RTEMS 6.1
pci.h
1
7/*
8 * Copyright 1994, Drew Eckhardt
9 * Copyright 1997, 1998 Martin Mares <mj@atrey.karlin.mff.cuni.cz>
10 *
11 * For more information, please consult the following manuals (look at
12 * http://www.pcisig.com/ for how to get them):
13 *
14 * PCI BIOS Specification
15 * PCI Local Bus Specification
16 * PCI to PCI Bridge Specification
17 * PCI System Design Guide
18 */
19
20#ifndef _RTEMS_PCI_H
21#define _RTEMS_PCI_H
22
23#include <stdint.h>
24
25#ifdef __cplusplus
26extern "C" {
27#endif
28
29/*
30 * Under PCI, each device has 256 bytes of configuration address space,
31 * of which the first 64 bytes are standardized as follows:
32 */
33#define PCI_VENDOR_ID 0x00 /* 16 bits */
34#define PCI_DEVICE_ID 0x02 /* 16 bits */
35
36#define PCI_INVALID_VENDORDEVICEID 0xffffffff
37
38#define PCI_COMMAND 0x04 /* 16 bits */
39#define PCI_COMMAND_IO 0x0001 /* Enable response in I/O space */
40#define PCI_COMMAND_MEMORY 0x0002 /* Enable response in Memory space */
41#define PCI_COMMAND_MASTER 0x0004 /* Enable bus mastering */
42#define PCI_COMMAND_SPECIAL 0x0008 /* Enable response to special cycles */
43#define PCI_COMMAND_INVALIDATE 0x0010 /* Use memory write and invalidate */
44#define PCI_COMMAND_VGA_PALETTE 0x0020 /* Enable palette snooping */
45#define PCI_COMMAND_PARITY 0x0040 /* Enable parity checking */
46#define PCI_COMMAND_WAIT 0x0080 /* Enable address/data stepping */
47#define PCI_COMMAND_SERR 0x0100 /* Enable SERR */
48#define PCI_COMMAND_FAST_BACK 0x0200 /* Enable back-to-back writes */
49#define PCI_COMMAND_INTX_DISABLE 0x0400 /* Disable INTx emulation */
50
51#define PCI_STATUS 0x06 /* 16 bits */
52#define PCI_STATUS_66MHZ 0x0020 /* Support 66 Mhz PCI 2.1 bus */
53#define PCI_STATUS_UDF 0x0040 /* Support User Definable Features */
54#define PCI_STATUS_FAST_BACK 0x0080 /* Accept fast-back to back */
55#define PCI_STATUS_PARITY 0x0100 /* Detected parity error */
56#define PCI_STATUS_DEVSEL_MASK 0x0600 /* DEVSEL timing */
57#define PCI_STATUS_DEVSEL_FAST 0x0000
58#define PCI_STATUS_DEVSEL_MEDIUM 0x0200
59#define PCI_STATUS_DEVSEL_SLOW 0x0400
60#define PCI_STATUS_SIG_TARGET_ABORT 0x0800 /* Set on target abort */
61#define PCI_STATUS_REC_TARGET_ABORT 0x1000 /* Master ack of " */
62#define PCI_STATUS_REC_MASTER_ABORT 0x2000 /* Set on master abort */
63#define PCI_STATUS_SIG_SYSTEM_ERROR 0x4000 /* Set when we drive SERR */
64#define PCI_STATUS_DETECTED_PARITY 0x8000 /* Set on parity error */
65
66#define PCI_CLASS_REVISION 0x08 /* High 24 bits are class, low 8 revision */
67#define PCI_REVISION_ID 0x08 /* Revision ID */
68#define PCI_CLASS_PROG 0x09 /* Reg. Level Programming Interface */
69#define PCI_CLASS_DEVICE 0x0a /* Device class */
70#define PCI_CACHE_LINE_SIZE 0x0c /* 8 bits */
71#define PCI_LATENCY_TIMER 0x0d /* 8 bits */
72
73#define PCI_HEADER_TYPE 0x0e /* 8 bits */
74#define PCI_HEADER_TYPE_NORMAL 0x00
75#define PCI_HEADER_TYPE_BRIDGE 0x01
76#define PCI_HEADER_TYPE_CARDBUS 0x02
77#define PCI_HEADER_TYPE_MULTI_FUNCTION 0x80
78
79#define PCI_BIST 0x0f /* 8 bits */
80#define PCI_BIST_CODE_MASK 0x0f /* Return result */
81#define PCI_BIST_START 0x40 /* 1 to start BIST, 2 secs or less */
82#define PCI_BIST_CAPABLE 0x80 /* 1 if BIST capable */
83
84/*
85 * Base addresses specify locations in memory or I/O space.
86 * Decoded size can be determined by writing a value of
87 * 0xffffffff to the register, and reading it back. Only
88 * 1 bits are decoded.
89 */
90#define PCI_BASE_ADDRESS_0 0x10 /* 32 bits */
91#define PCI_BASE_ADDRESS_1 0x14 /* 32 bits [htype 0,1 only] */
92#define PCI_BASE_ADDRESS_2 0x18 /* 32 bits [htype 0 only] */
93#define PCI_BASE_ADDRESS_3 0x1c /* 32 bits */
94#define PCI_BASE_ADDRESS_4 0x20 /* 32 bits */
95#define PCI_BASE_ADDRESS_5 0x24 /* 32 bits */
96#define PCI_BASE_ADDRESS_SPACE 0x01 /* 0 = memory, 1 = I/O */
97#define PCI_BASE_ADDRESS_SPACE_IO 0x01
98#define PCI_BASE_ADDRESS_SPACE_MEMORY 0x00
99#define PCI_BASE_ADDRESS_MEM_TYPE_MASK 0x06
100#define PCI_BASE_ADDRESS_MEM_TYPE_32 0x00 /* 32 bit address */
101#define PCI_BASE_ADDRESS_MEM_TYPE_1M 0x02 /* Below 1M */
102#define PCI_BASE_ADDRESS_MEM_TYPE_64 0x04 /* 64 bit address */
103#define PCI_BASE_ADDRESS_MEM_PREFETCH 0x08 /* prefetchable? */
104#define PCI_BASE_ADDRESS_MEM_MASK (~0x0fUL)
105#define PCI_BASE_ADDRESS_IO_MASK (~0x03UL)
106/* bit 1 is reserved if address_space = 1 */
107
108/* Header type 0 (normal devices) */
109#define PCI_CARDBUS_CIS 0x28
110#define PCI_SUBSYSTEM_VENDOR_ID 0x2c
111#define PCI_SUBSYSTEM_ID 0x2e
112#define PCI_ROM_ADDRESS 0x30 /* Bits 31..11 address, 10..1 reserved */
113#define PCI_ROM_ADDRESS_ENABLE 0x01
114#define PCI_ROM_ADDRESS_MASK (~0x7ffUL)
115
116/* upper 24 bits are reserved */
117#define PCI_CAPABILITY_LIST_POINTER 0x34
118
119/* 0x38-0x3b are reserved */
120#define PCI_INTERRUPT_LINE 0x3c /* 8 bits */
121#define PCI_INTERRUPT_PIN 0x3d /* 8 bits */
122#define PCI_MIN_GNT 0x3e /* 8 bits */
123#define PCI_MAX_LAT 0x3f /* 8 bits */
124
125/* Header type 1 (PCI-to-PCI bridges) */
126#define PCI_PRIMARY_BUS 0x18 /* Primary bus number */
127#define PCI_SECONDARY_BUS 0x19 /* Secondary bus number */
128#define PCI_SUBORDINATE_BUS 0x1a /* Highest bus number behind the bridge */
129#define PCI_SEC_LATENCY_TIMER 0x1b /* Latency timer for secondary interface */
130#define PCI_IO_BASE 0x1c /* I/O range behind the bridge */
131#define PCI_IO_LIMIT 0x1d
132#define PCI_IO_RANGE_TYPE_MASK 0x0f /* I/O bridging type */
133#define PCI_IO_RANGE_TYPE_16 0x00
134#define PCI_IO_RANGE_TYPE_32 0x01
135#define PCI_IO_RANGE_MASK ~0x0f
136
137#define PCI_SEC_STATUS 0x1e /* Secondary status register, only bit 14 used */
138
139#define PCI_MEMORY_BASE 0x20 /* Memory range behind */
140#define PCI_MEMORY_LIMIT 0x22
141#define PCI_MEMORY_RANGE_TYPE_MASK 0x0f
142#define PCI_MEMORY_RANGE_MASK ~0x0f
143#define PCI_PREF_MEMORY_BASE 0x24 /* Prefetchable memory range behind */
144#define PCI_PREF_MEMORY_LIMIT 0x26
145#define PCI_PREF_RANGE_TYPE_MASK 0x0f
