RTEMS 6.1
rtc.h
2
11/*
12 * COPYRIGHT (c) 1989-2001.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef _RTEMS_RTC_H
38#define _RTEMS_RTC_H
39
40#include <rtems.h>
41
42#ifdef __cplusplus
43extern "C" {
44#endif
45
59#define RTC_DEVICE_NAME "/dev/rtc"
60
64#define RTC_DRIVER_TABLE_ENTRY \
65 { rtc_initialize, rtc_open, rtc_close, \
66 rtc_read, rtc_write, rtc_control }
67
78 void *
79);
80
87 void *
88);
89
96 void *
97);
98
107 void *
108);
109
118 void *
119);
120
127 void *
128);
129
132#ifdef __cplusplus
133}
134#endif
135
136#endif
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
rtems_device_driver rtc_control(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:247
rtems_device_driver rtc_write(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:202
rtems_device_driver rtc_initialize(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:156
rtems_device_driver rtc_read(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:179
rtems_device_driver rtc_close(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:238
rtems_device_driver rtc_open(rtems_device_major_number, rtems_device_minor_number, void *)
Definition: rtc.c:229
