio.h:181
@ kFLEXIO_TimerStartBitDisabled
Definition: fsl_flexio.h:158
@ kFLEXIO_TimerStartBitEnabled
Definition: fsl_flexio.h:159
@ kFLEXIO_TimerDecSrcOnTriggerInputShiftTriggerInput
Definition: fsl_flexio.h:92
@ kFLEXIO_TimerDecSrcOnFlexIOClockShiftTimerOutput
Definition: fsl_flexio.h:86
@ kFLEXIO_TimerDecSrcOnPinInputShiftPinInput
Definition: fsl_flexio.h:90
@ kFLEXIO_TimerDecSrcOnTriggerInputShiftTimerOutput
Definition: fsl_flexio.h:88
@ kFLEXIO_ShifterInputFromNextShifterOutput
Definition: fsl_flexio.h:198
@ kFLEXIO_ShifterInputFromPin
Definition: fsl_flexio.h:197
@ kFLEXIO_TimerTriggerSourceInternal
Definition: fsl_flexio.h:44
@ kFLEXIO_TimerTriggerSourceExternal
Definition: fsl_flexio.h:43
@ kFLEXIO_TimerResetOnTimerPinRisingEdge
Definition: fsl_flexio.h:114
@ kFLEXIO_TimerResetNever
Definition: fsl_flexio.h:110
@ kFLEXIO_TimerResetOnTimerTriggerRisingEdge
Definition: fsl_flexio.h:115
@ kFLEXIO_TimerResetOnTimerTriggerEqualToTimerOutput
Definition: fsl_flexio.h:112
@ kFLEXIO_TimerResetOnTimerPinEqualToTimerOutput
Definition: fsl_flexio.h:111
@ kFLEXIO_TimerResetOnTimerTriggerBothEdge
Definition: fsl_flexio.h:116
@ kFLEXIO_PinConfigOutputDisabled
Definition: fsl_flexio.h:50
Definition: fsl_flexio.h:53
@ kFLEXIO_PinConfigOpenDrainOrBidirection
Definition: fsl_flexio.h:51
@ kFLEXIO_PinConfigBidirectionOutputData
Definition: fsl_flexio.h:52
@ kFLEXIO_TimerStopBitEnableOnTimerCompare
Definition: fsl_flexio.h:149
@ kFLEXIO_TimerStopBitDisabled
Definition: fsl_flexio.h:148
@ kFLEXIO_TimerStopBitEnableOnTimerCompareDisable
Definition: fsl_flexio.h:151
@ kFLEXIO_TimerStopBitEnableOnTimerDisable
Definition: fsl_flexio.h:150
@ kFLEXIO_ShifterStopBitLow
Definition: fsl_flexio.h:205
@ kFLEXIO_ShifterStopBitHigh
Definition: fsl_flexio.h:206
@ kFLEXIO_ShifterStopBitDisable
Definition: fsl_flexio.h:204
int32_t status_t
Type used for all status and error return values.
Definition: fsl_common.h:225
Definition: MIMXRT1052.h:20511
Definition: fsl_flexio.h:240
Definition: fsl_flexio.h:278
Definition: fsl_flexio.h:250