146#define PCI_PREF_RANGE_TYPE_32 0x00
147#define PCI_PREF_RANGE_TYPE_64 0x01
148#define PCI_PREF_RANGE_MASK ~0x0f
149#define PCI_PREF_BASE_UPPER32 0x28 /* Upper half of prefetchable memory */
150#define PCI_PREF_LIMIT_UPPER32 0x2c
151#define PCI_IO_BASE_UPPER16 0x30 /* Upper half of I/O addresses */
152#define PCI_IO_LIMIT_UPPER16 0x32
153/* 0x34-0x3b is reserved */
154#define PCI_ROM_ADDRESS1 0x38 /* Same as PCI_ROM_ADDRESS, but for htype 1 */
155/* 0x3c-0x3d are same as for htype 0 */
156#define PCI_BRIDGE_CONTROL 0x3e
157#define PCI_BRIDGE_CTL_PARITY 0x01 /* Enable parity detection on secondary interface */
158#define PCI_BRIDGE_CTL_SERR 0x02 /* The same for SERR forwarding */
159#define PCI_BRIDGE_CTL_NO_ISA 0x04 /* Disable bridging of ISA ports */
160#define PCI_BRIDGE_CTL_VGA 0x08 /* Forward VGA addresses */
161#define PCI_BRIDGE_CTL_MASTER_ABORT 0x20 /* Report master aborts */
162#define PCI_BRIDGE_CTL_BUS_RESET 0x40 /* Secondary bus reset */
163#define PCI_BRIDGE_CTL_FAST_BACK 0x80 /* Fast Back2Back enabled */
164 /* on secondary interface */
165
166/* Header type 2 (CardBus bridges) */
167/* 0x14-0x15 reserved */
168#define PCI_CB_SEC_STATUS 0x16 /* Secondary status */
169#define PCI_CB_PRIMARY_BUS 0x18 /* PCI bus number */
170#define PCI_CB_CARD_BUS 0x19 /* CardBus bus number */
171#define PCI_CB_SUBORDINATE_BUS 0x1a /* Subordinate bus number */
172#define PCI_CB_LATENCY_TIMER 0x1b /* CardBus latency timer */
173#define PCI_CB_MEMORY_BASE_0 0x1c
174#define PCI_CB_MEMORY_LIMIT_0 0x20
175#define PCI_CB_MEMORY_BASE_1 0x24
176#define PCI_CB_MEMORY_LIMIT_1 0x28
177#define PCI_CB_IO_BASE_0 0x2c
178#define PCI_CB_IO_BASE_0_HI 0x2e
179#define PCI_CB_IO_LIMIT_0 0x30
180#define PCI_CB_IO_LIMIT_0_HI 0x32
181#define PCI_CB_IO_BASE_1 0x34
182#define PCI_CB_IO_BASE_1_HI 0x36
183#define PCI_CB_IO_LIMIT_1 0x38
184#define PCI_CB_IO_LIMIT_1_HI 0x3a
185#define PCI_CB_IO_RANGE_MASK ~0x03
186/* 0x3c-0x3d are same as for htype 0 */
187
188#define PCI_CB_BRIDGE_CONTROL 0x3e
189#define PCI_CB_BRIDGE_CTL_PARITY 0x01 /* Similar to standard bridge */
190 /* control register */
191#define PCI_CB_BRIDGE_CTL_SERR 0x02
192#define PCI_CB_BRIDGE_CTL_ISA 0x04
193#define PCI_CB_BRIDGE_CTL_VGA 0x08
194#define PCI_CB_BRIDGE_CTL_MASTER_ABORT 0x20
195#define PCI_CB_BRIDGE_CTL_CB_RESET 0x40 /* CardBus reset */
196#define PCI_CB_BRIDGE_CTL_16BIT_INT 0x80 /* Enable interrupt for */
197 /* 16-bit cards */
198#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM0 0x100 /* Prefetch enable for */
199 /* both memory regions */
200#define PCI_CB_BRIDGE_CTL_PREFETCH_MEM1 0x200
201#define PCI_CB_BRIDGE_CTL_POST_WRITES 0x400
202
203#define PCI_CB_SUBSYSTEM_VENDOR_ID 0x40
204#define PCI_CB_SUBSYSTEM_ID 0x42
205
206/* 16-bit PC Card legacy mode base address (ExCa) */
207#define PCI_CB_LEGACY_MODE_BASE 0x44
208
209/* 0x48-0x7f reserved */
210
211/* Device classes and subclasses */
212
213#define PCI_CLASS_NOT_DEFINED 0x0000
214#define PCI_CLASS_NOT_DEFINED_VGA 0x0001
215
216#define PCI_BASE_CLASS_STORAGE 0x01
217#define PCI_CLASS_STORAGE_SCSI 0x0100
218#define PCI_CLASS_STORAGE_IDE 0x0101
219#define PCI_CLASS_STORAGE_FLOPPY 0x0102
220#define PCI_CLASS_STORAGE_IPI 0x0103
221#define PCI_CLASS_STORAGE_RAID 0x0104
222#define PCI_CLASS_STORAGE_OTHER 0x0180
223
224#define PCI_BASE_CLASS_NETWORK 0x02
225#define PCI_CLASS_NETWORK_ETHERNET 0x0200
226#define PCI_CLASS_NETWORK_TOKEN_RING 0x0201
227#define PCI_CLASS_NETWORK_FDDI 0x0202
228#define PCI_CLASS_NETWORK_ATM 0x0203
229#define PCI_CLASS_NETWORK_OTHER 0x0280
230
231#define PCI_BASE_CLASS_DISPLAY 0x03
232#define PCI_CLASS_DISPLAY_VGA 0x0300
233#define PCI_CLASS_DISPLAY_XGA 0x0301
234#define PCI_CLASS_DISPLAY_OTHER 0x0380
235
236#define PCI_BASE_CLASS_MULTIMEDIA 0x04
237#define PCI_CLASS_MULTIMEDIA_VIDEO 0x0400
238#define PCI_CLASS_MULTIMEDIA_AUDIO 0x0401
239#define PCI_CLASS_MULTIMEDIA_OTHER 0x0480
240
241#define PCI_BASE_CLASS_MEMORY 0x05
242#define PCI_CLASS_MEMORY_RAM 0x0500
243#define PCI_CLASS_MEMORY_FLASH 0x0501
244#define PCI_CLASS_MEMORY_OTHER 0x0580
245
246#define PCI_BASE_CLASS_BRIDGE 0x06
247#define PCI_CLASS_BRIDGE_HOST 0x0600
248#define PCI_CLASS_BRIDGE_ISA 0x0601
249#define PCI_CLASS_BRIDGE_EISA 0x0602
250#define PCI_CLASS_BRIDGE_MC 0x0603
251#define PCI_CLASS_BRIDGE_PCI 0x0604
252#define PCI_CLASS_BRIDGE_PCMCIA 0x0605
253#define PCI_CLASS_BRIDGE_NUBUS 0x0606
254#define PCI_CLASS_BRIDGE_CARDBUS 0x0607
255#define PCI_CLASS_BRIDGE_OTHER 0x0680
256
257#define PCI_BASE_CLASS_COMMUNICATION 0x07
258#define PCI_CLASS_COMMUNICATION_SERIAL 0x0700
259#define PCI_CLASS_COMMUNICATION_PARALLEL 0x0701
260#define PCI_CLASS_COMMUNICATION_OTHER 0x0780
261
262#define PCI_BASE_CLASS_SYSTEM 0x08
263#define PCI_CLASS_SYSTEM_PIC 0x0800
264#define PCI_CLASS_SYSTEM_DMA 0x0801
265#define PCI_CLASS_SYSTEM_TIMER 0x0802
266#define PCI_CLASS_SYSTEM_RTC 0x0803
267#define PCI_CLASS_SYSTEM_OTHER 0x0880
268
269#define PCI_BASE_CLASS_INPUT 0x09
270#define PCI_CLASS_INPUT_KEYBOARD 0x0900
271#define PCI_CLASS_INPUT_PEN 0x0901
272#define PCI_CLASS_INPUT_MOUSE 0x0902
273#define PCI_CLASS_INPUT_OTHER 0x0980
274
275#define PCI_BASE_CLASS_DOCKING 0x0a
276#define PCI_CLASS_DOCKING_GENERIC 0x0a00
277#define PCI_CLASS_DOCKING_OTHER 0x0a01
278
279#define PCI_BASE_CLASS_PROCESSOR 0x0b
280#define PCI_CLASS_PROCESSOR_386 0x0b00
281#define PCI_CLASS_PROCESSOR_486 0x0b01
282#define PCI_CLASS_PROCESSOR_PENTIUM 0x0b02
283#define PCI_CLASS_PROCESSOR_ALPHA 0x0b10
284#define PCI_CLASS_PROCESSOR_POWERPC 0x0b20
285#define PCI_CLASS_PROCESSOR_CO 0x0b40
286
287#define PCI_BASE_CLASS_SERIAL 0x0c
288#define PCI_CLASS_SERIAL_FIREWIRE 0x0c00
289#define PCI_CLASS_SERIAL_ACCESS 0x0c01
290#define PCI_CLASS_SERIAL_SSA 0x0c02
291#define PCI_CLASS_SERIAL_USB 0x0c03
292#define PCI_CLASS_SERIAL_FIBER 0x0c04
293
294#define PCI_CLASS_OTHERS 0xff
295
296/*
297 * Vendor and card ID's: sort these numerically according to vendor
298 * (and according to card ID within vendor). Send all updates to
299 * <linux-pcisupport@cck.uni-kl.de>.
