RTEMS 6.1
freebsd_loader.h
2
11/*
12 * Copyright (C) 2024 Matheus Pecoraro
13 *
16 * are met:
22 *
34 */
35
36#ifndef _AMD64_FREEBSD_LOADER_H
37#define _AMD64_FREEBSD_LOADER_H
38
39#include <bsp.h>
40
41/* Will be called by start.S */
42void retrieve_info_from_freebsd_loader(uint32_t modules_metadata_addr);
43
44#endif /* _AMD64_FREEBSD_LOADER_H */
This header file evaluates configuration options related to the BSP configuration.
