RTEMS 6.1
debugmod.h
1/* debugmod.h
2 *
3 * This file contains definitions for the IBM/Motorola PowerPC
4 * family members.
5 *
6 * Author: Andrew Bray <andy@i-cubed.co.uk>
7 *
8 * COPYRIGHT (c) 1995 by i-cubed ltd.
9 *
10 * MPC860 support code was added by Jay Monkman <jmonkman@frasca.com>
11 * MPC8260 support added by Andy Dachs <a.dachs@sstl.co.uk>
12 * Surrey Satellite Technology Limited
13 *
14 * To anyone who acknowledges that this file is provided "AS IS"
15 * without any express or implied warranty:
16 * permission to use, copy, modify, and distribute this file
17 * for any purpose is hereby granted without fee, provided that
18 * the above copyright notice and this notice appears in all
19 * copies, and that the name of i-cubed limited not be used in
20 * advertising or publicity pertaining to distribution of the
21 * software without specific, written prior permission.
22 * i-cubed limited makes no representations about the suitability
23 * of this software for any purpose.
24 *
25 * Derived from c/src/exec/cpu/no_cpu/no_cpu.h:
26 *
27 * COPYRIGHT (c) 1989-1997.
28 * On-Line Applications Research Corporation (OAR).
29 *
30 * The license and distribution terms for this file may in
31 * the file LICENSE in this distribution or at
32 * http://www.rtems.org/license/LICENSE.
33 *
34 *
35 * Note:
36 * This file is included by both C and assembler code ( -DASM )
37 */
38
39/*
40 * FIXME: This file is not used anywhere inside of RTEMS source-tree.
41 * Notify OAR if you actually use it, otherwise it might be removed in
42 * future versions of RTEMS
43 */
44
45#ifndef _RTEMS_POWERPC_DEBUGMOD_H
46#define _RTEMS_POWERPC_DEBUGMOD_H
47
48#warning "please read the FIXME inside of this file"
49
50#ifdef __cplusplus
51extern "C" {
52#endif
53
54/*
55 * This file contains the information required to build
56 * RTEMS for a particular member of the PowerPC family. It does
57 * this by setting variables to indicate which implementation
58 * dependent features are present in a particular member
59 * of the family.
60 *
61 * The following architectural feature definitions are defaulted
62 * unless specifically set by the model definition:
63 *
64 * + PPC_DEBUG_MODEL - PPC_DEBUG_MODEL_STANDARD
65 */
66
67/*
68 * Define the debugging assistance models found in the PPC family.
69 *
70 * Standard: single step and branch trace
71 * Single Step Only: single step only
72 * IBM 4xx: debug exception
73 */
74
75#define PPC_DEBUG_MODEL_STANDARD 1
76#define PPC_DEBUG_MODEL_SINGLE_STEP_ONLY 2
77#define PPC_DEBUG_MODEL_IBM4xx 3
78
79#elif defined(ppc403) || defined(ppc405) || defined(ppc440)
80
81#define PPC_DEBUG_MODEL PPC_DEBUG_MODEL_IBM4xx
82
83#elif defined(ppc601)
84
85#define PPC_DEBUG_MODEL PPC_DEBUG_MODEL_SINGLE_STEP_ONLY
86
87#endif
88
89/*
90 * Use the default debug scheme defined in the architectural specification
91 * if another model has not been specified.
92 */
93
94#ifndef PPC_DEBUG_MODEL
95#define PPC_DEBUG_MODEL PPC_DEBUG_MODEL_STANDARD
96#endif
97
98/*
99 * Interrupt/exception MSR bits set as defined on p. 2-20 in "The Programming
100 * Environments" and the manuals for various PPC models.
101 */
102
103#if (PPC_DEBUG_MODEL == PPC_DEBUG_MODEL_STANDARD)
104#define PPC_MSR_DE 0x000000000 /* bit 22 - debug exception enable */
105#define PPC_MSR_BE 0x000000200 /* bit 22 - branch trace enable */
106#define PPC_MSR_SE 0x000000400 /* bit 21 - single step trace enable */
107#elif (PPC_DEBUG_MODEL == PPC_DEBUG_MODEL_SINGLE_STEP_ONLY)
108#define PPC_MSR_DE 0x000000000 /* bit 22 - debug exception enable */
109#define PPC_MSR_BE 0x000000200 /* bit 22 - branch trace enable */
110#define PPC_MSR_SE 0x000000000 /* bit 21 - single step trace enable */
111#elif (PPC_DEBUG_MODEL == PPC_DEBUG_MODEL_IBM4xx)
112#define PPC_MSR_DE 0x000000200 /* bit 22 - debug exception enable */
113#define PPC_MSR_BE 0x000000000 /* bit 22 - branch trace enable */
114#define PPC_MSR_SE 0x000000000 /* bit 21 - single step trace enable */
115#else
116#error "MSR constants -- unknown PPC_DEBUG_MODEL!!"
117#endif
118
119#ifdef __cplusplus
120}
121#endif
122
123#endif /* _RTEMS_POWERPC_DEBUGMOD_H */
124/* end of include file */