300 */
301#define PCI_VENDOR_ID_COMPAQ 0x0e11
302#define PCI_DEVICE_ID_COMPAQ_1280 0x3033
303#define PCI_DEVICE_ID_COMPAQ_TRIFLEX 0x4000
304#define PCI_DEVICE_ID_COMPAQ_SMART2P 0xae10
305#define PCI_DEVICE_ID_COMPAQ_NETEL100 0xae32
306#define PCI_DEVICE_ID_COMPAQ_NETEL10 0xae34
307#define PCI_DEVICE_ID_COMPAQ_NETFLEX3I 0xae35
308#define PCI_DEVICE_ID_COMPAQ_NETEL100D 0xae40
309#define PCI_DEVICE_ID_COMPAQ_NETEL100PI 0xae43
310#define PCI_DEVICE_ID_COMPAQ_NETEL100I 0xb011
311#define PCI_DEVICE_ID_COMPAQ_THUNDER 0xf130
312#define PCI_DEVICE_ID_COMPAQ_NETFLEX3B 0xf150
313
314#define PCI_VENDOR_ID_NCR 0x1000
315#define PCI_DEVICE_ID_NCR_53C810 0x0001
316#define PCI_DEVICE_ID_NCR_53C820 0x0002
317#define PCI_DEVICE_ID_NCR_53C825 0x0003
318#define PCI_DEVICE_ID_NCR_53C815 0x0004
319#define PCI_DEVICE_ID_NCR_53C860 0x0006
320#define PCI_DEVICE_ID_NCR_53C896 0x000b
321#define PCI_DEVICE_ID_NCR_53C895 0x000c
322#define PCI_DEVICE_ID_NCR_53C885 0x000d
323#define PCI_DEVICE_ID_NCR_53C875 0x000f
324#define PCI_DEVICE_ID_NCR_53C875J 0x008f
325
326#define PCI_VENDOR_ID_ATI 0x1002
327#define PCI_DEVICE_ID_ATI_68800 0x4158
328#define PCI_DEVICE_ID_ATI_215CT222 0x4354
329#define PCI_DEVICE_ID_ATI_210888CX 0x4358
330#define PCI_DEVICE_ID_ATI_215GB 0x4742
331#define PCI_DEVICE_ID_ATI_215GD 0x4744
332#define PCI_DEVICE_ID_ATI_215GI 0x4749
333#define PCI_DEVICE_ID_ATI_215GP 0x4750
334#define PCI_DEVICE_ID_ATI_215GQ 0x4751
335#define PCI_DEVICE_ID_ATI_215GT 0x4754
336#define PCI_DEVICE_ID_ATI_215GTB 0x4755
337#define PCI_DEVICE_ID_ATI_210888GX 0x4758
338#define PCI_DEVICE_ID_ATI_215LG 0x4c47
339#define PCI_DEVICE_ID_ATI_264LT 0x4c54
340#define PCI_DEVICE_ID_ATI_264VT 0x5654
341
342#define PCI_VENDOR_ID_VLSI 0x1004
343#define PCI_DEVICE_ID_VLSI_82C592 0x0005
344#define PCI_DEVICE_ID_VLSI_82C593 0x0006
345#define PCI_DEVICE_ID_VLSI_82C594 0x0007
346#define PCI_DEVICE_ID_VLSI_82C597 0x0009
347#define PCI_DEVICE_ID_VLSI_82C541 0x000c
348#define PCI_DEVICE_ID_VLSI_82C543 0x000d
349#define PCI_DEVICE_ID_VLSI_82C532 0x0101
350#define PCI_DEVICE_ID_VLSI_82C534 0x0102
351#define PCI_DEVICE_ID_VLSI_82C535 0x0104
352#define PCI_DEVICE_ID_VLSI_82C147 0x0105
353#define PCI_DEVICE_ID_VLSI_VAS96011 0x0702
354
355#define PCI_VENDOR_ID_ADL 0x1005
356#define PCI_DEVICE_ID_ADL_2301 0x2301
357
358#define PCI_VENDOR_ID_NS 0x100b
359#define PCI_DEVICE_ID_NS_87415 0x0002
360#define PCI_DEVICE_ID_NS_87410 0xd001
361
362#define PCI_VENDOR_ID_TSENG 0x100c
363#define PCI_DEVICE_ID_TSENG_W32P_2 0x3202
364#define PCI_DEVICE_ID_TSENG_W32P_b 0x3205
365#define PCI_DEVICE_ID_TSENG_W32P_c 0x3206
366#define PCI_DEVICE_ID_TSENG_W32P_d 0x3207
367#define PCI_DEVICE_ID_TSENG_ET6000 0x3208
368
369#define PCI_VENDOR_ID_WEITEK 0x100e
370#define PCI_DEVICE_ID_WEITEK_P9000 0x9001
371#define PCI_DEVICE_ID_WEITEK_P9100 0x9100
372
373#define PCI_VENDOR_ID_DEC 0x1011
374#define PCI_DEVICE_ID_DEC_BRD 0x0001
375#define PCI_DEVICE_ID_DEC_TULIP 0x0002
376#define PCI_DEVICE_ID_DEC_TGA 0x0004
377#define PCI_DEVICE_ID_DEC_TULIP_FAST 0x0009
378#define PCI_DEVICE_ID_DEC_TGA2 0x000D
379#define PCI_DEVICE_ID_DEC_FDDI 0x000F
380#define PCI_DEVICE_ID_DEC_TULIP_PLUS 0x0014
381#define PCI_DEVICE_ID_DEC_21142 0x0019
382#define PCI_DEVICE_ID_DEC_21143 0x0019
383#define PCI_DEVICE_ID_DEC_21052 0x0021
384#define PCI_DEVICE_ID_DEC_21150 0x0022
385#define PCI_DEVICE_ID_DEC_21152 0x0024
386
387#define PCI_VENDOR_ID_CIRRUS 0x1013
388#define PCI_DEVICE_ID_CIRRUS_7548 0x0038
389#define PCI_DEVICE_ID_CIRRUS_5430 0x00a0
390#define PCI_DEVICE_ID_CIRRUS_5434_4 0x00a4
391#define PCI_DEVICE_ID_CIRRUS_5434_8 0x00a8
392#define PCI_DEVICE_ID_CIRRUS_5436 0x00ac
393#define PCI_DEVICE_ID_CIRRUS_5446 0x00b8
394#define PCI_DEVICE_ID_CIRRUS_5480 0x00bc
395#define PCI_DEVICE_ID_CIRRUS_5464 0x00d4
396#define PCI_DEVICE_ID_CIRRUS_5465 0x00d6
397#define PCI_DEVICE_ID_CIRRUS_6729 0x1100
398#define PCI_DEVICE_ID_CIRRUS_6832 0x1110
399#define PCI_DEVICE_ID_CIRRUS_7542 0x1200
400#define PCI_DEVICE_ID_CIRRUS_7543 0x1202
401#define PCI_DEVICE_ID_CIRRUS_7541 0x1204
402
403#define PCI_VENDOR_ID_IBM 0x1014
404#define PCI_DEVICE_ID_IBM_FIRE_CORAL 0x000a
405#define PCI_DEVICE_ID_IBM_TR 0x0018
406#define PCI_DEVICE_ID_IBM_82G2675 0x001d
407#define PCI_DEVICE_ID_IBM_MCA 0x0020
408#define PCI_DEVICE_ID_IBM_82351 0x0022
409#define PCI_DEVICE_ID_IBM_SERVERAID 0x002e
410#define PCI_DEVICE_ID_IBM_TR_WAKE 0x003e
411#define PCI_DEVICE_ID_IBM_MPIC 0x0046
412#define PCI_DEVICE_ID_IBM_3780IDSP 0x007d
413#define PCI_DEVICE_ID_IBM_MPIC_2 0xffff
414
415#define PCI_VENDOR_ID_WD 0x101c
416#define PCI_DEVICE_ID_WD_7197 0x3296
417
418#define PCI_VENDOR_ID_AMD 0x1022
419#define PCI_DEVICE_ID_AMD_LANCE 0x2000
420#define PCI_DEVICE_ID_AMD_SCSI 0x2020
421
422#define PCI_VENDOR_ID_TRIDENT 0x1023
423#define PCI_DEVICE_ID_TRIDENT_9397 0x9397
424#define PCI_DEVICE_ID_TRIDENT_9420 0x9420
425#define PCI_DEVICE_ID_TRIDENT_9440 0x9440
426#define PCI_DEVICE_ID_TRIDENT_9660 0x9660
427#define PCI_DEVICE_ID_TRIDENT_9750 0x9750
428
429#define PCI_VENDOR_ID_AI 0x1025
430#define PCI_DEVICE_ID_AI_M1435 0x1435
431
432#define PCI_VENDOR_ID_MATROX 0x102B
433#define PCI_DEVICE_ID_MATROX_MGA_2 0x0518
434#define PCI_DEVICE_ID_MATROX_MIL 0x0519
435#define PCI_DEVICE_ID_MATROX_MYS 0x051A
436#define PCI_DEVICE_ID_MATROX_MIL_2 0x051b
437#define PCI_DEVICE_ID_MATROX_MIL_2_AGP 0x051f
438#define PCI_DEVICE_ID_MATROX_MGA_IMP 0x0d10
439
440#define PCI_VENDOR_ID_CT 0x102c
441#define PCI_DEVICE_ID_CT_65545 0x00d8
442#define PCI_DEVICE_ID_CT_65548 0x00dc
443#define PCI_DEVICE_ID_CT_65550 0x00e0
444#define PCI_DEVICE_ID_CT_65554 0x00e4
445#define PCI_DEVICE_ID_CT_65555 0x00e5
446
447#define PCI_VENDOR_ID_MIRO 0x1031
448#define PCI_DEVICE_ID_MIRO_36050 0x5601
449
