RTEMS
6.1
include
drvmgr
drvmgr_list.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
9
10
* COPYRIGHT (c) 2009 Cobham Gaisler AB.
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
35
* Help functions for the Driver Manager. Implements a singly linked list
36
* with head and tail pointers for fast insertions/deletions to head and
37
* tail in list.
38
39
40
#ifndef _DRVIVER_MANAGER_LIST_H_
41
#define _DRVIVER_MANAGER_LIST_H_
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
48
struct
drvmgr_list
49
void
head
50
void
tail
51
int
ofs
52
53
54
/* Static initialization of list */
55
#define LIST_INITIALIZER(type, field) {NULL, NULL, offsetof(type, field)}
56
57
/* Return the first element in list */
58
#define LIST_HEAD(list, type) ((type *)(list)->head)
59
60
/* Return the last element in list */
61
#define LIST_TAIL(list, type) ((type *)(list)->tail)
62
63
/* Get the next pointer of an entry */
64
#define LIST_FIELD(list, entry) (*(void **)((char *)(entry) + (list)->ofs))
65
66
/* Return the next emlement in list */
67
#define LIST_NEXT(list, entry, type) ((type *)(LIST_FIELD(list, entry)))
68
69
/* Iterate through all entries in list */
70
#define LIST_FOR_EACH(list, entry, type) \
71
for (entry = LIST_HEAD(list, type); \
72
entry; \
73
entry = LIST_NEXT(list, entry, type))
74
81
extern
void
drvmgr_list_init
struct
drvmgr_list
*list,
int
offset);
82
84
extern
void
drvmgr_list_empty
struct
drvmgr_list
*list);
85
87
extern
void
drvmgr_list_add_head
struct
drvmgr_list
*list,
void
entry
88
90
extern
void
drvmgr_list_add_tail
struct
drvmgr_list
*list,
void
entry
91
93
extern
void
drvmgr_list_remove_head
struct
drvmgr_list
*list);
94
96
extern
void
drvmgr_list_remove
struct
drvmgr_list
*list,
void
entry
97
98
#ifdef __cplusplus
99
100
#endif
101
102
#endif
drvmgr_list_remove
void drvmgr_list_remove(struct drvmgr_list *list, void *entry)
Definition:
drvmgr_list.c:70
void drvmgr_list_add_tail(struct drvmgr_list *list, void *entry)
Definition:
drvmgr_list.c:53
drvmgr_list_init
void drvmgr_list_init(struct drvmgr_list *list, int offset)
Definition:
drvmgr_list.c:34
void drvmgr_list_add_head(struct drvmgr_list *list, void *entry)
Definition:
drvmgr_list.c:45
void drvmgr_list_remove_head(struct drvmgr_list *list)
Definition:
drvmgr_list.c:63
drvmgr_list_empty
void drvmgr_list_empty(struct drvmgr_list *list)
Definition:
drvmgr_list.c:40
drvmgr_list
Definition:
drvmgr_list.h:48
drvmgr_list::head
void * head
Definition:
drvmgr_list.h:49
drvmgr_list::ofs
int ofs
Definition:
drvmgr_list.h:51
drvmgr_list::tail
void * tail
Definition:
drvmgr_list.h:50
entry
Definition:
mmu-config.c:53
