RTEMS 6.1
debug_defs.h
2
3/*
4 * COPYRIGHT (c) 2007.
5 * Cobham Gaisler.
6 *
7 * Redistribution and use in source and binary forms, with or without
8 * modification, are permitted provided that the following conditions
9 * are met:
10 * 1. Redistributions of source code must retain the above copyright
11 * notice, this list of conditions and the following disclaimer.
12 * 2. Redistributions in binary form must reproduce the above copyright
13 * notice, this list of conditions and the following disclaimer in the
14 * documentation and/or other materials provided with the distribution.
15 *
16 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
17 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
18 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
19 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
20 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
21 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
22 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
23 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
24 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
25 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
26 * POSSIBILITY OF SUCH DAMAGE.
27 *
28 */
29
35#ifndef __DEBUG_DEFS_H__
36#define __DEBUG_DEFS_H__
37
38#ifdef __cplusplus
39extern "C" {
40#endif
41
42
43#ifdef DEBUG
44
45 #ifndef DEBUG_FLAGS
46 #define DEBUG_FLAGS 0
47 #endif
48
49 #define DBG(fmt, args...) do { printk(" : %03d @ %18s()]:" fmt , __LINE__,__FUNCTION__,## args); } while(0)
50 #define DBG2(fmt) do { printk(" : %03d @ %18s()]:" fmt , __LINE__,__FUNCTION__); } while(0)
51 #define DBGC(c,fmt, args...) do { if (DEBUG_FLAGS & c) { printk(" : %03d @ %18s()]:" fmt , __LINE__,__FUNCTION__,## args); }} while(0)
52
53#else
54
55 #define DBG(fmt, args...)
56 #define DBG2(fmt, args...)
57 #define DBGC(c, fmt, args...)
58
59#endif
60
61#ifdef DEBUGFUNCS
62 #define FUNCDBG() do { printk("%s\n\r",__FUNCTION__); } while(0)
63#else
64 #define FUNCDBG()
65#endif
66
67#ifdef __cplusplus
68}
69#endif
70
71#endif /* __DEBUG_DEFS_H__ */