450#define PCI_VENDOR_ID_NEC 0x1033
451#define PCI_DEVICE_ID_NEC_PCX2 0x0046
452
453#define PCI_VENDOR_ID_FD 0x1036
454#define PCI_DEVICE_ID_FD_36C70 0x0000
455
456#define PCI_VENDOR_ID_SI 0x1039
457#define PCI_DEVICE_ID_SI_5591_AGP 0x0001
458#define PCI_DEVICE_ID_SI_6202 0x0002
459#define PCI_DEVICE_ID_SI_503 0x0008
460#define PCI_DEVICE_ID_SI_ACPI 0x0009
461#define PCI_DEVICE_ID_SI_5597_VGA 0x0200
462#define PCI_DEVICE_ID_SI_6205 0x0205
463#define PCI_DEVICE_ID_SI_501 0x0406
464#define PCI_DEVICE_ID_SI_496 0x0496
465#define PCI_DEVICE_ID_SI_601 0x0601
466#define PCI_DEVICE_ID_SI_5107 0x5107
467#define PCI_DEVICE_ID_SI_5511 0x5511
468#define PCI_DEVICE_ID_SI_5513 0x5513
469#define PCI_DEVICE_ID_SI_5571 0x5571
470#define PCI_DEVICE_ID_SI_5591 0x5591
471#define PCI_DEVICE_ID_SI_5597 0x5597
472#define PCI_DEVICE_ID_SI_7001 0x7001
473
474#define PCI_VENDOR_ID_HP 0x103c
475#define PCI_DEVICE_ID_HP_J2585A 0x1030
476#define PCI_DEVICE_ID_HP_J2585B 0x1031
477
478#define PCI_VENDOR_ID_PCTECH 0x1042
479#define PCI_DEVICE_ID_PCTECH_RZ1000 0x1000
480#define PCI_DEVICE_ID_PCTECH_RZ1001 0x1001
481#define PCI_DEVICE_ID_PCTECH_SAMURAI_0 0x3000
482#define PCI_DEVICE_ID_PCTECH_SAMURAI_1 0x3010
483#define PCI_DEVICE_ID_PCTECH_SAMURAI_IDE 0x3020
484
485#define PCI_VENDOR_ID_DPT 0x1044
486#define PCI_DEVICE_ID_DPT 0xa400
487
488#define PCI_VENDOR_ID_OPTI 0x1045
489#define PCI_DEVICE_ID_OPTI_92C178 0xc178
490#define PCI_DEVICE_ID_OPTI_82C557 0xc557
491#define PCI_DEVICE_ID_OPTI_82C558 0xc558
492#define PCI_DEVICE_ID_OPTI_82C621 0xc621
493#define PCI_DEVICE_ID_OPTI_82C700 0xc700
494#define PCI_DEVICE_ID_OPTI_82C701 0xc701
495#define PCI_DEVICE_ID_OPTI_82C814 0xc814
496#define PCI_DEVICE_ID_OPTI_82C822 0xc822
497#define PCI_DEVICE_ID_OPTI_82C825 0xd568
498
499#define PCI_VENDOR_ID_SGS 0x104a
500#define PCI_DEVICE_ID_SGS_2000 0x0008
501#define PCI_DEVICE_ID_SGS_1764 0x0009
502
503#define PCI_VENDOR_ID_BUSLOGIC 0x104B
504#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER_NC 0x0140
505#define PCI_DEVICE_ID_BUSLOGIC_MULTIMASTER 0x1040
506#define PCI_DEVICE_ID_BUSLOGIC_FLASHPOINT 0x8130
507
508#define PCI_VENDOR_ID_TI 0x104c
509#define PCI_DEVICE_ID_TI_TVP4010 0x3d04
510#define PCI_DEVICE_ID_TI_TVP4020 0x3d07
511#define PCI_DEVICE_ID_TI_PCI1130 0xac12
512#define PCI_DEVICE_ID_TI_PCI1031 0xac13
513#define PCI_DEVICE_ID_TI_PCI1131 0xac15
514#define PCI_DEVICE_ID_TI_PCI1250 0xac16
515#define PCI_DEVICE_ID_TI_PCI1220 0xac17
516
517#define PCI_VENDOR_ID_OAK 0x104e
518#define PCI_DEVICE_ID_OAK_OTI107 0x0107
519
520#define PCI_VENDOR_ID_WINBOND2 0x1050
521#define PCI_DEVICE_ID_WINBOND2_89C940 0x0940
522
523#define PCI_VENDOR_ID_MOTOROLA 0x1057
524#define PCI_DEVICE_ID_MOTOROLA_MPC105 0x0001
525#define PCI_DEVICE_ID_MOTOROLA_MPC106 0x0002
526#define PCI_DEVICE_ID_MOTOROLA_RAVEN 0x4801
527#define PCI_DEVICE_ID_MOTOROLA_HAWK 0x4803
528
529#define PCI_VENDOR_ID_PROMISE 0x105a
530#define PCI_DEVICE_ID_PROMISE_20246 0x4d33
531#define PCI_DEVICE_ID_PROMISE_5300 0x5300
532
533#define PCI_VENDOR_ID_N9 0x105d
534#define PCI_DEVICE_ID_N9_I128 0x2309
535#define PCI_DEVICE_ID_N9_I128_2 0x2339
536#define PCI_DEVICE_ID_N9_I128_T2R 0x493d
537
538#define PCI_VENDOR_ID_UMC 0x1060
539#define PCI_DEVICE_ID_UMC_UM8673F 0x0101
540#define PCI_DEVICE_ID_UMC_UM8891A 0x0891
541#define PCI_DEVICE_ID_UMC_UM8886BF 0x673a
542#define PCI_DEVICE_ID_UMC_UM8886A 0x886a
543#define PCI_DEVICE_ID_UMC_UM8881F 0x8881
544#define PCI_DEVICE_ID_UMC_UM8886F 0x8886
545#define PCI_DEVICE_ID_UMC_UM9017F 0x9017
546#define PCI_DEVICE_ID_UMC_UM8886N 0xe886
547#define PCI_DEVICE_ID_UMC_UM8891N 0xe891
548
549#define PCI_VENDOR_ID_X 0x1061
550#define PCI_DEVICE_ID_X_AGX016 0x0001
551
552#define PCI_VENDOR_ID_PICOP 0x1066
553#define PCI_DEVICE_ID_PICOP_PT86C52X 0x0001
554#define PCI_DEVICE_ID_PICOP_PT80C524 0x8002
555
556#define PCI_VENDOR_ID_APPLE 0x106b
557#define PCI_DEVICE_ID_APPLE_BANDIT 0x0001
558#define PCI_DEVICE_ID_APPLE_GC 0x0002
559#define PCI_DEVICE_ID_APPLE_HYDRA 0x000e
560
561#define PCI_VENDOR_ID_NEXGEN 0x1074
562#define PCI_DEVICE_ID_NEXGEN_82C501 0x4e78
563
564#define PCI_VENDOR_ID_QLOGIC 0x1077
565#define PCI_DEVICE_ID_QLOGIC_ISP1020 0x1020
566#define PCI_DEVICE_ID_QLOGIC_ISP1022 0x1022
567
568#define PCI_VENDOR_ID_CYRIX 0x1078
569#define PCI_DEVICE_ID_CYRIX_5510 0x0000
570#define PCI_DEVICE_ID_CYRIX_PCI_MASTER 0x0001
571#define PCI_DEVICE_ID_CYRIX_5520 0x0002
572#define PCI_DEVICE_ID_CYRIX_5530_LEGACY 0x0100
573#define PCI_DEVICE_ID_CYRIX_5530_SMI 0x0101
574#define PCI_DEVICE_ID_CYRIX_5530_IDE 0x0102
575#define PCI_DEVICE_ID_CYRIX_5530_AUDIO 0x0103
576#define PCI_DEVICE_ID_CYRIX_5530_VIDEO 0x0104
577
578#define PCI_VENDOR_ID_LEADTEK 0x107d
579#define PCI_DEVICE_ID_LEADTEK_805 0x0000
580
581#define PCI_VENDOR_ID_CONTAQ 0x1080
582#define PCI_DEVICE_ID_CONTAQ_82C599 0x0600
583#define PCI_DEVICE_ID_CONTAQ_82C693 0xc693
584
585#define PCI_VENDOR_ID_FOREX 0x1083
586
587#define PCI_VENDOR_ID_OLICOM 0x108d
588#define PCI_DEVICE_ID_OLICOM_OC3136 0x0001
589#define PCI_DEVICE_ID_OLICOM_OC2315 0x0011
590#define PCI_DEVICE_ID_OLICOM_OC2325 0x0012
591#define PCI_DEVICE_ID_OLICOM_OC2183 0x0013
592#define PCI_DEVICE_ID_OLICOM_OC2326 0x0014
593#define PCI_DEVICE_ID_OLICOM_OC6151 0x0021
594
595#define PCI_VENDOR_ID_SUN 0x108e
596#define PCI_DEVICE_ID_SUN_EBUS 0x1000
597#define PCI_DEVICE_ID_SUN_HAPPYMEAL 0x1001
598#define PCI_DEVICE_ID_SUN_SIMBA 0x5000
599#define PCI_DEVICE_ID_SUN_PBM 0x8000
600#define PCI_DEVICE_ID_SUN_SABRE 0xa000
601
602#define PCI_VENDOR_ID_CMD 0x1095
603#define PCI_DEVICE_ID_CMD_640 0x0640
604#define PCI_DEVICE_ID_CMD_643 0x0643
605#define PCI_DEVICE_ID_CMD_646 0x0646
606#define PCI_DEVICE_ID_CMD_647 0x0647
607#define PCI_DEVICE_ID_CMD_670 0x0670
