RTEMS 6.1
fsl_aoi.h
1/*
2 * Copyright (c) 2015, Freescale Semiconductor, Inc.
3 * Copyright 2016-2019 NXP
4 * All rights reserved.
5 *
6 * SPDX-License-Identifier: BSD-3-Clause
7 */
8#ifndef _FSL_AOI_H_
9#define _FSL_AOI_H_
10
11#include "fsl_common.h"
12
18/*******************************************************************************
19 * Definitions
20 ******************************************************************************/
21#ifndef AOI
22#define AOI AOI0
23#endif
24
27#define FSL_AOI_DRIVER_VERSION (MAKE_VERSION(2, 0, 1))
29
36{
40 kAOI_LogicOne = 0x3U
42
47typedef enum _aoi_event
48{
49 kAOI_Event0 = 0x0U,
50 kAOI_Event1 = 0x1U,
51 kAOI_Event2 = 0x2U,
52 kAOI_Event3 = 0x3U
54
61typedef struct _aoi_event_config
62{
80
81/*******************************************************************************
82 * API
83 ******************************************************************************/
84
85#if defined(__cplusplus)
86extern "C" {
87#endif /* __cplusplus*/
88
101void AOI_Init(AOI_Type *base);
102
110void AOI_Deinit(AOI_Type *base);
111
136
176void AOI_SetEventLogicConfig(AOI_Type *base, aoi_event_t event, const aoi_event_config_t *eventConfig);
177
178#if defined(__cplusplus)
179}
180#endif /* __cplusplus*/
181
184/*!* @} */
185
186#endif /* _FSL_AOI_H_*/
Configures an AOI event.
Definition: fsl_aoi.c:193
aoi_input_config_t PT2DC
Definition: fsl_aoi.h:74
aoi_input_config_t PT0CC
Definition: fsl_aoi.h:65
void AOI_GetEventLogicConfig(AOI_Type *base, aoi_event_t event, aoi_event_config_t *config)
Gets the Boolean evaluation associated.
Definition: fsl_aoi.c:104
Deinitializes an AOI instance for operation.
Definition: fsl_aoi.c:80
aoi_input_config_t PT2BC
Definition: fsl_aoi.h:72
enum _aoi_input_config aoi_input_config_t
AOI input configurations.
aoi_input_config_t PT3AC
Definition: fsl_aoi.h:75
Initializes an AOI instance for operation.
Definition: fsl_aoi.c:65
aoi_input_config_t PT1DC
Definition: fsl_aoi.h:70
aoi_input_config_t PT1CC
Definition: fsl_aoi.h:69
_aoi_input_config
Definition: fsl_aoi.h:36
struct _aoi_event_config aoi_event_config_t
AOI event configuration structure.
_aoi_event
AOI event indexes, where an event is the collection of the four product terms (0, 1,...
Definition: fsl_aoi.h:48
aoi_input_config_t PT0AC
Definition: fsl_aoi.h:63
aoi_input_config_t PT1AC
Definition: fsl_aoi.h:67
enum _aoi_event aoi_event_t
aoi_input_config_t PT2CC
Definition: fsl_aoi.h:73
aoi_input_config_t PT2AC
Definition: fsl_aoi.h:71
aoi_input_config_t PT3DC
Definition: fsl_aoi.h:78
aoi_input_config_t PT0BC
Definition: fsl_aoi.h:64
aoi_input_config_t PT1BC
Definition: fsl_aoi.h:68
aoi_input_config_t PT3CC
Definition: fsl_aoi.h:77
aoi_input_config_t PT0DC
Definition: fsl_aoi.h:66
aoi_input_config_t PT3BC
Definition: fsl_aoi.h:76
@ kAOI_InputSignal
Definition: fsl_aoi.h:38
@ kAOI_LogicOne
Definition: fsl_aoi.h:40
@ kAOI_LogicZero
Definition: fsl_aoi.h:37
@ kAOI_InvInputSignal
Definition: fsl_aoi.h:39
@ kAOI_Event2
Definition: fsl_aoi.h:51
@ kAOI_Event1
Definition: fsl_aoi.h:50
@ kAOI_Event0
Definition: fsl_aoi.h:49
@ kAOI_Event3
Definition: fsl_aoi.h:52
Definition: MIMXRT1052.h:3550
Definition: fsl_aoi.h:62
Definition: deflate.c:114
