RTEMS
6.1
include
dev
i2c
eeprom.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2014 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
#ifndef _DEV_I2C_EEPROM_H
37
#define _DEV_I2C_EEPROM_H
38
39
dev/i2c/i2c.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
55
int
i2c_dev_register_eeprom(
56
const
char
*bus_path,
57
const
char
*dev_path,
58
uint16_t i2c_address,
59
uint16_t address_bytes,
60
uint16_t page_size_in_bytes,
61
uint32_t size_in_bytes,
62
uint32_t program_timeout_in_ms
63
64
67
#ifdef __cplusplus
68
69
#endif
/* __cplusplus */
70
71
#endif
/* _DEV_I2C_EEPROM_H */
i2c.h
Inter-Integrated Circuit (I2C) Driver API.