608
609#define PCI_VENDOR_ID_VISION 0x1098
610#define PCI_DEVICE_ID_VISION_QD8500 0x0001
611#define PCI_DEVICE_ID_VISION_QD8580 0x0002
612
613#define PCI_VENDOR_ID_BROOKTREE 0x109e
614#define PCI_DEVICE_ID_BROOKTREE_848 0x0350
615#define PCI_DEVICE_ID_BROOKTREE_849A 0x0351
616#define PCI_DEVICE_ID_BROOKTREE_8474 0x8474
617
618#define PCI_VENDOR_ID_SIERRA 0x10a8
619#define PCI_DEVICE_ID_SIERRA_STB 0x0000
620
621#define PCI_VENDOR_ID_ACC 0x10aa
622#define PCI_DEVICE_ID_ACC_2056 0x0000
623
624#define PCI_VENDOR_ID_WINBOND 0x10ad
625#define PCI_DEVICE_ID_WINBOND_83769 0x0001
626#define PCI_DEVICE_ID_WINBOND_82C105 0x0105
627#define PCI_DEVICE_ID_WINBOND_83C553 0x0565
628
629#define PCI_VENDOR_ID_DATABOOK 0x10b3
630#define PCI_DEVICE_ID_DATABOOK_87144 0xb106
631
632#define PCI_VENDOR_ID_PLX 0x10b5
633#define PCI_DEVICE_ID_PLX_9050 0x9050
634#define PCI_DEVICE_ID_PLX_9060 0x9060
635#define PCI_DEVICE_ID_PLX_9060ES 0x906E
636#define PCI_DEVICE_ID_PLX_9060SD 0x906D
637#define PCI_DEVICE_ID_PLX_9080 0x9080
638
639#define PCI_VENDOR_ID_PLX2 0x3388
640#define PCI_DEVICE_ID_PLX2_PCI6154_HB2 0x0026
641
642#define PCI_VENDOR_ID_MADGE 0x10b6
643#define PCI_DEVICE_ID_MADGE_MK2 0x0002
644#define PCI_DEVICE_ID_MADGE_C155S 0x1001
645
646#define PCI_VENDOR_ID_3COM 0x10b7
647#define PCI_DEVICE_ID_3COM_3C339 0x3390
648#define PCI_DEVICE_ID_3COM_3C590 0x5900
649#define PCI_DEVICE_ID_3COM_3C595TX 0x5950
650#define PCI_DEVICE_ID_3COM_3C595T4 0x5951
651#define PCI_DEVICE_ID_3COM_3C595MII 0x5952
652#define PCI_DEVICE_ID_3COM_3C900TPO 0x9000
653#define PCI_DEVICE_ID_3COM_3C900COMBO 0x9001
654#define PCI_DEVICE_ID_3COM_3C905TX 0x9050
655#define PCI_DEVICE_ID_3COM_3C905T4 0x9051
656#define PCI_DEVICE_ID_3COM_3C905B_TX 0x9055
657
658#define PCI_VENDOR_ID_SMC 0x10b8
659#define PCI_DEVICE_ID_SMC_EPIC100 0x0005
660
661#define PCI_VENDOR_ID_AL 0x10b9
662#define PCI_DEVICE_ID_AL_M1445 0x1445
663#define PCI_DEVICE_ID_AL_M1449 0x1449
664#define PCI_DEVICE_ID_AL_M1451 0x1451
665#define PCI_DEVICE_ID_AL_M1461 0x1461
666#define PCI_DEVICE_ID_AL_M1489 0x1489
667#define PCI_DEVICE_ID_AL_M1511 0x1511
668#define PCI_DEVICE_ID_AL_M1513 0x1513
669#define PCI_DEVICE_ID_AL_M1521 0x1521
670#define PCI_DEVICE_ID_AL_M1523 0x1523
671#define PCI_DEVICE_ID_AL_M1531 0x1531
672#define PCI_DEVICE_ID_AL_M1533 0x1533
673#define PCI_DEVICE_ID_AL_M3307 0x3307
674#define PCI_DEVICE_ID_AL_M4803 0x5215
675#define PCI_DEVICE_ID_AL_M5219 0x5219
676#define PCI_DEVICE_ID_AL_M5229 0x5229
677#define PCI_DEVICE_ID_AL_M5237 0x5237
678#define PCI_DEVICE_ID_AL_M7101 0x7101
679
680#define PCI_VENDOR_ID_MITSUBISHI 0x10ba
681
682#define PCI_VENDOR_ID_SURECOM 0x10bd
683#define PCI_DEVICE_ID_SURECOM_NE34 0x0e34
684
685#define PCI_VENDOR_ID_NEOMAGIC 0x10c8
686#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2070 0x0001
687#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128V 0x0002
688#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_128ZV 0x0003
689#define PCI_DEVICE_ID_NEOMAGIC_MAGICGRAPH_NM2160 0x0004
690
691#define PCI_VENDOR_ID_ASP 0x10cd
692#define PCI_DEVICE_ID_ASP_ABP940 0x1200
693#define PCI_DEVICE_ID_ASP_ABP940U 0x1300
694#define PCI_DEVICE_ID_ASP_ABP940UW 0x2300
695
696#define PCI_VENDOR_ID_MACRONIX 0x10d9
697#define PCI_DEVICE_ID_MACRONIX_MX98713 0x0512
698#define PCI_DEVICE_ID_MACRONIX_MX987x5 0x0531
699
700#define PCI_VENDOR_ID_CERN 0x10dc
701#define PCI_DEVICE_ID_CERN_SPSB_PMC 0x0001
702#define PCI_DEVICE_ID_CERN_SPSB_PCI 0x0002
703#define PCI_DEVICE_ID_CERN_HIPPI_DST 0x0021
704#define PCI_DEVICE_ID_CERN_HIPPI_SRC 0x0022
705
706#define PCI_VENDOR_ID_NVIDIA 0x10de
707
708#define PCI_VENDOR_ID_IMS 0x10e0
709#define PCI_DEVICE_ID_IMS_8849 0x8849
710
711#define PCI_VENDOR_ID_TEKRAM2 0x10e1
712#define PCI_DEVICE_ID_TEKRAM2_690c 0x690c
713
714#define PCI_VENDOR_ID_TUNDRA 0x10e3
715#define PCI_DEVICE_ID_TUNDRA_CA91C042 0x0000
716
717#define PCI_VENDOR_ID_AMCC 0x10e8
718#define PCI_DEVICE_ID_AMCC_MYRINET 0x8043
719#define PCI_DEVICE_ID_AMCC_PARASTATION 0x8062
720#define PCI_DEVICE_ID_AMCC_S5933 0x807d
721#define PCI_DEVICE_ID_AMCC_S5933_HEPC3 0x809c
722
723#define PCI_VENDOR_ID_INTERG 0x10ea
724#define PCI_DEVICE_ID_INTERG_1680 0x1680
725#define PCI_DEVICE_ID_INTERG_1682 0x1682
726
727#define PCI_VENDOR_ID_REALTEK 0x10ec
728#define PCI_DEVICE_ID_REALTEK_8029 0x8029
729#define PCI_DEVICE_ID_REALTEK_8129 0x8129
730#define PCI_DEVICE_ID_REALTEK_8139 0x8139
731
732#define PCI_VENDOR_ID_TRUEVISION 0x10fa
733#define PCI_DEVICE_ID_TRUEVISION_T1000 0x000c
734
735#define PCI_VENDOR_ID_INIT 0x1101
736#define PCI_DEVICE_ID_INIT_320P 0x9100
737#define PCI_DEVICE_ID_INIT_360P 0x9500
738
739#define PCI_VENDOR_ID_TTI 0x1103
740#define PCI_DEVICE_ID_TTI_HPT343 0x0003
741
742#define PCI_VENDOR_ID_VIA 0x1106
743#define PCI_DEVICE_ID_VIA_82C505 0x0505
744#define PCI_DEVICE_ID_VIA_82C561 0x0561
745#define PCI_DEVICE_ID_VIA_82C586_1 0x0571
746#define PCI_DEVICE_ID_VIA_82C576 0x0576
747#define PCI_DEVICE_ID_VIA_82C585 0x0585
748#define PCI_DEVICE_ID_VIA_82C586_0 0x0586
749#define PCI_DEVICE_ID_VIA_82C595 0x0595
750#define PCI_DEVICE_ID_VIA_82C597_0 0x0597
751#define PCI_DEVICE_ID_VIA_82C926 0x0926
752#define PCI_DEVICE_ID_VIA_82C416 0x1571
753#define PCI_DEVICE_ID_VIA_82C595_97 0x1595
754#define PCI_DEVICE_ID_VIA_82C586_2 0x3038
755#define PCI_DEVICE_ID_VIA_82C586_3 0x3040
756#define PCI_DEVICE_ID_VIA_86C100A 0x6100
757#define PCI_DEVICE_ID_VIA_82C597_1 0x8597
758
759#define PCI_VENDOR_ID_VORTEX 0x1119
760#define PCI_DEVICE_ID_VORTEX_GDT60x0 0x0000
761#define PCI_DEVICE_ID_VORTEX_GDT6000B 0x0001
762#define PCI_DEVICE_ID_VORTEX_GDT6x10 0x0002
763#define PCI_DEVICE_ID_VORTEX_GDT6x20 0x0003
764#define PCI_DEVICE_ID_VORTEX_GDT6530 0x0004
