RTEMS 6.1
spi.h
2
11/*
12 * Copyright (C) 2016, 2017 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef _DEV_SPI_SPI_H
37#define _DEV_SPI_SPI_H
38
39#include <linux/spi/spidev.h>
40
41#include <rtems.h>
42#include <rtems/seterr.h>
43#include <rtems/thread.h>
44
45#ifdef __cplusplus
46extern "C" {
47#endif /* __cplusplus */
48
50
51typedef struct spi_bus spi_bus;
52
68#define SPI_BUS_OBTAIN _IO(SPI_IOC_MAGIC, 13)
69
75#define SPI_BUS_RELEASE _IO(SPI_IOC_MAGIC, 23)
76
80struct spi_bus {
92 int (*transfer)(spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count);
93
103 int (*setup)(spi_bus *bus);
104
110 void (*destroy)(spi_bus *bus);
111
115 rtems_recursive_mutex mutex;
116
120 uint32_t max_speed_hz;
121
125 uint32_t speed_hz;
126
131
135 uint8_t cs;
136
141
146
150 uint32_t mode;
151
156 uint16_t delay_usecs;
157
163 int (*ioctl)(spi_bus *bus, ioctl_command_t command, void *arg);
164};
165
181int spi_bus_init(spi_bus *bus);
182
200spi_bus *spi_bus_alloc_and_init(size_t size);
201
207void spi_bus_destroy(spi_bus *bus);
208
215
229 spi_bus *bus,
230 const char *bus_path
231);
232
235#ifdef __cplusplus
236}
237#endif /* __cplusplus */
238
239#endif /* _DEV_SPI_SPI_H */
spi_bus * spi_bus_alloc_and_init(size_t size)
Allocates a bus control from the heap and initializes it.
Definition: spi-bus.c:323
Initializes a bus control.
Definition: spi-bus.c:316
int spi_bus_register(spi_bus *bus, const char *bus_path)
Registers a bus control.
Definition: spi-bus.c:248
void spi_bus_destroy_and_free(spi_bus *bus)
Destroys a bus control and frees its memory.
Definition: spi-bus.c:310
Destroys a bus control.
Definition: spi-bus.c:305
This header file defines macros to set errno and return minus one.
RTEMS Port of Linux SPI API.
SPI bus control.
Definition: spi.h:80
void(* destroy)(spi_bus *bus)
Destroys the bus.
Definition: spi.h:110
uint8_t cs
Indicates which device is selected by chip select.
Definition: spi.h:135
uint32_t mode
Current mode.
Definition: spi.h:150
Indicates the delay between transfers on different chip select devices.
Definition: spi.h:156
int(* transfer)(spi_bus *bus, const spi_ioc_transfer *msgs, uint32_t msg_count)
Transfers SPI messages.
Definition: spi.h:92
bool lsb_first
Indicates if LSB is supposed to be transmitted first.
Definition: spi.h:145
int(* ioctl)(spi_bus *bus, ioctl_command_t command, void *arg)
Driver specific ioctl.
Definition: spi.h:163
int(* setup)(spi_bus *bus)
Checks if maximum speed and bits per word are in a valid range for the device.
Definition: spi.h:103
bool cs_change
Indicates if chip select must be set high after transfer.
Definition: spi.h:130
uint32_t speed_hz
Indicates the speed of the current device message.
Definition: spi.h:125
Mutex to protect the bus access.
Definition: spi.h:115
Maximum Speed in Hz.
Definition: spi.h:120
uint8_t bits_per_word
Indicates the bits per word used on the device.
Definition: spi.h:140
SPI transfer message.
Definition: spidev.h:158
This header file provides the API of Self-Contained Objects.
