RTEMS
6.1
bsps
powerpc
include
bsp
consoleIo.h
1
2
* consoleIo.h -- console I/O package interface
3
4
* Copyright (C) 1999 Eric Valette. valette@crf.canon.fr
5
6
* The license and distribution terms for this file may be
7
* found in the file LICENSE in this distribution or at
8
* http://www.rtems.org/license/LICENSE.
9
10
11
#ifndef __CONSOLE_IO_H
12
#define __CONSOLE_IO_H
13
14
typedef
enum
15
CONSOLE_LOG = 1,
16
CONSOLE_SERIAL = 2,
17
CONSOLE_VGA = 3,
18
CONSOLE_VACUUM = 4
19
}ioType;
20
21
typedef
volatile
unsigned
char
* __io_ptr;
22
23
typedef
struct
24
__io_ptr io_base;
25
__io_ptr isa_mem_base;
26
board_memory_map
27
28
extern
board_memory_map
*ptr_mem_map;
29
30
extern
int
select_console(ioType t);
31
/* extern int printk(const char *, ...) __attribute__((format(printf, 1, 2))); */
32
extern
void
debug_putc(
const
char
c);
33
extern
void
debug_putc_onlcr(
const
char
c);
34
extern
int
debug_getc(
void
35
extern
int
debug_tstc(
void
36
int
kbdreset(
void
37
38
#endif
board_memory_map
Definition:
consoleIo.h:23