765#define PCI_DEVICE_ID_VORTEX_GDT6550 0x0005
766#define PCI_DEVICE_ID_VORTEX_GDT6x17 0x0006
767#define PCI_DEVICE_ID_VORTEX_GDT6x27 0x0007
768#define PCI_DEVICE_ID_VORTEX_GDT6537 0x0008
769#define PCI_DEVICE_ID_VORTEX_GDT6557 0x0009
770#define PCI_DEVICE_ID_VORTEX_GDT6x15 0x000a
771#define PCI_DEVICE_ID_VORTEX_GDT6x25 0x000b
772#define PCI_DEVICE_ID_VORTEX_GDT6535 0x000c
773#define PCI_DEVICE_ID_VORTEX_GDT6555 0x000d
774#define PCI_DEVICE_ID_VORTEX_GDT6x17RP 0x0100
775#define PCI_DEVICE_ID_VORTEX_GDT6x27RP 0x0101
776#define PCI_DEVICE_ID_VORTEX_GDT6537RP 0x0102
777#define PCI_DEVICE_ID_VORTEX_GDT6557RP 0x0103
778#define PCI_DEVICE_ID_VORTEX_GDT6x11RP 0x0104
779#define PCI_DEVICE_ID_VORTEX_GDT6x21RP 0x0105
780#define PCI_DEVICE_ID_VORTEX_GDT6x17RP1 0x0110
781#define PCI_DEVICE_ID_VORTEX_GDT6x27RP1 0x0111
782#define PCI_DEVICE_ID_VORTEX_GDT6537RP1 0x0112
783#define PCI_DEVICE_ID_VORTEX_GDT6557RP1 0x0113
784#define PCI_DEVICE_ID_VORTEX_GDT6x11RP1 0x0114
785#define PCI_DEVICE_ID_VORTEX_GDT6x21RP1 0x0115
786#define PCI_DEVICE_ID_VORTEX_GDT6x17RP2 0x0120
787#define PCI_DEVICE_ID_VORTEX_GDT6x27RP2 0x0121
788#define PCI_DEVICE_ID_VORTEX_GDT6537RP2 0x0122
789#define PCI_DEVICE_ID_VORTEX_GDT6557RP2 0x0123
790#define PCI_DEVICE_ID_VORTEX_GDT6x11RP2 0x0124
791#define PCI_DEVICE_ID_VORTEX_GDT6x21RP2 0x0125
792
793#define PCI_VENDOR_ID_EF 0x111a
794#define PCI_DEVICE_ID_EF_ATM_FPGA 0x0000
795#define PCI_DEVICE_ID_EF_ATM_ASIC 0x0002
796
797#define PCI_VENDOR_ID_FORE 0x1127
798#define PCI_DEVICE_ID_FORE_PCA200PC 0x0210
799#define PCI_DEVICE_ID_FORE_PCA200E 0x0300
800
801#define PCI_VENDOR_ID_IMAGINGTECH 0x112f
802#define PCI_DEVICE_ID_IMAGINGTECH_ICPCI 0x0000
803
804#define PCI_VENDOR_ID_PHILIPS 0x1131
805#define PCI_DEVICE_ID_PHILIPS_SAA7145 0x7145
806#define PCI_DEVICE_ID_PHILIPS_SAA7146 0x7146
807
808#define PCI_VENDOR_ID_CYCLONE 0x113c
809#define PCI_DEVICE_ID_CYCLONE_SDK 0x0001
810
811#define PCI_VENDOR_ID_ALLIANCE 0x1142
812#define PCI_DEVICE_ID_ALLIANCE_PROMOTIO 0x3210
813#define PCI_DEVICE_ID_ALLIANCE_PROVIDEO 0x6422
814#define PCI_DEVICE_ID_ALLIANCE_AT24 0x6424
815#define PCI_DEVICE_ID_ALLIANCE_AT3D 0x643d
816
817#define PCI_VENDOR_ID_SK 0x1148
818#define PCI_DEVICE_ID_SK_FP 0x4000
819#define PCI_DEVICE_ID_SK_TR 0x4200
820#define PCI_DEVICE_ID_SK_GE 0x4300
821
822#define PCI_VENDOR_ID_VMIC 0x114a
823#define PCI_DEVICE_ID_VMIC_VME 0x7587
824
825#define PCI_VENDOR_ID_DIGI 0x114f
826#define PCI_DEVICE_ID_DIGI_EPC 0x0002
827#define PCI_DEVICE_ID_DIGI_RIGHTSWITCH 0x0003
828#define PCI_DEVICE_ID_DIGI_XEM 0x0004
829#define PCI_DEVICE_ID_DIGI_XR 0x0005
830#define PCI_DEVICE_ID_DIGI_CX 0x0006
831#define PCI_DEVICE_ID_DIGI_XRJ 0x0009
832#define PCI_DEVICE_ID_DIGI_EPCJ 0x000a
833#define PCI_DEVICE_ID_DIGI_XR_920 0x0027
834
835#define PCI_VENDOR_ID_MUTECH 0x1159
836#define PCI_DEVICE_ID_MUTECH_MV1000 0x0001
837
838#define PCI_VENDOR_ID_RENDITION 0x1163
839#define PCI_DEVICE_ID_RENDITION_VERITE 0x0001
840#define PCI_DEVICE_ID_RENDITION_VERITE2100 0x2000
841
842#define PCI_VENDOR_ID_TOSHIBA 0x1179
843#define PCI_DEVICE_ID_TOSHIBA_601 0x0601
844#define PCI_DEVICE_ID_TOSHIBA_TOPIC95 0x060a
845#define PCI_DEVICE_ID_TOSHIBA_TOPIC97 0x060f
846
847#define PCI_VENDOR_ID_RICOH 0x1180
848#define PCI_DEVICE_ID_RICOH_RL5C465 0x0465
849#define PCI_DEVICE_ID_RICOH_RL5C466 0x0466
850#define PCI_DEVICE_ID_RICOH_RL5C475 0x0475
851#define PCI_DEVICE_ID_RICOH_RL5C478 0x0478
852
853#define PCI_VENDOR_ID_ARTOP 0x1191
854#define PCI_DEVICE_ID_ARTOP_ATP8400 0x0004
855#define PCI_DEVICE_ID_ARTOP_ATP850UF 0x0005
856
857#define PCI_VENDOR_ID_ZEITNET 0x1193
858#define PCI_DEVICE_ID_ZEITNET_1221 0x0001
859#define PCI_DEVICE_ID_ZEITNET_1225 0x0002
860
861#define PCI_VENDOR_ID_OMEGA 0x119b
862#define PCI_DEVICE_ID_OMEGA_82C092G 0x1221
863
864#define PCI_VENDOR_ID_MARVELL 0x11ab
865#define PCI_DEVICE_ID_MARVELL_GT6426xAB 0x6430
866
867#define PCI_VENDOR_ID_LITEON 0x11ad
868#define PCI_DEVICE_ID_LITEON_LNE100TX 0x0002
869
870#define PCI_VENDOR_ID_NP 0x11bc
871#define PCI_DEVICE_ID_NP_PCI_FDDI 0x0001
872
873#define PCI_VENDOR_ID_ATT 0x11c1
874#define PCI_DEVICE_ID_ATT_L56XMF 0x0440
875
876#define PCI_VENDOR_ID_SPECIALIX 0x11cb
877#define PCI_DEVICE_ID_SPECIALIX_IO8 0x2000
878#define PCI_DEVICE_ID_SPECIALIX_XIO 0x4000
879#define PCI_DEVICE_ID_SPECIALIX_RIO 0x8000
880
881#define PCI_VENDOR_ID_AURAVISION 0x11d1
882#define PCI_DEVICE_ID_AURAVISION_VXP524 0x01f7
883
884#define PCI_VENDOR_ID_IKON 0x11d5
885#define PCI_DEVICE_ID_IKON_10115 0x0115
886#define PCI_DEVICE_ID_IKON_10117 0x0117
887
888#define PCI_VENDOR_ID_ZORAN 0x11de
889#define PCI_DEVICE_ID_ZORAN_36057 0x6057
890#define PCI_DEVICE_ID_ZORAN_36120 0x6120
891
892#define PCI_VENDOR_ID_KINETIC 0x11f4
893#define PCI_DEVICE_ID_KINETIC_2915 0x2915
894
895#define PCI_VENDOR_ID_COMPEX 0x11f6
896#define PCI_DEVICE_ID_COMPEX_ENET100VG4 0x0112
897#define PCI_DEVICE_ID_COMPEX_RL2000 0x1401
898
899#define PCI_VENDOR_ID_RP 0x11fe
900#define PCI_DEVICE_ID_RP32INTF 0x0001
901#define PCI_DEVICE_ID_RP8INTF 0x0002
902#define PCI_DEVICE_ID_RP16INTF 0x0003
903#define PCI_DEVICE_ID_RP4QUAD 0x0004
904#define PCI_DEVICE_ID_RP8OCTA 0x0005
905#define PCI_DEVICE_ID_RP8J 0x0006
906#define PCI_DEVICE_ID_RPP4 0x000A
907#define PCI_DEVICE_ID_RPP8 0x000B
908#define PCI_DEVICE_ID_RP8M 0x000C
909
910#define PCI_VENDOR_ID_CYCLADES 0x120e
911#define PCI_DEVICE_ID_CYCLOM_Y_Lo 0x0100
912#define PCI_DEVICE_ID_CYCLOM_Y_Hi 0x0101
913#define PCI_DEVICE_ID_CYCLOM_Z_Lo 0x0200
914#define PCI_DEVICE_ID_CYCLOM_Z_Hi 0x0201
915
916#define PCI_VENDOR_ID_ESSENTIAL 0x120f
917#define PCI_DEVICE_ID_ESSENTIAL_ROADRUNNER 0x0001
918
919#define PCI_VENDOR_ID_O2 0x1217
920#define PCI_DEVICE_ID_O2_6729 0x6729
921#define PCI_DEVICE_ID_O2_6730 0x673a
