RTEMS 6.1
eventmp.h
2
12/* COPYRIGHT (c) 1989-2013.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_EVENTMP_H
38#define _RTEMS_RTEMS_EVENTMP_H
39
40#ifndef _RTEMS_RTEMS_EVENTIMPL_H
41# error "Never use <rtems/rtems/eventmp.h> directly; include <rtems/rtems/eventimpl.h> instead."
42#endif
43
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
64/*
65 * @brief Event_MP_Send_process_packet
66 *
67 * This routine performs a remote procedure call so that a
68 * process operation can be performed on another node.
69 *
70 * @note This routine is not needed since there are no process
71 * packets to be sent by this manager.
72 */
73
78 rtems_id id,
79 rtems_event_set event_in
80);
81
89 rtems_packet_prefix *the_packet_prefix
90);
91
92/*
93 * @brief Event_MP_Send_object_was_deleted
94 *
95 * This routine is invoked indirectly by the thread queue
96 * when a proxy has been removed from the thread queue and
97 * the remote node must be informed of this.
98 *
99 * This routine is not needed since there are no objects
100 * deleted by this manager.
101 */
102
103/*
104 * @brief Event_MP_Send_extract_proxy
105 *
106 * This routine is invoked when a task is deleted and it
107 * has a proxy which must be removed from a thread queue and
108 * the remote node must be informed of this.
109 *
110 * This routine is not needed since there are no objects
111 * deleted by this manager.
112 */
113
114#ifdef __cplusplus
115}
116#endif
117
120#endif
121/* end of file */
uint32_t rtems_event_set
This integer type represents a bit field which can hold exactly 32 individual events.
Definition: event.h:436
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
void _Event_MP_Process_packet(rtems_packet_prefix *the_packet_prefix)
Event MP Packet Process.
Definition: eventmp.c:140
rtems_status_code _Event_MP_Send(rtems_id id, rtems_event_set event_in)
Issues a remote rtems_event_send() request.
Definition: eventmp.c:80
This header file provides interfaces of the MPCI Handler which are only used by the implementation.
