RTEMS 6.1
dpmemimpl.h
2
12/* COPYRIGHT (c) 1989-2008.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTEMS_DPMEM_INL
38#define _RTEMS_RTEMS_DPMEM_INL
39
42
43#ifdef __cplusplus
44extern "C" {
45#endif
46
65 *_Dual_ported_memory_Allocate ( void )
66{
69}
70
78static inline void _Dual_ported_memory_Free (
80)
81{
82 _Objects_Free( &_Dual_ported_memory_Information, &the_port->Object );
83}
84
85static inline Dual_ported_memory_Control *_Dual_ported_memory_Get(
86 Objects_Id id,
87 ISR_lock_Context *lock_context
88)
89{
92}
93
96#ifdef __cplusplus
97}
98#endif
99
100#endif /* _RTEMS_RTEMS_DPMEM_INL */
101/* end of include file */
This header file provides data structures used by the implementation and the Application Configuratio...
Objects_Information _Dual_ported_memory_Information
The Classic Dual Ported Memory objects information.
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition: objectallocate.c:43
uint32_t Objects_Id
Definition: object.h:101
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition: objectgetlocal.c:43
This header file provides interfaces of the Object Handler which are only used by the implementation.
Definition: dpmemdata.h:59
Objects_Control Object
Definition: dpmemdata.h:61
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:94