922#define PCI_DEVICE_ID_O2_6832 0x6832
923#define PCI_DEVICE_ID_O2_6836 0x6836
924
925#define PCI_VENDOR_ID_3DFX 0x121a
926#define PCI_DEVICE_ID_3DFX_VOODOO 0x0001
927#define PCI_DEVICE_ID_3DFX_VOODOO2 0x0002
928
929#define PCI_VENDOR_ID_SIGMADES 0x1236
930#define PCI_DEVICE_ID_SIGMADES_6425 0x6401
931
932#define PCI_VENDOR_ID_CCUBE 0x123f
933
934#define PCI_VENDOR_ID_DIPIX 0x1246
935
936#define PCI_VENDOR_ID_STALLION 0x124d
937#define PCI_DEVICE_ID_STALLION_ECHPCI832 0x0000
938#define PCI_DEVICE_ID_STALLION_ECHPCI864 0x0002
939#define PCI_DEVICE_ID_STALLION_EIOPCI 0x0003
940
941#define PCI_VENDOR_ID_OPTIBASE 0x1255
942#define PCI_DEVICE_ID_OPTIBASE_FORGE 0x1110
943#define PCI_DEVICE_ID_OPTIBASE_FUSION 0x1210
944#define PCI_DEVICE_ID_OPTIBASE_VPLEX 0x2110
945#define PCI_DEVICE_ID_OPTIBASE_VPLEXCC 0x2120
946#define PCI_DEVICE_ID_OPTIBASE_VQUEST 0x2130
947
948#define PCI_VENDOR_ID_SATSAGEM 0x1267
949#define PCI_DEVICE_ID_SATSAGEM_PCR2101 0x5352
950#define PCI_DEVICE_ID_SATSAGEM_TELSATTURBO 0x5a4b
951
952#define PCI_VENDOR_ID_HUGHES 0x1273
953#define PCI_DEVICE_ID_HUGHES_DIRECPC 0x0002
954
955#define PCI_VENDOR_ID_ENSONIQ 0x1274
956#define PCI_DEVICE_ID_ENSONIQ_AUDIOPCI 0x5000
957
958#define PCI_VENDOR_ID_ALTEON 0x12ae
959#define PCI_DEVICE_ID_ALTEON_ACENIC 0x0001
960
961#define PCI_VENDOR_ID_PICTUREL 0x12c5
962#define PCI_DEVICE_ID_PICTUREL_PCIVST 0x0081
963
964#define PCI_VENDOR_ID_NVIDIA_SGS 0x12d2
965#define PCI_DEVICE_ID_NVIDIA_SGS_RIVA128 0x0018
966
967#define PCI_VENDOR_ID_CBOARDS 0x1307
968#define PCI_DEVICE_ID_CBOARDS_DAS1602_16 0x0001
969
970#define PCI_VENDOR_ID_SYMPHONY 0x1c1c
971#define PCI_DEVICE_ID_SYMPHONY_101 0x0001
972
973#define PCI_VENDOR_ID_TEKRAM 0x1de1
974#define PCI_DEVICE_ID_TEKRAM_DC290 0xdc29
975
976#define PCI_VENDOR_ID_3DLABS 0x3d3d
977#define PCI_DEVICE_ID_3DLABS_300SX 0x0001
978#define PCI_DEVICE_ID_3DLABS_500TX 0x0002
979#define PCI_DEVICE_ID_3DLABS_DELTA 0x0003
980#define PCI_DEVICE_ID_3DLABS_PERMEDIA 0x0004
981#define PCI_DEVICE_ID_3DLABS_MX 0x0006
982
983#define PCI_VENDOR_ID_AVANCE 0x4005
984#define PCI_DEVICE_ID_AVANCE_ALG2064 0x2064
985#define PCI_DEVICE_ID_AVANCE_2302 0x2302
986
987#define PCI_VENDOR_ID_NETVIN 0x4a14
988#define PCI_DEVICE_ID_NETVIN_NV5000SC 0x5000
989
990#define PCI_VENDOR_ID_S3 0x5333
991#define PCI_DEVICE_ID_S3_PLATO_PXS 0x0551
992#define PCI_DEVICE_ID_S3_ViRGE 0x5631
993#define PCI_DEVICE_ID_S3_TRIO 0x8811
994#define PCI_DEVICE_ID_S3_AURORA64VP 0x8812
995#define PCI_DEVICE_ID_S3_TRIO64UVP 0x8814
996#define PCI_DEVICE_ID_S3_ViRGE_VX 0x883d
997#define PCI_DEVICE_ID_S3_868 0x8880
998#define PCI_DEVICE_ID_S3_928 0x88b0
999#define PCI_DEVICE_ID_S3_864_1 0x88c0
1000#define PCI_DEVICE_ID_S3_864_2 0x88c1
1001#define PCI_DEVICE_ID_S3_964_1 0x88d0
1002#define PCI_DEVICE_ID_S3_964_2 0x88d1
1003#define PCI_DEVICE_ID_S3_968 0x88f0
1004#define PCI_DEVICE_ID_S3_TRIO64V2 0x8901
1005#define PCI_DEVICE_ID_S3_PLATO_PXG 0x8902
1006#define PCI_DEVICE_ID_S3_ViRGE_DXGX 0x8a01
1007#define PCI_DEVICE_ID_S3_ViRGE_GX2 0x8a10
1008#define PCI_DEVICE_ID_S3_ViRGE_MX 0x8c01
1009#define PCI_DEVICE_ID_S3_ViRGE_MXP 0x8c02
1010#define PCI_DEVICE_ID_S3_ViRGE_MXPMV 0x8c03
1011#define PCI_DEVICE_ID_S3_SONICVIBES 0xca00
1012
1013#define PCI_VENDOR_ID_INTEL 0x8086
1014#define PCI_DEVICE_ID_INTEL_82375 0x0482
1015#define PCI_DEVICE_ID_INTEL_82424 0x0483
1016#define PCI_DEVICE_ID_INTEL_82378 0x0484
1017#define PCI_DEVICE_ID_INTEL_82430 0x0486
1018#define PCI_DEVICE_ID_INTEL_82434 0x04a3
1019#define PCI_DEVICE_ID_INTEL_82544EI_COPPER 0x1008
1020#define PCI_DEVICE_ID_INTEL_82092AA_0 0x1221
1021#define PCI_DEVICE_ID_INTEL_82092AA_1 0x1222
1022#define PCI_DEVICE_ID_INTEL_7116 0x1223
1023#define PCI_DEVICE_ID_INTEL_82596 0x1226
1024#define PCI_DEVICE_ID_INTEL_82865 0x1227
1025#define PCI_DEVICE_ID_INTEL_82557 0x1229
1026#define PCI_DEVICE_ID_INTEL_82437 0x122d
1027#define PCI_DEVICE_ID_INTEL_82371FB_0 0x122e
1028#define PCI_DEVICE_ID_INTEL_82371FB_1 0x1230
1029#define PCI_DEVICE_ID_INTEL_82371MX 0x1234
1030#define PCI_DEVICE_ID_INTEL_82437MX 0x1235
1031#define PCI_DEVICE_ID_INTEL_82441 0x1237
1032#define PCI_DEVICE_ID_INTEL_82380FB 0x124b
1033#define PCI_DEVICE_ID_INTEL_82439 0x1250
1034#define PCI_DEVICE_ID_INTEL_82371SB_0 0x7000
1035#define PCI_DEVICE_ID_INTEL_82371SB_1 0x7010
1036#define PCI_DEVICE_ID_INTEL_82371SB_2 0x7020
1037#define PCI_DEVICE_ID_INTEL_82437VX 0x7030
1038#define PCI_DEVICE_ID_INTEL_82439TX 0x7100
1039#define PCI_DEVICE_ID_INTEL_82371AB_0 0x7110
1040#define PCI_DEVICE_ID_INTEL_82371AB 0x7111
1041#define PCI_DEVICE_ID_INTEL_82371AB_2 0x7112
1042#define PCI_DEVICE_ID_INTEL_82371AB_3 0x7113
1043#define PCI_DEVICE_ID_INTEL_82443LX_0 0x7180
1044#define PCI_DEVICE_ID_INTEL_82443LX_1 0x7181
1045#define PCI_DEVICE_ID_INTEL_82443BX_0 0x7190
1046#define PCI_DEVICE_ID_INTEL_82443BX_1 0x7191
1047#define PCI_DEVICE_ID_INTEL_82443BX_2 0x7192
1048#define PCI_DEVICE_ID_INTEL_P6 0x84c4
1049#define PCI_DEVICE_ID_INTEL_82450GX 0x84c5
1050
1051#define PCI_VENDOR_ID_KTI 0x8e2e
1052#define PCI_DEVICE_ID_KTI_ET32P2 0x3000
1053
1054#define PCI_VENDOR_ID_ADAPTEC 0x9004
1055#define PCI_DEVICE_ID_ADAPTEC_7810 0x1078
1056#define PCI_DEVICE_ID_ADAPTEC_7850 0x5078
1057#define PCI_DEVICE_ID_ADAPTEC_7855 0x5578
1058#define PCI_DEVICE_ID_ADAPTEC_5800 0x5800
1059#define PCI_DEVICE_ID_ADAPTEC_1480A 0x6075
1060#define PCI_DEVICE_ID_ADAPTEC_7860 0x6078
1061#define PCI_DEVICE_ID_ADAPTEC_7861 0x6178
1062#define PCI_DEVICE_ID_ADAPTEC_7870 0x7078
1063#define PCI_DEVICE_ID_ADAPTEC_7871 0x7178
1064#define PCI_DEVICE_ID_ADAPTEC_7872 0x7278
1065#define PCI_DEVICE_ID_ADAPTEC_7873 0x7378
1066#define PCI_DEVICE_ID_ADAPTEC_7874 0x7478
1067#define PCI_DEVICE_ID_ADAPTEC_7895 0x7895
1068#define PCI_DEVICE_ID_ADAPTEC_7880 0x8078
