RTEMS 6.1
efidef.h
1/* $FreeBSD$ */
2#ifndef _EFI_DEF_H
3#define _EFI_DEF_H
4
5/*++
6
7Copyright (c) 1999 - 2002 Intel Corporation. All rights reserved
8This software and associated documentation (if any) is furnished
9under a license and may only be used or copied in accordance
10with the terms of the license. Except as permitted by such
11license, no part of this software or documentation may be
12reproduced, stored in a retrieval system, or transmitted in any
13form or by any means without the express written consent of
14Intel Corporation.
15
16Module Name:
17
18 efidef.h
19
20Abstract:
21
22 EFI definitions
23
24
25
26
27Revision History
28
29--*/
30
31typedef UINT16 CHAR16;
32typedef UINT8 CHAR8;
33#ifndef ACPI_THREAD_ID /* ACPI's definitions are fine */
34typedef UINT8 BOOLEAN;
35#endif
36
37#ifndef TRUE
38 #define TRUE ((BOOLEAN) 1)
39 #define FALSE ((BOOLEAN) 0)
40#endif
41
42#ifndef NULL
43 #define NULL ((VOID *) 0)
44#endif
45
46typedef UINTN EFI_STATUS;
47typedef UINT64 EFI_LBA;
48typedef UINTN EFI_TPL;
49typedef VOID *EFI_HANDLE;
50typedef VOID *EFI_EVENT;
51
52
53//
54// Prototype argument decoration for EFI parameters to indicate
55// their direction
56//
57// IN - argument is passed into the function
58// OUT - argument (pointer) is returned from the function
59// OPTIONAL - argument is optional
60//
61
62#ifndef IN
63 #define IN
64 #define OUT
65 #define OPTIONAL
66 #define CONST const
67#endif
68
69
70//
71// A GUID
72//
73
74typedef struct {
75 UINT32 Data1;
76 UINT16 Data2;
77 UINT16 Data3;
78 UINT8 Data4[8];
79} EFI_GUID;
80
81
82//
83// Time
84//
85
86typedef struct {
87 UINT16 Year; // 1998 - 20XX
88 UINT8 Month; // 1 - 12
89 UINT8 Day; // 1 - 31
90 UINT8 Hour; // 0 - 23
91 UINT8 Minute; // 0 - 59
92 UINT8 Second; // 0 - 59
93 UINT8 Pad1;
94 UINT32 Nanosecond; // 0 - 999,999,999
95 INT16 TimeZone; // -1440 to 1440 or 2047
96 UINT8 Daylight;
97 UINT8 Pad2;
98} EFI_TIME;
99
100// Bit definitions for EFI_TIME.Daylight
101#define EFI_TIME_ADJUST_DAYLIGHT 0x01
102#define EFI_TIME_IN_DAYLIGHT 0x02
103
104// Value definition for EFI_TIME.TimeZone
105#define EFI_UNSPECIFIED_TIMEZONE 0x07FF
106
107
108
109//
110// Networking
111//
112
113typedef struct {
114 UINT8 Addr[4];
116
117typedef struct {
118 UINT8 Addr[16];
120
121typedef struct {
122 UINT8 Addr[32];
124
125typedef struct {
126 UINT32 ReceivedQueueTimeoutValue;
127 UINT32 TransmitQueueTimeoutValue;
128 UINT16 ProtocolTypeFilter;
129 BOOLEAN EnableUnicastReceive;
130 BOOLEAN EnableMulticastReceive;
131 BOOLEAN EnableBroadcastReceive;
132 BOOLEAN EnablePromiscuousReceive;
133 BOOLEAN FlushQueuesOnReset;
134 BOOLEAN EnableReceiveTimestamps;
135 BOOLEAN DisableBackgroundPolling;
137
138//
139// Memory
140//
141
142typedef UINT64 EFI_PHYSICAL_ADDRESS;
143typedef UINT64 EFI_VIRTUAL_ADDRESS;
144
145typedef enum {
146 AllocateAnyPages,
147 AllocateMaxAddress,
148 AllocateAddress,
149 MaxAllocateType
150} EFI_ALLOCATE_TYPE;
151
152//Preseve the attr on any range supplied.
153//ConventialMemory must have WB,SR,SW when supplied.
154//When allocating from ConventialMemory always make it WB,SR,SW
155//When returning to ConventialMemory always make it WB,SR,SW
156//When getting the memory map, or on RT for runtime types
157
158
159typedef enum {
160 EfiReservedMemoryType,
161 EfiLoaderCode,
162 EfiLoaderData,
163 EfiBootServicesCode,
164 EfiBootServicesData,
165 EfiRuntimeServicesCode,
166 EfiRuntimeServicesData,
167 EfiConventionalMemory,
168 EfiUnusableMemory,
169 EfiACPIReclaimMemory,
170 EfiACPIMemoryNVS,
171 EfiMemoryMappedIO,
172 EfiMemoryMappedIOPortSpace,
173 EfiPalCode,
174 EfiPersistentMemory,
175 EfiMaxMemoryType
176} EFI_MEMORY_TYPE;
177
178// possible caching types for the memory range
179#define EFI_MEMORY_UC 0x0000000000000001
180#define EFI_MEMORY_WC 0x0000000000000002
181#define EFI_MEMORY_WT 0x0000000000000004
182#define EFI_MEMORY_WB 0x0000000000000008
183#define EFI_MEMORY_UCE 0x0000000000000010
184
185// physical memory protection on range
186#define EFI_MEMORY_WP 0x0000000000001000
187#define EFI_MEMORY_RP 0x0000000000002000
188#define EFI_MEMORY_XP 0x0000000000004000
189#define EFI_MEMORY_NV 0x0000000000008000
190#define EFI_MEMORY_MORE_RELIABLE 0x0000000000010000
191#define EFI_MEMORY_RO 0x0000000000020000
192
193// range requires a runtime mapping
194#define EFI_MEMORY_RUNTIME 0x8000000000000000
195
196#define EFI_MEMORY_DESCRIPTOR_VERSION 1
197typedef struct {
198 UINT32 Type; // Field size is 32 bits followed by 32 bit pad
199 UINT32 Pad;
200 EFI_PHYSICAL_ADDRESS PhysicalStart; // Field size is 64 bits
201 EFI_VIRTUAL_ADDRESS VirtualStart; // Field size is 64 bits
202 UINT64 NumberOfPages; // Field size is 64 bits
203 UINT64 Attribute; // Field size is 64 bits
205
206//
207// International Language
208//
209
210typedef UINT8 ISO_639_2;
211#define ISO_639_2_ENTRY_SIZE 3
212
213//
214//
215//
216
217#define EFI_PAGE_SIZE 4096
218#define EFI_PAGE_MASK 0xFFF
219#define EFI_PAGE_SHIFT 12
220
221#define EFI_SIZE_TO_PAGES(a) \
222 ( ((a) >> EFI_PAGE_SHIFT) + (((a) & EFI_PAGE_MASK) ? 1 : 0) )
223
224#endif
Definition: efidef.h:74
Definition: efidef.h:113
Definition: efidef.h:117
Definition: efidef.h:121
Definition: efidef.h:125
Definition: efidef.h:197
Definition: efidef.h:86
