RTEMS 6.1
cs2100.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef CS2100_H
38#define CS2100_H
39
40#include "board.h"
41
42/*----------------------------------------------------------------------------
43 * Definitions
44 *----------------------------------------------------------------------------*/
45
46#define CS2100_SLAVE_ADDRESS 0x4E
47
49#define CS2100_REG_ID 0x01
50
52#define CS2100_REG_CTRL 0x02
53
55#define CS2100_REG_DEV_CFG1 0x03
56
58#define CS2100_REG_CFG 0x05
59
61#define CS2100_REG_32_BIT_RATIO_1 0x06
63#define CS2100_REG_32_BIT_RATIO_2 0x07
65#define CS2100_REG_32_BIT_RATIO_3 0x08
67#define CS2100_REG_32_BIT_RATIO_4 0x09
69#define CS2100_REG_FUNC_CFG1 0x16
71#define CS2100_REG_FUNC_CFG2 0x17
73#define CS2100_REG_FUNC_CFG3 0x1E
74
75/*----------------------------------------------------------------------------
76 * Exported functions
77 *----------------------------------------------------------------------------*/
78
79extern uint16_t CS2100_Read(
80 Twid *pTwid,
81 uint32_t device,
82 uint32_t regAddr);
83
84extern void CS2100_Write(
85 Twid *pTwid,
86 uint32_t device,
87 uint32_t regAddr,
88 uint16_t data);
89
90extern uint8_t CS2100_Init(Twid *pTwid, uint32_t device, uint32_t PCK);
91#endif // CS2100_H
92
93
TWI driver structure. Holds the internal state of the driver.
Definition: twid.h:72