1069#define PCI_DEVICE_ID_ADAPTEC_7881 0x8178
1070#define PCI_DEVICE_ID_ADAPTEC_7882 0x8278
1071#define PCI_DEVICE_ID_ADAPTEC_7883 0x8378
1072#define PCI_DEVICE_ID_ADAPTEC_7884 0x8478
1073#define PCI_DEVICE_ID_ADAPTEC_1030 0x8b78
1074
1075#define PCI_VENDOR_ID_ADAPTEC2 0x9005
1076#define PCI_DEVICE_ID_ADAPTEC2_2940U2 0x0010
1077#define PCI_DEVICE_ID_ADAPTEC2_7890 0x001f
1078#define PCI_DEVICE_ID_ADAPTEC2_3940U2 0x0050
1079#define PCI_DEVICE_ID_ADAPTEC2_7896 0x005f
1080
1081#define PCI_VENDOR_ID_ATRONICS 0x907f
1082#define PCI_DEVICE_ID_ATRONICS_2015 0x2015
1083
1084#define PCI_VENDOR_ID_HOLTEK 0x9412
1085#define PCI_DEVICE_ID_HOLTEK_6565 0x6565
1086
1087#define PCI_VENDOR_ID_TIGERJET 0xe159
1088#define PCI_DEVICE_ID_TIGERJET_300 0x0001
1089
1090#define PCI_VENDOR_ID_ARK 0xedd8
1091#define PCI_DEVICE_ID_ARK_STING 0xa091
1092#define PCI_DEVICE_ID_ARK_STINGARK 0xa099
1093#define PCI_DEVICE_ID_ARK_2000MT 0xa0a1
1094/*
1095 * The PCI interface treats multi-function devices as independent
1096 * devices. The slot/function address of each device is encoded
1097 * in a single byte as follows:
1098 *
1099 * 7:3 = slot
1100 * 2:0 = function
1101 */
1102#define PCI_DEVFN(_slot,_func) ((((_slot) & 0x1f) << 3) | ((_func) & 0x07))
1103#define PCI_SLOT(_devfn) (((_devfn) >> 3) & 0x1f)
1104#define PCI_FUNC(_devfn) ((_devfn) & 0x07)
1105
1106/*
1107 * Error values that may be returned by the PCI bios.
1108 */
1109#define PCIBIOS_SUCCESSFUL 0x00
1110#define PCIBIOS_FUNC_NOT_SUPPORTED 0x81
1111#define PCIBIOS_BAD_VENDOR_ID 0x83
1112#define PCIBIOS_DEVICE_NOT_FOUND 0x86
1113#define PCIBIOS_BAD_REGISTER_NUMBER 0x87
1114#define PCIBIOS_SET_FAILED 0x88
1115#define PCIBIOS_BUFFER_TOO_SMALL 0x89
1116
1117/* T. Straumann, 7/31/2001: increased to 32 - PMC slots are not
1118 * scanned on mvme2306 otherwise
1119 */
1120#define PCI_MAX_DEVICES 32
1121#define PCI_MAX_FUNCTIONS 8
1122
1123typedef struct {
1124 int (*read_config_byte)(unsigned char, unsigned char, unsigned char,
1125 unsigned char, uint8_t *);
1126 int (*read_config_word)(unsigned char, unsigned char, unsigned char,
1127 unsigned char, uint16_t *);
1128 int (*read_config_dword)(unsigned char, unsigned char, unsigned char,
1129 unsigned char, uint32_t *);
1130 int (*write_config_byte)(unsigned char, unsigned char, unsigned char,
1131 unsigned char, uint8_t);
1132 int (*write_config_word)(unsigned char, unsigned char, unsigned char,
1133 unsigned char, uint16_t);
1134 int (*write_config_dword)(unsigned char, unsigned char, unsigned char,
1135 unsigned char, uint32_t);
1137
1138/* Error codes for pci_initialize */
1139#define PCIB_ERR_SUCCESS (0)
1140#define PCIB_ERR_UNINITIALIZED (-1) /* PCI BIOS is not initilized */
1141#define PCIB_ERR_NOTPRESENT (-2) /* PCI BIOS not present */
1142#define PCIB_ERR_NOFUNC (-3) /* Function not supported */
1143#define PCIB_ERR_BADVENDOR (-4) /* Bad Vendor ID */
1144#define PCIB_ERR_DEVNOTFOUND (-5) /* Device not found */
1145#define PCIB_ERR_BADREG (-6) /* Bad register number */
1146
1147extern int pci_initialize(void);
1148
1149typedef struct {
1150 volatile unsigned char* pci_config_addr;
1151 volatile unsigned char* pci_config_data;
1152 const pci_config_access_functions* pci_functions;
1154
1155extern rtems_pci_config_t BSP_pci_configuration;
1156
1157static inline int
1158pci_read_config_byte(
1159 unsigned char bus,
1160 unsigned char slot,
1161 unsigned char function,
1162 unsigned char where,
1163 uint8_t *val)
1164{
1165 return BSP_pci_configuration.pci_functions->read_config_byte(
1166 bus, slot, function, where, val);
1167}
1168
1169static inline int
1170pci_read_config_word(
1171 unsigned char bus,
1172 unsigned char slot,
1173 unsigned char function,
1174 unsigned char where,
1175 uint16_t *val)
1176{
1177 return BSP_pci_configuration.pci_functions->read_config_word(
1178 bus, slot, function, where, val);
1179}
1180
1181static inline int
1182pci_read_config_dword(
1183 unsigned char bus,
1184 unsigned char slot,
1185 unsigned char function,
1186 unsigned char where,
1187 uint32_t *val)
1188{
1189 return BSP_pci_configuration.pci_functions->read_config_dword(bus, slot, function, where, val);
1190}
1191
1192static inline int
1193pci_write_config_byte(
1194 unsigned char bus,
1195 unsigned char slot,
1196 unsigned char function,
1197 unsigned char where,
1198 uint8_t val)
1199{
1200 return BSP_pci_configuration.pci_functions->write_config_byte(
1201 bus, slot, function, where, val);
1202}
1203
1204static inline int
1205pci_write_config_word(
1206 unsigned char bus,
1207 unsigned char slot,
1208 unsigned char function,
1209 unsigned char where,
1210 uint16_t val)
1211{
1212 return BSP_pci_configuration.pci_functions->write_config_word(
1213 bus, slot, function, where, val);
1214}
1215
1216static inline int
1217pci_write_config_dword(
1218 unsigned char bus,
1219 unsigned char slot,
1220 unsigned char function,
1221 unsigned char where,
1222 uint32_t val)
1223{
1224 return BSP_pci_configuration.pci_functions->write_config_dword(
1225 bus, slot, function, where, val);
1226}
1227
1228/* scan for a specific device */
1229/* find a particular PCI device
1230 * (currently, only bus0 is scanned for device/fun0)
1231 *
1232 * RETURNS: zero on success, bus/dev/fun in *pbus / *pdev / *pfun
1233 */
1234int
1235pci_find_device(
1236 unsigned short vendorid,
1237 unsigned short deviceid,
1238 int instance,
1239 int *pbus,
1240 int *pdev,
1241 int *pfun
1242);
1243
1244/*
1245 * Return the number of PCI busses in the system
1246 */
1247extern unsigned char pci_bus_count(void);
1248
1249#ifdef __cplusplus
1250}
1251#endif
1252
1253#endif /* _RTEMS_PCI_H */
Definition: pci.h:1123
Definition: pci.h:1149
