RTEMS 6.1
asm.h
1
17/*
18 * COPYRIGHT:
19 *
20 * This file is based on similar code found in newlib available
21 * from ftp.cygnus.com. The file which was used had no copyright
22 * notice. This file is freely distributable as long as the source
23 * of the file is noted. This file is:
24 *
25 * COPYRIGHT (c) 1995.
26 * i-cubed ltd.
27 *
28 * COPYRIGHT (c) 1994.
29 * On-Line Applications Research Corporation (OAR).
30 */
31
32#ifndef _RTEMS_ASM_H
33#define _RTEMS_ASM_H
34
35/*
36 * Indicate we are in an assembly file and get the basic CPU definitions.
37 */
38
39#ifndef ASM
40#define ASM
41#endif
42#include <rtems/score/cpuopts.h>
43#include <rtems/score/powerpc.h>
44
55/*
56 * Recent versions of GNU cpp define variables which indicate the
57 * need for underscores and percents. If not using GNU cpp or
58 * the version does not support this, then you will obviously
59 * have to define these as appropriate.
60 */
61
62#ifndef __USER_LABEL_PREFIX__
63#define __USER_LABEL_PREFIX__
64#endif
65
66#ifndef __REGISTER_PREFIX__
67#define __REGISTER_PREFIX__
68#endif
69
70#ifndef __FLOAT_REGISTER_PREFIX__
71#define __FLOAT_REGISTER_PREFIX__ __REGISTER_PREFIX__
72#endif
73
74#ifndef __PROC_LABEL_PREFIX__
75#define __PROC_LABEL_PREFIX__ __USER_LABEL_PREFIX__
76#endif
77
78/* Use the right prefix for global labels. */
79
80#define SYM(x) RTEMS_XCONCAT (__USER_LABEL_PREFIX__, x)
81
82/* Use the right prefix for procedure labels. */
83
84#define PROC(x) RTEMS_XCONCAT (__PROC_LABEL_PREFIX__, x)
85
86/* Use the right prefix for registers. */
87
88#define REG(x) RTEMS_XCONCAT (__REGISTER_PREFIX__, x)
89
90/* Use the right prefix for floating point registers. */
91
92#define FREG(x) RTEMS_XCONCAT (__FLOAT_REGISTER_PREFIX__, x)
93
94/*
95 * define macros for all of the registers on this CPU
96 *
97 * EXAMPLE: #define d0 REG (d0)
98 */
99#define r0 REG(0)
100#define r1 REG(1)
101#define r2 REG(2)
102#define r3 REG(3)
103#define r4 REG(4)
104#define r5 REG(5)
105#define r6 REG(6)
106#define r7 REG(7)
107#define r8 REG(8)
108#define r9 REG(9)
109#define r10 REG(10)
110#define r11 REG(11)
111#define r12 REG(12)
112#define r13 REG(13)
113#define r14 REG(14)
114#define r15 REG(15)
115#define r16 REG(16)
116#define r17 REG(17)
117#define r18 REG(18)
118#define r19 REG(19)
119#define r20 REG(20)
120#define r21 REG(21)
121#define r22 REG(22)
122#define r23 REG(23)
123#define r24 REG(24)
124#define r25 REG(25)
125#define r26 REG(26)
126#define r27 REG(27)
127#define r28 REG(28)
128#define r29 REG(29)
129#define r30 REG(30)
130#define r31 REG(31)
131#define f0 FREG(0)
132#define f1 FREG(1)
133#define f2 FREG(2)
134#define f3 FREG(3)
135#define f4 FREG(4)
136#define f5 FREG(5)
137#define f6 FREG(6)
138#define f7 FREG(7)
139#define f8 FREG(8)
140#define f9 FREG(9)
141#define f10 FREG(10)
142#define f11 FREG(11)
143#define f12 FREG(12)
144#define f13 FREG(13)
145#define f14 FREG(14)
146#define f15 FREG(15)
147#define f16 FREG(16)
148#define f17 FREG(17)
149#define f18 FREG(18)
150#define f19 FREG(19)
151#define f20 FREG(20)
152#define f21 FREG(21)
153#define f22 FREG(22)
154#define f23 FREG(23)
155#define f24 FREG(24)
156#define f25 FREG(25)
157#define f26 FREG(26)
158#define f27 FREG(27)
159#define f28 FREG(28)
160#define f29 FREG(29)
161#define f30 FREG(30)
162#define f31 FREG(31)
163#define v0 0
164#define v1 1
165#define v2 2
166#define v3 3
167#define v4 4
168#define v5 5
169#define v6 6
170#define v7 7
171#define v8 8
172#define v9 9
173#define v10 10
174#define v11 11
175#define v12 12
176#define v13 13
177#define v14 14
178#define v15 15
179#define v16 16
180#define v17 17
181#define v18 18
182#define v19 19
183#define v20 20
184#define v21 21
185#define v22 22
186#define v23 23
187#define v24 24
188#define v25 25
189#define v26 26
190#define v27 27
191#define v28 28
192#define v29 29
193#define v30 30
194#define v31 31
195
196/*
197 * Some special purpose registers (SPRs).
