RTEMS 6.1
extensionimpl.h
2
11/*
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_EXTENSIONIMPL_H
38#define _RTEMS_EXTENSIONIMPL_H
39
40#include <rtems/extensiondata.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
57static inline Extension_Control *_Extension_Allocate( void )
58{
60}
61
62static inline void _Extension_Free (
63 Extension_Control *the_extension
64)
65{
66 _Objects_Free( &_Extension_Information, &the_extension->Object );
67}
68
69static inline Extension_Control *_Extension_Get( Objects_Id id )
70{
71 return (Extension_Control *)
73}
74
77#ifdef __cplusplus
78}
79#endif
80
81#endif
82/* end of include file */
This header file provides data structures used by the implementation and the Application Configuratio...
Objects_Information _Extension_Information
The Classic Extensions objects information.
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:43
uint32_t Objects_Id
Definition: object.h:101
Objects_Control * _Objects_Get_no_protection(Objects_Id id, const Objects_Information *information)
Maps object ids to object control blocks.
Definition: objectgetnoprotection.c:44
This header file provides interfaces of the Object Handler which are only used by the implementation.
Definition: extensiondata.h:55
