RTEMS
6.1
include
score
exception.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_EXCEPTION_H
38
#define _RTEMS_EXCEPTION_H
39
40
rtems/fatal.h
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
61
void
_Exception_Raise_signal
62
Internal_errors_Source
source,
63
bool
always_set_to_false,
64
Internal_errors_t
code
65
66
67
#ifdef __cplusplus
68
69
#endif
70
71
#endif
/* _RTEMS_EXCEPTION_H */
fatal.h
This header file defines the Fatal Error Manager API.
void _Exception_Raise_signal(Internal_errors_Source source, bool always_set_to_false, Internal_errors_t code)
Handle an exception frame for the purpose of mapping signals.
Definition:
exceptionmapping.c:61
This type lists the possible sources from which an error can be reported.
Definition:
interr.h:63
code
Definition:
inftrees.h:24