198 */
199#define srr0 0x01a
200#define srr1 0x01b
201#define srr2 0x3de /* IBM 400 series only */
202#define srr3 0x3df /* IBM 400 series only */
203#define csrr0 58 /* Book E */
204#define csrr1 59 /* Book E */
205#define mcsrr0 570 /* e500 */
206#define mcsrr1 571 /* e500 */
207#define dsrr0 574 /* e200 */
208#define dsrr1 575 /* e200 */
209
210#define sprg0 0x110
211#define sprg1 0x111
212#define sprg2 0x112
213#define sprg3 0x113
214#define sprg4 276
215#define sprg5 277
216#define sprg6 278
217#define sprg7 279
218
219#define usprg0 256
220
221#define dar 0x013 /* Data Address Register */
222#define dec 0x016 /* Decrementer Register */
223
224#if defined(ppc403) || defined(ppc405)
225/* the following SPR/DCR registers exist only in IBM 400 series */
226#define dear 0x3d5
227#define evpr 0x3d6 /* SPR: exception vector prefix register */
228#define iccr 0x3fb /* SPR: instruction cache control reg. */
229#define dccr 0x3fa /* SPR: data cache control reg. */
230
231#if defined (ppc403)
232#define exisr 0x040 /* DCR: external interrupt status register */
233#define exier 0x042 /* DCR: external interrupt enable register */
234#endif /* ppc403 */
235#if defined(ppc405)
236#define exisr 0x0C0 /* DCR: external interrupt status register */
237#define exier 0x0C2 /* DCR: external interrupt enable register */
238#endif /* ppc405 */
239
240#define br0 0x080 /* DCR: memory bank register 0 */
241#define br1 0x081 /* DCR: memory bank register 1 */
242#define br2 0x082 /* DCR: memory bank register 2 */
243#define br3 0x083 /* DCR: memory bank register 3 */
244#define br4 0x084 /* DCR: memory bank register 4 */
245#define br5 0x085 /* DCR: memory bank register 5 */
246#define br6 0x086 /* DCR: memory bank register 6 */
247#define br7 0x087 /* DCR: memory bank register 7 */
248
249/* end of IBM400 series register definitions */
250
251#elif defined(mpc860) || defined(mpc821)
252/* The following registers are for the MPC8x0 */
253#define der 0x095 /* Debug Enable Register */
254#define ictrl 0x09E /* Instruction Support Control Register */
255#define immr 0x27E /* Internal Memory Map Register */
256/* end of MPC8x0 registers */
257#endif
258
259/*
260 * Following must be tailor for a particular flavor of the C compiler.
261 * They may need to put underscores in front of the symbols.
262 */
263
264#define PUBLIC_VAR(sym) .globl SYM (sym)
265#define EXTERN_VAR(sym) .extern SYM (sym)
266#define PUBLIC_PROC(sym) .globl PROC (sym)
267#define EXTERN_PROC(sym) .extern PROC (sym)
268
269/* Other potentially assembler specific operations */
270#if PPC_ASM == PPC_ASM_ELF
271#define ALIGN(n,p) .align p
272#define DESCRIPTOR(x) \
273 .section .descriptors,"aw"; \
274 PUBLIC_VAR (x); \
275SYM (x):; \
276 .long PROC (x); \
277 .long s.got; \
278 .long 0
279
280#define EXT_SYM_REF(x) .long x
281#define EXT_PROC_REF(x) .long x
282
283/*
284 * Define macros to handle section beginning and ends.
285 */
286
287#define BEGIN_CODE_DCL .text
288#define END_CODE_DCL
289#define BEGIN_DATA_DCL .data
290#define END_DATA_DCL
291#define BEGIN_CODE .text
292#define END_CODE
293#define BEGIN_DATA .data
294#define END_DATA
295#define BEGIN_BSS .bss
296#define END_BSS
297#define END
298
299#else
300#error "PPC_ASM_TYPE is not properly defined"
301#endif
302#ifndef PPC_ASM
303#error "PPC_ASM_TYPE is not properly defined"
304#endif
305
306#if defined(__powerpc64__)
307#define PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE nop
308#else
309#define PPC64_NOP_FOR_LINKER_TOC_POINTER_RESTORE
310#endif
311
312#endif
313
IBM/Motorola PowerPC Definitions.
